New fresh install windows 2016 with Mellanox MCX512A-ACAT
Make sure firmware is updated
Firmware Flash Card
Mellanox Firmware Tools (MFT) Mellanox Firmware Tools (MFT)
PS C:\Windows\system32> cd 'C:\Program Files\Mellanox\WinMFT'
PS C:\Program Files\Mellanox\WinMFT> mst status
MST devices:
mt4119_pciconf0
PS C:\Program Files\Mellanox\WinMFT> mst status -v
MST devices:
mt4119_pciconf0 bus:dev.fn=1a:00.0
mt4119_pciconf0.1 bus:dev.fn=1a:00.1
PS C:\Program Files\Mellanox\WinMFT> mlxfwmanager -d mt4119_pciconf0 --query
Querying Mellanox devices firmware …
Device #1:
Device Type: ConnectX5
Part Number: MCX512A-ACA_Ax
Description: ConnectX-5 EN network interface card; 10/25GbE dual-port SFP28; PCIe3.0 x8; tall bracket; ROHS R6
PSID: MT_0000000080
PCI Device Name: mt4119_pciconf0
Base GUID: 98039b0300325eba
Base MAC: 98039b325eba
Versions: Current Available
FW 16.22.1002 N/A
PXE 3.5.0403 N/A
UEFI 14.15.0019 N/A
Status: No matching image found
PS C:\ftp\Mellanox_iSER\fw-ConnectX5-rel-16_23_1020-MCX512A-ACA_Ax-UEFI-14.16.17-FlexBoot-3.5.504.bin> dir
Directory: C:\ftp\Mellanox_iSER\fw-ConnectX5-rel-16_23_1020-MCX512A-ACA_Ax-UEFI-14.16.17-FlexBoot-3.5.504.bin
Mode LastWriteTime Length Name
------ 7/12/2018 8:57 AM 16777216 fw-ConnectX5-rel-16_23_1020-MCX512A-ACA_Ax-UEFI-14.16.17-FlexBoot-3.5.504.bin
PS C:\ftp\Mellanox_iSER\fw-ConnectX5-rel-16_23_1020-MCX512A-ACA_Ax-UEFI-14.16.17-FlexBoot-3.5.504.bin> flint.bat -d mt4119_pciconf0 -i .\fw-ConnectX5-rel-16_23_1020-MCX512A-ACA_Ax-UEFI-14.16.17-FlexBoot-3.5.504.bin
No command found.
No options found.
copy C:\ftp\Mellanox_iSER\fw-ConnectX5-rel-16_23_1020-MCX512A-ACA_Ax-UEFI-14.16.17-FlexBoot-3.5.504.bin C:\Program Files\Mellanox\WinMFT\
PS C:\Program Files\Mellanox\WinMFT> .\flint_ext.exe -d mt4119_pciconf0 -i .\fw-ConnectX5-rel-16_23_1020-MCX512A-ACA_Ax-UEFI-14.16.17-FlexBoot-3.5.504.bin
No command found.
PS C:\Program Files\Mellanox\WinMFT> .\flint.bat -d mt4119_pciconf0 -i .\fw-ConnectX5-rel-16_23_1020-MCX512A-ACA_Ax-UEFI-14.16.17-FlexBoot-3.5.504.bin
No command found.
I know the firmware is back rev. I try simple run of flint command per document. then “.exe” vs “.bat” then move firmware bin file into same directory as flint binary… no change… But when I run “flint” by itself it gives different response that I am missing options so “No command found” not helpful at all as to what is not being found.
thanks,
