Windows11 22h2 fails with "windows version not compatible" and "no device found" when using GPU passthrough
I’ve installed Ubuntu 22.04.1 amd64 LTS on an Acer VN7-593G-73E7 notebook with a GTX 1060m (6GB VRAM) and did all updates/upgrades. After that I added GRUB_CMDLINE_LINUX_DEFAULT="intel_iommu=on iommu=pt i915.enable_gvt=1 vfio-pci.ids=10de:10f1,10de:1c20" to /etc/default/grub and ran update-grub and did a reboot.
After installing all the KVM/QEMU/Virt-Manager packages I created the following Windows11 Home 22h2-VM:
<domain type="kvm">
  <name>Windows11Home</name>
  <uuid>2c90b6e0-e872-4e3c-a106-71376c8922ae</uuid>
  <title>Windows11Home</title>
  <description>Windows11Home</description>
  <metadata>
    <libosinfo:libosinfo xmlns:libosinfo="http://libvirt.org/schemas/domain/qemu/1.0">
      <libosinfo:os id="http://microsoft.com/win/10"/>
    </libosinfo:libosinfo>
  </metadata>
  <memory unit="KiB">33554432</memory>
  <currentMemory unit="KiB">33554432</currentMemory>
  <memoryBacking>
    <source type="memfd"/>
    <access mode="shared"/>
  </memoryBacking>
  <vcpu placement="static">6</vcpu>
  <os>
    <type arch="x86_64" machine="pc-q35-6.2">hvm</type>
    <loader readonly="yes" secure="yes" type="pflash">/usr/share/OVMF/OVMF_CODE_4M.secboot.fd</loader>
    <nvram>/var/lib/libvirt/qemu/nvram/Windows11Home_VARS.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv mode="custom">
      <relaxed state="on"/>
      <vapic state="on"/>
      <spinlocks state="on" retries="8191"/>
      <vendor_id state="on" value="randomid"/>
    </hyperv>
    <vmport state="off"/>
    <smm state="on"/>
  </features>
  <cpu mode="host-passthrough" check="none" migratable="on">
    <topology sockets="1" dies="1" cores="3" threads="2"/>
  </cpu>
  <clock offset="localtime">
    <timer name="rtc" tickpolicy="catchup"/>
    <timer name="pit" tickpolicy="delay"/>
    <timer name="hpet" present="no"/>
    <timer name="hypervclock" present="yes"/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled="no"/>
    <suspend-to-disk enabled="no"/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <disk type="file" device="disk">
      <driver name="qemu" type="qcow2" cache="writeback" discard="unmap"/>
      <source file="/var/lib/libvirt/images/Windows11Home.qcow2"/>
      <target dev="vda" bus="virtio"/>
      <boot order="1"/>
      <address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
    </disk>
      <driver name="qemu" type="qcow2"/>
      <source file="/var/lib/libvirt/images/Windows11Home-1.qcow2"/>
      <target dev="vdb" bus="virtio"/>
      <address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
    </disk>
    <disk type="file" device="cdrom">
      <driver name="qemu" type="raw"/>
      <source file="/home/renne/Dokumente/Software/ISOs/MS_Windows/virtio-win-0.1.229.iso"/>
      <target dev="sda" bus="sata"/>
      <readonly/>
      <address type="drive" controller="0" bus="0" target="0" unit="0"/>
    </disk>
    <controller type="usb" index="0" model="qemu-xhci" ports="15">
      <address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
    </controller>
    <controller type="pci" index="0" model="pcie-root"/>
    <controller type="pci" index="1" model="pcie-root-port">
      <model name="pcie-root-port"/>
      <target chassis="1" port="0x10"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="2" model="pcie-root-port">
      <target chassis="2" port="0x11"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
    </controller>
    <controller type="pci" index="3" model="pcie-root-port">
      <target chassis="3" port="0x12"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
    </controller>
    <controller type="pci" index="4" model="pcie-root-port">
      <target chassis="4" port="0x13"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
    </controller>
    <controller type="pci" index="5" model="pcie-root-port">
      <target chassis="5" port="0x14"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
    </controller>
    <controller type="pci" index="6" model="pcie-root-port">
      <target chassis="6" port="0x15"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
    </controller>
    <controller type="pci" index="7" model="pcie-root-port">
      <target chassis="7" port="0x16"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/>
    </controller>
    <controller type="pci" index="8" model="pcie-root-port">
      <target chassis="8" port="0x17"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x7"/>
    </controller>
    <controller type="pci" index="9" model="pcie-root-port">
      <target chassis="9" port="0x18"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x0" multifunction="on"/>
    </controller>
    <controller type="pci" index="10" model="pcie-root-port">
      <target chassis="10" port="0x19"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x1"/>
    </controller>
    <controller type="pci" index="11" model="pcie-root-port">
      <target chassis="11" port="0x1a"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x2"/>
    </controller>
    <controller type="pci" index="12" model="pcie-root-port">
      <target chassis="12" port="0x1b"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x3"/>
    </controller>
    <controller type="pci" index="13" model="pcie-root-port">
      <target chassis="13" port="0x1c"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x4"/>
    </controller>
    <controller type="pci" index="14" model="pcie-root-port">
      <target chassis="14" port="0x1d"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x5"/>
    </controller>
    <controller type="pci" index="15" model="pcie-root-port">
      <target chassis="15" port="0x1e"/>
      <address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x6"/>
    </controller>
    <controller type="pci" index="16" model="pcie-to-pci-bridge">
      <model name="pcie-pci-bridge"/>
      <address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
    </controller>
    <controller type="sata" index="0">
      <address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
    </controller>
    <interface type="network">
      <mac address="52:54:00:ce:5c:ac"/>
      <source network="default"/>
      <model type="virtio"/>
      <link state="up"/>
      <address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
    </interface>
    <input type="mouse" bus="ps2"/>
    <input type="keyboard" bus="ps2"/>
    <tpm model="tpm-tis">
      <backend type="emulator" version="2.0"/>
    </tpm>
    <audio id="1" type="none"/>
    <hostdev mode="subsystem" type="pci" managed="yes">
      <source>
        <address domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
      </source>
      <rom file="/usr/share/vgabios/NVidia_Geforce_GTX_1060m-GP106.rom"/>
      <address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
    </hostdev>
      <source>
        <address domain="0x0000" bus="0x01" slot="0x00" function="0x1"/>
      </source>
      <address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
    </hostdev>
    <hostdev mode="subsystem" type="usb" managed="yes">
      <source>
        <vendor id="0x046d"/>
        <product id="0xc52b"/>
      </source>
      <address type="usb" bus="0" port="1"/>
    </hostdev>
    <memballoon model="virtio">
      <address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
    </memballoon>
    <shmem name="looking-glass">
      <model type="ivshmem-plain"/>
      <size unit="M">128</size>
      <address type="pci" domain="0x0000" bus="0x10" slot="0x01" function="0x0"/>
    </shmem>
  </devices>
</domain>
When I try to install the GameReadyDrivers (tested with 528.24 and 528.49) I get the error message (translated from german) “This graphics driver is not compatible with this Windows version. The graphics driver could not find a compatible graphics hardware.”
How can I find the reason for that inexpressive error message?
Are there any logs available from the installer?
Thanx for any hint! :-)
Renne
Passing through a mobile dgpu of a notebook is not that easy and straight forward. Please see this thread from a user who managed to succeed:
https://forums.developer.nvidia.com/t/trying-to-get-discrete-laptop-gpu-running-in-qemu-kvm-windows/221706
