I just purchased an ASUS Geforce RTX 3050. I’m running Fedora 38 and I installed the nvidia drivers through rpmfusion. I used to be able to fit 4 firefox windows without overlapping on my 32 inch monitor resolution 3840x2160. After installing the nvidia drivers I can only fit 2 firefox windows overlapping each other on my monitor. The problem seems to be a larger font is used which makes everything bigger. What can I do fix this problem?
Related topics
Topic | Replies | Views | Activity | |
No option for my resolution after installing nvidia driver | 0 | 521 | July 23, 2023 | |
Probem regarding big screen due to graohic card issue of NVIDIA GeForce RTX 3060 | 5 | 398 | November 15, 2023 | |
NVIDIA card may not working properly, unable to change resolution | 0 | 402 | June 6, 2023 | |
Unable to Install Drivers | 0 | 407 | September 1, 2018 | |
Monitors connected to on-board HMDI and VGA ports shows blank after installing Nvidia Driver | Fedora 32 | 2 | 704 | October 12, 2021 | |
Nvidia multi-monitor setup won't span screens | 0 | 1485 | July 18, 2013 | |
Geforce GTX 960M missing resolutions with nvidia drivers installed on Ubuntu. | 0 | 664 | January 15, 2020 | |
nvidia xorg configuration only allows maximum screen resolution, nvidia settings not retained on reb | 0 | 934 | June 10, 2016 | |
F32 : upgrade to 32.20200913.0 from 32.20200822.0 nvidia troubles | 0 | 293 | September 14, 2020 | |
New laptop with M2000M running Fedora25: installing driver fails on libglvnd and dkms | 1 | 1554 | December 7, 2016 |
