I am observing a similar problem.
I hava a Windows 7 laptop with a NVidia Quadra M2000M card. The CUDA GPUs website lists a compute capablity of 5.0. I installed the latest Nvidia graphic drivers (388.16), CUDA v8.0 and cudnn v6 for Cuda 8.
deviceQuery shows the following error:
C:\ProgramData\NVIDIA Corporation\CUDA Samples\v8.0\bin\win64\Release\deviceQuery.exe Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 38
→ no CUDA-capable device is detected
Result = FAIL
When I run deviceQuery, a Windows alert pops up: 'Das Gerät “NVIDIA Quadro M2000M” ist kein Wechselgerät und kann daher nicht abgedockt oder entfernt werden." (The device NVIDIA Quadro M2000M is not a pluggable device and therefore it cannot be unplugged or removed.)
nvidia-smi.exe gives me the following output:
“c:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe”
Mon Jan 08 12:05:54 2018
| NVIDIA-SMI 376.51 Driver Version: 376.51 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 Quadro M2000M WDDM | 0000:01:00.0 Off | N/A |
| N/A 48C P0 N/A / N/A | 61MiB / 4096MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
Any help would be appreciated!
