Hello, I also have a similar issue.
I have 2 TX2s running JetPack 3.1. The access point was created with NetworkManager, but to enable the Hotspot functionality, I added the following line to /etc/modprobe.d/bcmdhd.conf
options bcmdhd op_mode=2
I also disabled power-save by default by creating a file at /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf with
[connection]
wifi.powersave = 2
I am always able to start the TX2 with the AP running. But sometimes, after anywhere from 15 minutes to 7 hours later, all connected devices will be kicked and any attempts to reconnect will fail. The SSID always stays visible. Trying to connect with either Ubuntu or Windows just indicates that it is connecting with no update or password prompt until it just stops attempting to connect.
Rebooting the TX2 resets the problem, but problem has the irritating tendency of appearing when I cannot manually reboot it. There is no other network connection to the TX2s. I have noticed that this happens when I am running code that is continuously sending and receiving packets, but more than 90% of the time, this problem never occurs.
Access Point parameters (output of nmcli)
connection.id: Center Dos
connection.uuid: 4d90c42d-8362-422c-b21b-85f982ead050
connection.interface-name: wlan0
connection.type: 802-11-wireless
connection.autoconnect: yes
connection.autoconnect-priority: 0
connection.timestamp: 1536105245
connection.read-only: no
connection.permissions:
connection.zone: --
connection.master: --
connection.slave-type: --
connection.autoconnect-slaves: -1 (default)
connection.secondaries:
connection.gateway-ping-timeout: 0
connection.metered: unknown
connection.lldp: -1 (default)
802-11-wireless.ssid: centerdos
802-11-wireless.mode: ap
802-11-wireless.band: a
802-11-wireless.channel: 36
802-11-wireless.bssid: --
802-11-wireless.rate: 0
802-11-wireless.tx-power: 0
802-11-wireless.mac-address: 01:23:45:67:89:AB
802-11-wireless.cloned-mac-address: --
802-11-wireless.mac-address-blacklist:
802-11-wireless.mac-address-randomization:default
802-11-wireless.mtu: auto
802-11-wireless.seen-bssids: 01:23:45:67:89:AB
802-11-wireless.hidden: no
802-11-wireless.powersave: default (0)
802-11-wireless-security.key-mgmt: wpa-psk
802-11-wireless-security.wep-tx-keyidx: 0
802-11-wireless-security.auth-alg: --
802-11-wireless-security.proto:
802-11-wireless-security.pairwise:
802-11-wireless-security.group:
802-11-wireless-security.leap-username: --
802-11-wireless-security.wep-key0: <hidden>
802-11-wireless-security.wep-key1: <hidden>
802-11-wireless-security.wep-key2: <hidden>
802-11-wireless-security.wep-key3: <hidden>
802-11-wireless-security.wep-key-flags: 0 (none)
802-11-wireless-security.wep-key-type: 0 (unknown)
802-11-wireless-security.psk: <hidden>
802-11-wireless-security.psk-flags: 0 (none)
802-11-wireless-security.leap-password: <hidden>
802-11-wireless-security.leap-password-flags:0 (none)
ipv4.method: shared
ipv4.dns:
ipv4.dns-search:
ipv4.dns-options: (default)
ipv4.dns-priority: 0
ipv4.addresses:
ipv4.gateway: --
ipv4.routes:
ipv4.route-metric: -1
ipv4.ignore-auto-routes: no
ipv4.ignore-auto-dns: no
ipv4.dhcp-client-id: --
ipv4.dhcp-timeout: 0
ipv4.dhcp-send-hostname: yes
ipv4.dhcp-hostname: --
ipv4.dhcp-fqdn: --
ipv4.never-default: no
ipv4.may-fail: yes
ipv4.dad-timeout: -1 (default)
ipv6.method: ignore
ipv6.dns:
ipv6.dns-search:
ipv6.dns-options: (default)
ipv6.dns-priority: 0
ipv6.addresses:
ipv6.gateway: --
ipv6.routes:
ipv6.route-metric: -1
ipv6.ignore-auto-routes: no
ipv6.ignore-auto-dns: no
ipv6.never-default: no
ipv6.may-fail: yes
ipv6.ip6-privacy: 0 (disabled)
ipv6.addr-gen-mode: stable-privacy
ipv6.dhcp-send-hostname: yes
ipv6.dhcp-hostname: --
GENERAL.NAME: Center Dos
GENERAL.UUID: 4d90c42d-8362-422c-b21b-85f982ead050
GENERAL.DEVICES: wlan0
GENERAL.STATE: activated
GENERAL.DEFAULT: no
GENERAL.DEFAULT6: no
GENERAL.VPN: no
GENERAL.ZONE: --
GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/ActiveConnection/0
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/Settings/1
GENERAL.SPEC-OBJECT: /org/freedesktop/NetworkManager/AccessPoint/1
GENERAL.MASTER-PATH: --
IP4.ADDRESS[1]: 10.42.0.1/24
IP4.GATEWAY:
IP4.ROUTE[1]: dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000
IP6.ADDRESS[1]: fe80::204:4bff:fe8c:7474/64
IP6.GATEWAY:
Output of dmesg (clipped to start of error):
[ 92.323878] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 92.350189] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 92.368070] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 93.387134] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 724.186473] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DISASSOC_IND(12) status 0 reason 8
[ 724.207931] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 726.235791] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 726.275678] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 726.290115] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 727.309954] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 739.506241] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DISASSOC_IND(12) status 0 reason 8
[ 739.530404] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 810.304073] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 810.326384] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 810.340966] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 811.359858] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 891.978250] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DISASSOC_IND(12) status 0 reason 8
[ 891.987951] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DEAUTH(5) status 0 reason 7
[ 891.994919] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 894.808172] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 894.831966] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 894.846887] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 895.865451] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 1074.704494] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DISASSOC_IND(12) status 0 reason 8
[ 1074.714137] CFG80211-ERROR) wl_notify_connect_status_ap :
[ 1074.718058] CFG80211-ERROR) wl_cfg80211_del_station :
[ 1074.718069] Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 1074.729050] event WLC_E_DEAUTH(5) status 0 reason 7
[ 1077.588401] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 1077.606917] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 1077.621511] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 1078.640260] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 1086.911999] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DISASSOC_IND(12) status 0 reason 8
[ 1086.925295] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 1158.202313] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 1158.228466] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 1158.243296] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 1159.261957] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 3821.202975] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 3821.271515] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 3821.293473] CFG80211-ERROR) wl_cfg80211_get_key : Invalid algo (0x46)
[ 3830.947930] test_program[3755]: unhandled level 2 translation fault (11) at 0x00000000, esr 0x92000006
[ 3830.957287] pgd = ffffffc0688f6000
[ 3830.960768] [00000000] *pgd=00000000e4c43003, *pud=00000000e4c43003, *pmd=0000000000000000
[ 3830.970757] CPU: 3 PID: 3755 Comm: test_program Not tainted 4.4.38-tegra #1
[ 3830.977736] Hardware name: quill (DT)
[ 3830.981419] task: ffffffc07212e400 ti: ffffffc07b34c000 task.ti: ffffffc07b34c000
[ 3830.988955] PC is at 0x7fab084880
[ 3830.992284] LR is at 0x7fab085a38
[ 3830.995602] pc : [<0000007fab084880>] lr : [<0000007fab085a38>] pstate: 80000000
[ 3831.002991] sp : 0000007ff2680630
[ 3831.006297] x29: 0000007ff2680630 x28: 0000000000000000
[ 3831.011630] x27: 0000000000000000 x26: 0000000000000000
[ 3831.016962] x25: 0000000000000000 x24: 0000000000000001
[ 3831.022295] x23: 0000000000000003 x22: 0000007fab4bcbf8
[ 3831.027660] x21: 0000000000000003 x20: 0000007fab695000
[ 3831.033043] x19: 0000007fab695000 x18: 0000000000000014
[ 3831.038381] x17: 00000000004d2280 x16: 0000007fab085848
[ 3831.043725] x15: 0000007fab7c3000 x14: 0000000000000000
[ 3831.049057] x13: 610a2c6d65747379 x12: 7320656c69662065
[ 3831.054391] x11: 6874206e69207473 x10: 0101010101010101
[ 3831.059727] x9 : 0000000000524550 x8 : 0000000000000000
[ 3831.065061] x7 : 0000007fab7c3cb8 x6 : 0000007ff2680840
[ 3831.070391] x5 : 00000000ffffffe0 x4 : 00000000ffffff80
[ 3831.075728] x3 : 0000007ff2680860 x2 : 0000000000000001
[ 3831.081060] x1 : 0000007ff2680830 x0 : 0000000000000000
[ 3831.087921] Library at 0x7fab084880: 0x7faabc7000 /usr/lib/libgdal.so.1.18.3
[ 3831.094970] Library at 0x7fab085a38: 0x7faabc7000 /usr/lib/libgdal.so.1.18.3
[ 3831.102011] vdso base = 0x7fab7c2000
[ 4819.627373] _dhd_wlfc_deque_afq: queue is empty
[ 4819.631906] _dhd_wlfc_deque_afq: queue is empty
[ 4819.636441] _dhd_wlfc_deque_afq: queue is empty
[ 4819.640968] _dhd_wlfc_deque_afq: queue is empty
[ 4819.645494] _dhd_wlfc_deque_afq: queue is empty
[ 4819.650016] _dhd_wlfc_deque_afq: queue is empty
[ 4819.654541] _dhd_wlfc_deque_afq: queue is empty
[ 4819.659064] _dhd_wlfc_deque_afq: queue is empty
[ 4819.663587] _dhd_wlfc_deque_afq: queue is empty
[ 4819.668112] _dhd_wlfc_deque_afq: queue is empty
[ 4819.672634] _dhd_wlfc_deque_afq: queue is empty
[ 4819.677157] _dhd_wlfc_deque_afq: queue is empty
[ 4819.681680] _dhd_wlfc_deque_afq: queue is empty
[ 4819.686204] _dhd_wlfc_deque_afq: queue is empty
[ 4819.690727] _dhd_wlfc_deque_afq: queue is empty
[ 4819.695250] _dhd_wlfc_deque_afq: queue is empty
[ 4819.699774] _dhd_wlfc_deque_afq: queue is empty
[ 4819.704299] _dhd_wlfc_deque_afq: queue is empty
[ 4819.708822] _dhd_wlfc_deque_afq: queue is empty
[ 4819.713384] _dhd_wlfc_deque_afq: queue is empty
[ 4819.717912] _dhd_wlfc_deque_afq: queue is empty
[ 4819.722436] _dhd_wlfc_deque_afq: queue is empty
[ 4819.726958] _dhd_wlfc_deque_afq: queue is empty
[ 4819.731480] _dhd_wlfc_deque_afq: queue is empty
[ 4819.736006] _dhd_wlfc_deque_afq: queue is empty
[ 4819.740528] _dhd_wlfc_deque_afq: queue is empty
[ 4819.745051] _dhd_wlfc_deque_afq: queue is empty
[ 4819.749573] _dhd_wlfc_deque_afq: queue is empty
[ 4819.754097] _dhd_wlfc_deque_afq: queue is empty
[ 4819.758620] _dhd_wlfc_deque_afq: queue is empty
[ 4819.763142] _dhd_wlfc_deque_afq: queue is empty
[ 4819.767667] _dhd_wlfc_deque_afq: queue is empty
[ 4819.772190] _dhd_wlfc_deque_afq: queue is empty
[ 4819.776711] _dhd_wlfc_deque_afq: queue is empty
[ 4819.781233] _dhd_wlfc_deque_afq: queue is empty
[ 4819.785757] _dhd_wlfc_deque_afq: queue is empty
[ 4819.790281] _dhd_wlfc_deque_afq: queue is empty
[ 4819.794803] _dhd_wlfc_deque_afq: queue is empty
[ 4819.799326] _dhd_wlfc_deque_afq: queue is empty
[ 4819.804258] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DEAUTH_IND(6) status 0 reason 7
[ 4819.814627] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DISASSOC_IND(12) status 0 reason 8
[ 4819.826166] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4822.077904] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 4826.092973] CFG80211-ERROR) wl_cfg80211_del_station :
[ 4826.097953] CFG80211-ERROR) wl_notify_connect_status_ap :
[ 4826.103446] event WLC_E_DEAUTH(5) status 0 reason 3
[ 4826.107173] Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4826.114351] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4826.125447] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4828.508538] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 4832.524480] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4832.535143] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4832.599898] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DEAUTH(5) status 0 reason 3
[ 4832.608796] CFG80211-ERROR) wl_notify_connect_status_ap :
[ 4832.609942] CFG80211-ERROR) wl_cfg80211_del_station :
[ 4832.609944] Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4832.623539] event WLC_E_DEAUTH(5) status 0 reason 3
[ 4835.014705] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 4839.038029] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4839.048802] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4839.159630] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DEAUTH(5) status 0 reason 3
[ 4839.168562] CFG80211-ERROR) wl_notify_connect_status_ap :
[ 4839.169699] CFG80211-ERROR) wl_cfg80211_del_station :
[ 4839.169701] Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4839.183308] event WLC_E_DEAUTH(5) status 0 reason 3
[ 4841.567532] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 4842.775460] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DEAUTH_IND(6) status 0 reason 1
[ 4842.784745] CFG80211-ERROR) wl_notify_connect_status_ap :
[ 4842.785879] CFG80211-ERROR) wl_cfg80211_del_station :
[ 4842.785881] Disconnect STA : 06:17:28:39:4a:5b scb_val.val 3
[ 4842.799377] event WLC_E_DISASSOC_IND(12) status 0 reason 8
[ 5423.151420] CFG80211-ERROR) wl_cfg80211_del_station :
[ 5423.152989] CFG80211-ERROR) wl_notify_connect_status_ap :
[ 5423.152992] event WLC_E_DEAUTH(5) status 0 reason 3
[ 5423.165313] Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5423.173146] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5423.183904] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5424.979710] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 5429.001534] CFG80211-ERROR) wl_cfg80211_del_station :
[ 5429.006619] CFG80211-ERROR) wl_notify_connect_status_ap :
[ 5429.006647] Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5429.008222] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5429.025810] event WLC_E_DEAUTH(5) status 0 reason 3
[ 5429.032120] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5430.812675] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 5434.833986] CFG80211-ERROR) wl_cfg80211_del_station :
[ 5434.834175] CFG80211-ERROR) wl_notify_connect_status_ap :
[ 5434.834177] event WLC_E_DEAUTH(5) status 0 reason 3
[ 5434.847889] Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5434.855464] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5434.866166] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5436.653244] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 5438.564616] CFG80211-ERROR) wl_notify_connect_status_ap : event WLC_E_DISASSOC_IND(12) status 0 reason 8
[ 5438.575378] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5440.513899] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 5444.535275] CFG80211-ERROR) wl_cfg80211_del_station :
[ 5444.535461] CFG80211-ERROR) wl_notify_connect_status_ap :
[ 5444.535464] event WLC_E_DEAUTH(5) status 0 reason 3
[ 5444.549128] Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5444.556666] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5444.567460] CFG80211-ERROR) wl_cfg80211_del_station : Disconnect STA : 00:11:22:33:44:66 scb_val.val 3
[ 5466.260455] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
[ 5470.281723] CFG80211-ERROR) wl_cfg80211_del_station :
[ 5470.281903] CFG80211-ERROR) wl_notify_connect_status_ap :
[ 5470.281906] event WLC_E_DEAUTH(5) status 0 reason 3
Any help is much appreciated.
