Hi!
Is there any tool support to flash the Jetson Orin Nano Dev Kit from a Windows machine?
Best regards,
Stefan
Hi!
Best regards,
Stefan
Does not exist. Your best and least frustrating results will be if you dual boot to Ubuntu 18.04. Some people use VMs, but this is hit and miss due to needing to correctly setting up USB. I’ve heard of more advanced users using WSL2, but you have to know how to both set up USB correctly, and install loopback capability. I’ll strongly encourage dual boot.
NOTE: You’re also in the older TX1 Nano forum. You should post in the Orin Nano forum.
I almost forgot: Because this is Orin Nano, you could use Ubuntu 18.04, but you are better off using Ubuntu 20.04 instead (Orin is newer).
