Hi, I’m using Jetson Nano with an AC-8265 wifi card. I’ve disabled Ubuntu 18.04 desktop and using netplan for networking. I’ve manage to config AC8256 as a client for my WiFi router, but now I need to config it as an AP. Is there a way to make it work? If not, then is there a wifi dongle that work in AP mode?
that post is not working for me.
I boot in gui again ( sudo systemctl set-default graphical.target) in order to test hotspot mode but I can’t configure the wi-fi. under Wi-Fi Networks I can see “device not managed” and I don’t see any wireless network to connect to. Is there a way to restore the network?
BTW iwconfig and ifconfig -a shows that wlan0 is connected to mi wifi router, but I can’t use network-manager to manage the connections
I have no idea now as other usesr can get it working on both Nano and Orin, maybe to reinstall the network manager could help, or reflash your device to start setting it from the beginning.
ok, the flash solution works. I make a hotspot on a new system using GUI, then disable the GUI and reboot. The wifi AP is still there.
I would like to config ip address for the AP, I will look into it.
thank
