Goal
Command
set USE_LIBUV=0 && set MASTER_ADDR=127.0.0.1 && set MASTER_PORT=29500 ^
&& python -m torch.distributed.run --nproc_per_node=2 train_tuple.py --ddp --use_gpu
(Also tried torchrun alias, same result.)
Error (excerpt)
torch.distributed.DistStoreError: use_libuv was requested but PyTorch was built without libuv support, run with USE_LIBUV
System & environment
OS / GPU
Windows 10/11 (x64)
(RTX 5090) — Driver version: (please advise if you need exact
nvidia-smioutput; can share)
Python
python 3.11.14
PyTorch / CUDA / FAISS (conda + pip mix)
torch 2.10.0.dev20251022+cu128 (pip)
torchvision 0.25.0.dev20251022+cu128 (pip)
torchaudio 2.10.0.dev20251022+cu128 (pip))
faiss 1.9.0 py311cuda126... (conda-forge)
faiss-gpu 1.9.0 ... (conda-forge)
cuda-toolkit 12.8.0 (conda, NVIDIA label)
cudnn 9.13.1 (conda-forge)
the error message specifically complains about libuv rendezvous.
Screenshot 2025-10-25 0806321920×999 173 KB
Things I already tried
Setting
USE_LIBUV=0in the shell and at the very top of the script (before anytorchimport). -
Explicit
backend="gloo"ininit_process_group. -
Using
python -m torch.distributed.runvstorchrun. -
Ensuring
MASTER_ADDR/MASTER_PORTare set and free. -
Verifying single-process execution works.
Verified that
os.environ["USE_LIBUV"]prints0inside the script right before importingtorch.distributed. -
I have looked into all the forums and tried various version of nightly and different suggested combinations of torch and cuda the error still remain.
Questions for the community
Is libuv rendezvous expected/required on current PyTorch nightlies for Windows, or should
USE_LIBUV=0fully disable it? -
What’s the recommended, known-good install matrix for:
Windows + CUDA 12.6/12.8
PyTorch (stable/nightly) + torchvision/torchaudio
FAISS (GPU)
so that DDP (gloo backend) works withnproc_per_node>1?
If libuv rendezvous is the intended default on Windows nightlies, how do I force TCPStore/gloo without libuv, or how do I install a libuv-enabled/non-libuv PyTorch build for Windows?
Any guidance on FAISS build compatibility with the above stack on Windows would also be appreciated (I’m fine to re-create a clean env).
What works vs fails (using the same exact code base)
:white_check_mark: RTX 4090 — OK (DDP with
nproc_per_node=2) -
:white_check_mark: RTX 2080 Ti — OK
:cross_mark: RTX 50-series — fails with the libuv rendezvous error
