I am looking for install and use wine on jetson nano 2gb.
I’ve seen some posts on the forum but I didn’t understood as well if is possible install it or no , and if the answer is positive if there is a tutorial step by step.
I am trying following several tutorial but less or more without success and i am pretty disappointed of that due i think jetson can give big results running wine
It would be good if someday nvidia will rethink multilib support it will gain many uses that you need the 32bit library to run 32bit binaries similar to how Steam works on PC with 32bit games.
I followed your suggest and i figure out with box64 that is clear and step by step , but not with box86 , I didn’t found specified instructions for tegra / jetson system and i am stuck on wine32 missing message
