thanks
Hi Board serial #s (WiFi issue)
0324515042312
0324515042177
thanks
S/N: 0324415031878
thx Mohit.
S/N: 0324515042380
S/N: 0324515042253
I ran lswh on mine - the wlan0 section below indicates driverversion=0. that seems strange. also, I ran lspci on the unit and that returned nothing at all.
tegra-ubuntu
description: Computer
product: jetson_tx1
width: 32 bits
*-core
description: Motherboard
physical id: 0
capabilities: nvidia_jetson-cv nvidia_tegra210
*-cpu:0
description: CPU
product: cpu
physical id: 0
bus info: cpu@0
capacity: 1224MHz
capabilities: cpufreq
*-cpu:1 DISABLED
description: CPU
product: cpu
physical id: 1
bus info: cpu@1
capacity: 1224MHz
*-cpu:2 DISABLED
description: CPU
product: cpu
physical id: 2
bus info: cpu@2
capacity: 1224MHz
*-cpu:3 DISABLED
description: CPU
product: cpu
physical id: 3
bus info: cpu@3
capacity: 1224MHz
*-memory
description: System memory
physical id: 4
-network:0
description: Ethernet interface
physical id: 1
logical name: eth0
serial: 00:04:4b:57:f2:2d
capacity: 1Gbit/s
capabilities: ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v2.03.3 (2015/01/29) duplex=full ip=192.168.1.15 link=yes multicast=yes port=MII speed=1Gbit/s
[b]-network:1 DISABLED
description: Wireless interface
physical id: 2
logical name: wlan0
serial: 00:90:4c:11:22:33
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=wl driverversion=0 multicast=yes wireless=IEEE 802.11bg[/b]
*-network:2 DISABLED
physical id: 3
logical name: dummy0
serial: da:80:c7:b3:7c:58
If you haven’t enabled the wifi via nm-connection-editor it will show disabled.
Griz
Are you getting the ‘mmc1: Data CRC error’ from dmesg?
If you have the issue, you will see the following text repeating in kernel log:
[ 64.580357] Dongle Host Driver, version 1.201.82 (r)
[ 64.580357] Compiled in drivers/net/wireless/bcmdhd on Nov 9 2015 at 13:14:59
[ 64.580380] wl_android_wifi_on in
[ 64.580390] wifi_platform_set_power = 1
[ 64.865679] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 46
[ 64.867043] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[ 64.867749] F1 signature read @0x18000000=0x17214354
[ 64.883178] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 64.885441] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 64.961672] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 74.090447] dhd_bus_init: enable 0x06, ready 0x02 (waited 3006383us)
[ 74.092009] gpio wake8 for gpio=58
[ 74.092079] Enabling wake8
[ 74.093198] mmc1: Data CRC error, intmask: 200000 Interface clock = 204000000Hz
[ 74.100610] sdhci: ================== REGISTER DUMP (mmc1)==================
[ 74.107752] sdhci: Sys addr[0x000]: 0x00000000 | Version[0x0fe]: 0x00000303
[ 74.114879] sdhci: Blk size[0x004]: 0x00007080 | Blk cnt[0x006]: 0x00000000
[ 74.122006] sdhci: Argument[0x008]: 0xa5000080 | Trn mode[0x00c]: 0x00000003
[ 74.129127] sdhci: Present[0x024]: 0x01fb00f0 | Host ctl[0x028]: 0x00000013
[ 74.136248] sdhci: Power[0x029]: 0x0000000d | Blk gap[0x02a]: 0x00000000
[ 74.143369] sdhci: Wake-up[0x02b]: 0x00000000 | Clock[0x02c]: 0x00000007
[ 74.150488] sdhci: Timeout[0x02e]: 0x0000000e | Int stat[0x030]: 0x00000000
[ 74.157606] sdhci: Int enab[0x034]: 0x02ff000b | Sig enab[0x038]: 0x02fc000b
[ 74.164723] sdhci: AC12 err[0x03c]: 0x00000000 | Slot int[0x0fc]: 0x00000000
[ 74.171844] sdhci: Caps[0x040]: 0x376cd08c | Caps_1[0x044]: 0x10006f73
[ 74.178963] sdhci: Cmd[0x00e]: 0x0000353a | Max curr[0x048]: 0x00000000
[ 74.186088] sdhci: Host ctl2[0x03e]: 0x0000300b
[ 74.190698] sdhci: ADMA Err[0x054]: 0x00000000 | ADMA Ptr[0x058]: 0xe9500010
[ 74.197824] mmc1: tuning_window[0]: 0x0
[ 74.197885] mmc1: tuning_window[1]: 0x0
[ 74.197943] mmc1: tuning_window[2]: 0x0
[ 74.197998] mmc1: tuning_window[3]: 0x0
[ 74.198051] mmc1: tuning_window[4]: 0x0
[ 74.198105] mmc1: tuning_window[5]: 0x0
[ 74.198159] mmc1: tuning_window[6]: 0x0
[ 74.198213] mmc1: tuning_window[7]: 0x0
[ 74.198267] sdhci: Tap value: 46 | Trim value: 8
[ 74.198321] sdhci: SDMMC Interrupt status: 0x00040000
[ 74.198368] sdhci: =========================================================
[ 74.207266] dhd_bcmsdh_send_buf: sdio error -1, abort command and terminate frame.
[ 74.208977] dhdcdc_query_ioctl: dhdcdc_msg failed w/status -5
[ 74.209060] dhd_open : wl_android_wifi_on failed (-14)
[ 74.209263] mmc1: Data CRC error, intmask: 200000 Interface clock = 204000000Hz
[ 74.216608] sdhci: ================== REGISTER DUMP (mmc1)==================
[ 74.223690] sdhci: Sys addr[0x000]: 0x00000000 | Version[0x0fe]: 0x00000303
[ 74.230769] sdhci: Blk size[0x004]: 0x00007080 | Blk cnt[0x006]: 0x00000000
[ 74.237843] sdhci: Argument[0x008]: 0xa5000080 | Trn mode[0x00c]: 0x00000003
[ 74.244919] sdhci: Present[0x024]: 0x01fb00f0 | Host ctl[0x028]: 0x00000013
[ 74.251991] sdhci: Power[0x029]: 0x0000000d | Blk gap[0x02a]: 0x00000000
[ 74.259064] sdhci: Wake-up[0x02b]: 0x00000000 | Clock[0x02c]: 0x00000007
[ 74.266135] sdhci: Timeout[0x02e]: 0x0000000e | Int stat[0x030]: 0x00000000
[ 74.273208] sdhci: Int enab[0x034]: 0x02ff000b | Sig enab[0x038]: 0x02fc000b
[ 74.280282] sdhci: AC12 err[0x03c]: 0x00000000 | Slot int[0x0fc]: 0x00000000
[ 74.287357] sdhci: Caps[0x040]: 0x376cd08c | Caps_1[0x044]: 0x10006f73
[ 74.294433] sdhci: Cmd[0x00e]: 0x0000353a | Max curr[0x048]: 0x00000000
[ 74.301501] sdhci: Host ctl2[0x03e]: 0x0000300b
[ 74.306062] sdhci: ADMA Err[0x054]: 0x00000000 | ADMA Ptr[0x058]: 0xe9500010
[ 74.313141] mmc1: tuning_window[0]: 0x0
[ 74.313173] mmc1: tuning_window[1]: 0x0
[ 74.313205] mmc1: tuning_window[2]: 0x0
[ 74.313235] mmc1: tuning_window[3]: 0x0
[ 74.313263] mmc1: tuning_window[4]: 0x0
[ 74.313291] mmc1: tuning_window[5]: 0x0
[ 74.313319] mmc1: tuning_window[6]: 0x0
[ 74.313345] mmc1: tuning_window[7]: 0x0
[ 74.313372] sdhci: Tap value: 46 | Trim value: 8
[ 74.313400] sdhci: SDMMC Interrupt status: 0x00040000
[ 74.313422] sdhci: =========================================================
[ 74.321634] dhd_bcmsdh_send_buf: sdio error -1, abort command and terminate frame.
[ 74.321810] dhdcdc_query_ioctl: dhdcdc_msg failed w/status -5
[ 74.321827] CFGP2P-ERROR) wl_cfgp2p_bss_isup : 'cfg bss -C 0' failed: -5
[ 74.321836] CFGP2P-ERROR) wl_cfgp2p_bss_isup : NOTE: this ioctl error is normal when the BSS has not been created yet.
[ 74.321854] wl_android_wifi_off in
[ 74.321860] tegra_sysfs_off
[ 74.321935] mmc1: Data CRC error, intmask: 200000 Interface clock = 204000000Hz
[ 74.329239] sdhci: ================== REGISTER DUMP (mmc1)==================
[ 74.336279] sdhci: Sys addr[0x000]: 0x00000000 | Version[0x0fe]: 0x00000303
[ 74.343317] sdhci: Blk size[0x004]: 0x00007040 | Blk cnt[0x006]: 0x00000000
[ 74.350357] sdhci: Argument[0x008]: 0xa5000040 | Trn mode[0x00c]: 0x00000003
[ 74.357396] sdhci: Present[0x024]: 0x01fb00f0 | Host ctl[0x028]: 0x00000013
[ 74.364435] sdhci: Power[0x029]: 0x0000000d | Blk gap[0x02a]: 0x00000000
[ 74.371475] sdhci: Wake-up[0x02b]: 0x00000000 | Clock[0x02c]: 0x00000007
[ 74.378514] sdhci: Timeout[0x02e]: 0x0000000e | Int stat[0x030]: 0x00000000
[ 74.385554] sdhci: Int enab[0x034]: 0x02ff000b | Sig enab[0x038]: 0x02fc000b
[ 74.392592] sdhci: AC12 err[0x03c]: 0x00000000 | Slot int[0x0fc]: 0x00000000
[ 74.399632] sdhci: Caps[0x040]: 0x376cd08c | Caps_1[0x044]: 0x10006f73
[ 74.406671] sdhci: Cmd[0x00e]: 0x0000353a | Max curr[0x048]: 0x00000000
[ 74.413707] sdhci: Host ctl2[0x03e]: 0x0000300b
[ 74.418232] sdhci: ADMA Err[0x054]: 0x00000000 | ADMA Ptr[0x058]: 0xe9500010
[ 74.425274] mmc1: tuning_window[0]: 0x0
[ 74.425282] mmc1: tuning_window[1]: 0x0
[ 74.425290] mmc1: tuning_window[2]: 0x0
[ 74.425297] mmc1: tuning_window[3]: 0x0
[ 74.425304] mmc1: tuning_window[4]: 0x0
[ 74.425312] mmc1: tuning_window[5]: 0x0
[ 74.425319] mmc1: tuning_window[6]: 0x0
[ 74.425327] mmc1: tuning_window[7]: 0x0
[ 74.425332] sdhci: Tap value: 46 | Trim value: 8
[ 74.425338] sdhci: SDMMC Interrupt status: 0x00040000
[ 74.425342] sdhci: =========================================================
[ 74.432657] dhd_bcmsdh_send_buf: sdio error -1, abort command and terminate frame.
[ 74.432987] dhdcdc_set_ioctl: dhdcdc_msg failed w/status -5
[ 74.433429] gpio wake8 for gpio=58
[ 74.433436] Disabling wake8
[ 74.434859] wifi_platform_set_power = 0
The repeated attempts to power-up the WiFi, manifests lag in the system. Use these commands to disable until we issue the fix:
$ sudo mv /lib/firmware/brcm /lib/firmware/brcm_
$ sudo reboot
If you get the ‘mmc1: Data CRC error’ spew and haven’t yet posted your S/N, please post your S/N here.
If you already posted your S/N but don’t get the errors, please confirm.
I’m getting the ‘mmc1: Data CRC error’ S/N: 0324515042253.
Disabling the repeated attempts to power-up the WiFi as suggested has stopped the noticeable lag on the TX1.
Any ETA on when we can expect a fix?
Cheers
Mark
We are planning for next week, will keep you guys informed. Apologies for the inconvenience and thanks again for your continued patience.
Hats off to the community for assisting with the issue!
I have the Data CRC error.
My serial is 032441505885
I also do not have WiFi as well as no Bluetooth capability. I did not have it out of the box or after installing JetPack 2.0
S/N:0324415050408
Device: wlan0 ----------------------------------------------------------------
Type: 802.11 WiFi
Driver: bcmsdh_sdmmc
State: unavailable
Default: no
HW Address: 00:90:4C:11:22:33Capabilities:
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
WPA2 Encryption: yesWireless Access Points
Thanks for reporting. We will be in touch in the next few days with the resolution.
It sounds like you are experiencing the issue too, you get the repeating Data CRC error from dmesg too? Aside from the symptom of WiFi not powering up, the dmesg kernel log may contain repeating “mmc1: Data CRC error” followed by register dump. Below is the full block of repeating output.
[ 74.639708]
[ 74.639708] Dongle Host Driver, version 1.201.82 (r)
[ 74.639708] Compiled in drivers/net/wireless/bcmdhd on Nov 9 2015 at 13:14:59
[ 74.639728] wl_android_wifi_on in
[ 74.639737] wifi_platform_set_power = 1
[ 74.926391] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 46
[ 74.927760] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[ 74.928477] F1 signature read @0x18000000=0x17214354
[ 74.944355] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 74.946643] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 75.022733] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 84.158888] dhd_bus_init: enable 0x06, ready 0x02 (waited 3006383us)
[ 84.159260] gpio wake8 for gpio=58
[ 84.159265] Enabling wake8
[ 84.159417] mmc1: Data CRC error, intmask: 200000 Interface clock = 204000000Hz
[ 84.166714] sdhci: ================== REGISTER DUMP (mmc1)==================
[ 84.173751] sdhci: Sys addr[0x000]: 0x00000000 | Version[0x0fe]: 0x00000303
[ 84.180788] sdhci: Blk size[0x004]: 0x00007080 | Blk cnt[0x006]: 0x00000000
[ 84.187823] sdhci: Argument[0x008]: 0xa5000080 | Trn mode[0x00c]: 0x00000003
[ 84.194858] sdhci: Present[0x024]: 0x01fb00f0 | Host ctl[0x028]: 0x00000013
[ 84.201893] sdhci: Power[0x029]: 0x0000000d | Blk gap[0x02a]: 0x00000000
[ 84.208927] sdhci: Wake-up[0x02b]: 0x00000000 | Clock[0x02c]: 0x00000007
[ 84.215963] sdhci: Timeout[0x02e]: 0x0000000e | Int stat[0x030]: 0x00000000
[ 84.222997] sdhci: Int enab[0x034]: 0x02ff000b | Sig enab[0x038]: 0x02fc000b
[ 84.230033] sdhci: AC12 err[0x03c]: 0x00000000 | Slot int[0x0fc]: 0x00000000
[ 84.237067] sdhci: Caps[0x040]: 0x376cd08c | Caps_1[0x044]: 0x10006f73
[ 84.244101] sdhci: Cmd[0x00e]: 0x0000353a | Max curr[0x048]: 0x00000000
[ 84.251134] sdhci: Host ctl2[0x03e]: 0x0000300b
[ 84.255656] sdhci: ADMA Err[0x054]: 0x00000000 | ADMA Ptr[0x058]: 0xe9500010
[ 84.262694] mmc1: tuning_window[0]: 0x0
[ 84.262700] mmc1: tuning_window[1]: 0x0
[ 84.262706] mmc1: tuning_window[2]: 0x0
[ 84.262712] mmc1: tuning_window[3]: 0x0
[ 84.262718] mmc1: tuning_window[4]: 0x0
[ 84.262724] mmc1: tuning_window[5]: 0x0
[ 84.262730] mmc1: tuning_window[6]: 0x0
[ 84.262736] mmc1: tuning_window[7]: 0x0
[ 84.262740] sdhci: Tap value: 46 | Trim value: 8
[ 84.262744] sdhci: SDMMC Interrupt status: 0x00040000
[ 84.262747] sdhci: =========================================================
[ 84.269963] dhd_bcmsdh_send_buf: sdio error -1, abort command and terminate frame.
[ 84.270215] dhdcdc_query_ioctl: dhdcdc_msg failed w/status -5
[ 84.270227] dhd_open : wl_android_wifi_on failed (-14)
[ 84.270272] mmc1: Data CRC error, intmask: 200000 Interface clock = 204000000Hz
[ 84.277570] sdhci: ================== REGISTER DUMP (mmc1)==================
[ 84.284608] sdhci: Sys addr[0x000]: 0x00000000 | Version[0x0fe]: 0x00000303
[ 84.291643] sdhci: Blk size[0x004]: 0x00007080 | Blk cnt[0x006]: 0x00000000
[ 84.298679] sdhci: Argument[0x008]: 0xa5000080 | Trn mode[0x00c]: 0x00000003
[ 84.305715] sdhci: Present[0x024]: 0x01fb00f0 | Host ctl[0x028]: 0x00000013
[ 84.312751] sdhci: Power[0x029]: 0x0000000d | Blk gap[0x02a]: 0x00000000
[ 84.319787] sdhci: Wake-up[0x02b]: 0x00000000 | Clock[0x02c]: 0x00000007
[ 84.326822] sdhci: Timeout[0x02e]: 0x0000000e | Int stat[0x030]: 0x00000000
[ 84.333857] sdhci: Int enab[0x034]: 0x02ff000b | Sig enab[0x038]: 0x02fc000b
[ 84.340892] sdhci: AC12 err[0x03c]: 0x00000000 | Slot int[0x0fc]: 0x00000000
[ 84.347928] sdhci: Caps[0x040]: 0x376cd08c | Caps_1[0x044]: 0x10006f73
[ 84.354963] sdhci: Cmd[0x00e]: 0x0000353a | Max curr[0x048]: 0x00000000
[ 84.361996] sdhci: Host ctl2[0x03e]: 0x0000300b
[ 84.366517] sdhci: ADMA Err[0x054]: 0x00000000 | ADMA Ptr[0x058]: 0xe9500010
[ 84.373554] mmc1: tuning_window[0]: 0x0
[ 84.373560] mmc1: tuning_window[1]: 0x0
[ 84.373566] mmc1: tuning_window[2]: 0x0
[ 84.373572] mmc1: tuning_window[3]: 0x0
[ 84.373578] mmc1: tuning_window[4]: 0x0
[ 84.373584] mmc1: tuning_window[5]: 0x0
[ 84.373590] mmc1: tuning_window[6]: 0x0
[ 84.373596] mmc1: tuning_window[7]: 0x0
[ 84.373600] sdhci: Tap value: 46 | Trim value: 8
[ 84.373604] sdhci: SDMMC Interrupt status: 0x00040000
[ 84.373606] sdhci: =========================================================
[ 84.380799] dhd_bcmsdh_send_buf: sdio error -1, abort command and terminate frame.
[ 84.381139] dhdcdc_query_ioctl: dhdcdc_msg failed w/status -5
[ 84.381149] CFGP2P-ERROR) wl_cfgp2p_bss_isup : 'cfg bss -C 0' failed: -5
[ 84.381154] CFGP2P-ERROR) wl_cfgp2p_bss_isup : NOTE: this ioctl error is normal when the BSS has not been created yet.
[ 84.381165] wl_android_wifi_off in
[ 84.381170] tegra_sysfs_off
[ 84.381212] mmc1: Data CRC error, intmask: 200000 Interface clock = 204000000Hz
[ 84.388509] sdhci: ================== REGISTER DUMP (mmc1)==================
[ 84.395545] sdhci: Sys addr[0x000]: 0x00000000 | Version[0x0fe]: 0x00000303
[ 84.402580] sdhci: Blk size[0x004]: 0x00007040 | Blk cnt[0x006]: 0x00000000
[ 84.409616] sdhci: Argument[0x008]: 0xa5000040 | Trn mode[0x00c]: 0x00000003
[ 84.416652] sdhci: Present[0x024]: 0x01fb00f0 | Host ctl[0x028]: 0x00000013
[ 84.423688] sdhci: Power[0x029]: 0x0000000d | Blk gap[0x02a]: 0x00000000
[ 84.430724] sdhci: Wake-up[0x02b]: 0x00000000 | Clock[0x02c]: 0x00000007
[ 84.437758] sdhci: Timeout[0x02e]: 0x0000000e | Int stat[0x030]: 0x00000000
[ 84.444793] sdhci: Int enab[0x034]: 0x02ff000b | Sig enab[0x038]: 0x02fc000b
[ 84.451828] sdhci: AC12 err[0x03c]: 0x00000000 | Slot int[0x0fc]: 0x00000000
[ 84.458863] sdhci: Caps[0x040]: 0x376cd08c | Caps_1[0x044]: 0x10006f73
[ 84.465898] sdhci: Cmd[0x00e]: 0x0000353a | Max curr[0x048]: 0x00000000
[ 84.472931] sdhci: Host ctl2[0x03e]: 0x0000300b
[ 84.477452] sdhci: ADMA Err[0x054]: 0x00000000 | ADMA Ptr[0x058]: 0xe9500010
[ 84.484489] mmc1: tuning_window[0]: 0x0
[ 84.484495] mmc1: tuning_window[1]: 0x0
[ 84.484501] mmc1: tuning_window[2]: 0x0
[ 84.484507] mmc1: tuning_window[3]: 0x0
[ 84.484513] mmc1: tuning_window[4]: 0x0
[ 84.484519] mmc1: tuning_window[5]: 0x0
[ 84.484525] mmc1: tuning_window[6]: 0x0
[ 84.484531] mmc1: tuning_window[7]: 0x0
[ 84.484535] sdhci: Tap value: 46 | Trim value: 8
[ 84.484540] sdhci: SDMMC Interrupt status: 0x00040000
[ 84.484542] sdhci: =========================================================
[ 84.491690] dhd_bcmsdh_send_buf: sdio error -1, abort command and terminate frame.
[ 84.491997] dhdcdc_set_ioctl: dhdcdc_msg failed w/status -5
[ 84.492355] gpio wake8 for gpio=58
[ 84.492360] Disabling wake8
[ 84.493611] wifi_platform_set_power = 0
Also have the wlan0 “unavailable” problem. S/N 0324415051173
Also have the wlan0 “unavailable” problem. S/N 0324415032133
Rick
S/N 0324515042002
I am also having the issue however I ran the wifi-config-check script and it said it was inconclusive.
S/N 0333615050282 in the script (both) and
S/N 0333715040121 on the stick on the base board.
Hi BlackOpsCoder,
What the message you saw by running the wifi-config-check script?
We are also having the same issue.
S/N: 0324515042014
The sudo mv /lib/firmware/brcm /lib/firmware/brcm_
did work as a temporary fix, obviously wifi doesn’t work now, but we can at least use terminal now.
Please go to https://developer.nvidia.com/embedded/support to download and run the wifi-config-check tool to find out whether you need to request a replacement developer kit via the RMA Process. During the RMA, they will send you a replacement Jetson TX1 devkit in advance.
