Windows 7 + CUDA + parallel Nsight + VS2010 Instalation
I have problem with instalation parallel nsight. I tried different ways but with no results. So I reinstall PC and I tried it again, but still it doesn’t work.
Ok what’s my problem:
I used unofficial program “nexus”, because it supported VS2010. Finally parallel nsight is here and by the way it should support VS2010…
Maybe I’m looser… Can anyone help me? I really need step-by-step manual because I think I make a mistake somewhere.
What I did: install vs2010, instal the newest drivers ( 266.58 ), CUDA toolit 3.2, CUDA SDK 3.2, Parallel nsight host 1.51 and Parallel nsight monitor 1.51.
I can see only Nsight tab up to window. But If I want setup new CUDA project, I see only default C++ projects.
I really need help, I’m helpless and I don’t know what I should do with it.
Thx for answers
PS: I’m sorry for my bad english
Šňůrka Bill
BTW: I have Windows 7 ultimate 64 bit
Hi ,
I have simmilar trouble - after pritty new installation of Windows 7 ultimate x64, VS2008 SP1, VS2010,
devdriver_3.2_winvista-win7_64_263.06_general
cudatoolkit_3.2.16_win_64
gpucomputingsdk_3.2.16_win_64
Both visual studios do no show CUDA templates when I want to create new project - it is normal ??
When I try to compile sample project - there is many paths missing and build failed
  • I must handy set paths in the project(V90 set in project) properties - it is normal ??
thanks for any advice
In case you haven’t resolved it yet: the tutorial here http://forums.nvidia.com/index.php?showtopic=184539 worked perfectly fine for me (also VS 2010 + Win7-64). There is no template project for CUDA in nSight (dont ask me why, i would also like to know…), but you can set it up quite easily using this guide.
