Wireless problem
we have a Jetson Thor system which loses wireless network every now and then (my ssh connection gets dropped but in 10s or so I can connect again). The kernel log is full of “_cmd_abort_notify(570)vv abort=1” (over 320 messages for two days uptime). I did a quick search, and it seems that _cmd_abort_notify is defined in NVIDIA’s own code in nvidia-oot/drivers/net/wireless/realtek/rtl8852ce/phl/phl_cmd_scan.c. What is going on and how to fix it?
$ cat /etc/nv_tegra_release
# R39 (release), REVISION: 2.1, GCID: 46758480, BOARD: generic, EABI: aarch64, DATE: Fri Aug  7 05:54:22 AM UTC 2026
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia_kernel_display_driver_source
Just to add some details, this is how we installed software on our Jetson Thor:
  1. Put it Forced Recovery Mode
  2. Unpacked Jetson_Linux_R39.2.1_aarch64.tbz2 and Tegra_Linux_Sample-Root-Filesystem_R39.2.1_aarch64.tbz2 on an Intel PC under Ubuntu 24.04
  3. Connected this PC to the Jetson via USB
  4. Ran “sudo ./l4t_initrd_flash.sh --erase-all jetson-agx-thor-devkit internal”
  5. Rebooted Jetson
  6. After reboot, ran “sudo apt update” and “sudo apt install nvidia-jetpack”
After tar and before flash did you run
sudo ./apply_binaries --openrm
You could try some of following
sudo rm -f /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
sudo tee /etc/NetworkManager/conf.d/99-wifi-powersave-off.conf >/dev/null <<'EOF'
[connection]
wifi.powersave = 2
EOF
| Value | Meaning                                  |
|   `0` | Default                                  |
|   `1` | Ignore / leave current setting unchanged |
|   `2` | **Disable Wi-Fi power saving**           |
|   `3` | **Enable Wi-Fi power saving**            |
CON="yourSSID"
sudo nmcli connection modify "$CON" \
    connection.autoconnect yes \
    connection.autoconnect-retries 0 \
    connection.autoconnect-priority 100 \
    802-11-wireless.powersave 2
sudo systemctl reload NetworkManager
# connection.autoconnect-retries 0 means retry forever. The normal default is -1, which uses NetworkManager's global default
# of four attempts before giving up for a time period.
On computer you are ssh from, edit to add these and change thor/ip to your values of Thor to ssh to.
~/.ssh/config
Host thor
    HostName 192.168.1.60
    User thor
    ServerAliveInterval 10
    ServerA
    liveCountMax 3
    TCPKeepAlive yes
    ConnectTimeout 5
    ConnectionAttempts 3
You could use: sudo apt install tmux
Then whenever you SSH in:
tmux new -A -s thor
# That creates session thor if it doesn't exist
# attach to thor if it already exists
Or
sudo apt install autossh
AUTOSSH_GATETIME=0 autossh -M 0 \
    -o ServerAliveInterval=10 \
    -o ServerAliveCountMax=3 \
    -o ConnectTimeout=5 \
    -t thor 'tmux new -A -s thor'
or apt show mosh
Mosh is a remote terminal application that supports:
  • intermittent network connectivity,
  • roaming to different IP address without dropping the connection, and
  • intelligent local echo and line editing to reduce the effects
    of “network lag” on high-latency connections.
No, we did not run “sudo ./apply_binaries --openrm”.
In the section "To Flash the Jetson Developer Kit Operating Software" it says to run
sudo ./apply_binaries.sh
AFTER “sudo ./tools/l4t_flash_prerequisites.sh”
Which way is correct ?
Also, it should be run on the PC, correct ?
My apologies, you are correct. Now, I remember a post by Nvidia that said --openrm is no longer required in Jetpack 7.2.{1}. I just ran sudo ./apply_binaries.sh and it did install the openrm debians.
Thanks whitescott. Do you think we should rerun our installation (does not take long time from a host PC) with “sudo ./apply_binaries.sh” and see if it fixes the problem, or should we try your other suggestions to fix the network problem without reinstallation ?
If you are at a point where you can flash and not lose work you may want to do that.
We will set up Thor developer kit in Jetpack 7.2.1 r39,.2.1 and try to replicate the issue. Would be great if you can share your dmesg or uart log for reference.
For r39.2 and r39.2.1, it is not obligatory to have –openrm, as noted in
Quick Start — NVIDIA Jetson Linux Developer Guide
We test on Thor developer kit and the WIFI connection is stable. If you use developer kit, please re-flash it and try again. If the issue persists, please share step-by-step method. We can follow it and test again on developer kit.
