I’m adding some CUDA functionality to an existing Windows Forms app. I’ve simply added a .cu file to the project which has a device kernel function and a standard C function wrapper to call the kernel.
I then call the C function from the Windows Forms part of my code.
So far everything works fine, except I can’t step into (debug) the C function in my .cu file. If I put a breakpoint in the C function, execution simply halts at the caller function (in the Windows Forms part).
Any pointers to where I might start to look? (my runtime library setting in both C/C++ and the CUDA build step section is /MDd, by the way)
Also, I’m on WinXP, VS2005
Thanks in advance
