With lt6911c Orin N custom board, only the green screen can be captured
  1. Looks like the the NX_no2 get 3 frames then hit the “PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110” and failed after that.
    The message tell the FIFO overloaded. Maybe confirm by boost the clocks by previous comment.
  2. Both of the device have CHANSEL_NOMATCH that could be the sensor output embedded data but device tree didn’t define correctly or sensor output some user define data cause that.
Hi ShaneCCC,
Sorry, the reply is a little late. Both of our Orin nx modules are broken. Boot failed - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
We can’t test until new module arrives. There may be some delay in feedback on progress after that.
Hi @h1994213,
I am not sure if one needs to flash the firmware to the lt6911 on a brand new board. The bridge could be flashed separately using the I2C interface with a HW tool to connect the chip to the PC on which there’s SW tool running.
Alternatively, I am not sure if the driver of lt6911 could also handle the firmware flashing/update itself like this : Debian Sid Gnome does not boot into Desktop - #2 by l4es - Qualcomm RB5 - 96Boards Forum
The firmware and tool for the lt6911 can be downloaded (for registered users of course) : DOWNLOADS_Lontium
Regards,
Khang
Hi khang.l4es
I have burned the firmware to the lt6911 and have been able to capture the video.
The current problem is that one of the core boards, Orin_NX_no2, does not work properly.
Hi ShaneCCC
We have purchased a new core board (Orin_NX_no3) which can also capture video properly. I’m inclined to think that Orin_NX_no2 CSI or VI is problematic. We have other new core boards that have not arrived yet, and I will give feedback on the new test situation here.
Hi ShaneCCC,
We got a new Orin nx core board (Orin_NX_no4), and after running gst-launch-1.0 for a while, we had the same problem as the no2 core board.
When I flash the camera firmware here GMSL Camera fail on Orin Nano JatPack 5.1.2 - #5 by JerryChang https://forums.developer.nvidia.com/uploads/short-url/l8htccw4ZwK182puK6J0067EtUU.7z , the no4 module worked very stable. But when I flash this firmware to the no3 core board, no3 could not capture the video.
Where can I get these different versions of firmware? Is the camera firmware open source?
It’s not open source.
It’s better to check by imx219/imx477 reference sensor to confirm if modules problem.
please moving forward to the latest JetPack 5.1.3 public release version for verification.
Hi JerryChang,
When I used JetPack5.1.3, the no4 module was able to capture the video correctly, but the no3 preview video would get stuck.
The no3 module tracking logs are as follows:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.192-tegra (hyq@hyq-HP) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Mon Mar 4 14:26:47 CST 2024
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: NVIDIA Orin NX Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x2661b1a18 SMBIOS=0xffff0000 SMBIOS 3.0=0x26a1b0000 MEMATTR=0x264979018 ESRT=0x26497a298 RNG=0x258350018 MEMRESERVE=0x258cc4f18
[    0.000000] random: crng init done
[    0.000000] esrt: Reserving ESRT space from 0x000000026497a298 to 0x000000026497a2d0.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000248000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000273ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000025b004fff]
[    0.000000]   node   0: [mem 0x000000025b005000-0x000000025b31bfff]
[    0.000000]   node   0: [mem 0x000000025b31c000-0x00000002687fffff]
[    0.000000]   node   0: [mem 0x0000000268800000-0x000000026a73ffff]
[    0.000000]   node   0: [mem 0x000000026a740000-0x000000026eb0ffff]
[    0.000000]   node   0: [mem 0x000000026eb10000-0x000000026eb1ffff]
[    0.000000]   node   0: [mem 0x0000000272000000-0x0000000273ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000273ffffff]
[    0.000000] On node 0 totalpages: 2034464
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524288 pages, LIFO batch:63
[    0.000000]   Normal zone: 23808 pages used for memmap
[    0.000000]   Normal zone: 1510176 pages, LIFO batch:63
[    0.000000] On node 0, zone Normal: 224 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[    0.000000] pcpu-alloc: s90392 r8192 d32488 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2002464
[    0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 7352164K/8137856K available (18816K kernel code, 3462K rwdata, 7692K rodata, 4480K init, 1415K bss, 523548K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000662] Console: colour dummy device 80x25
[    0.000701] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000709] pid_max: default: 32768 minimum: 301
[    0.000759] LSM: Security Framework initializing
[    0.000782] Yama: becoming mindful.
[    0.000799] SELinux:  Initializing.
[    0.000854] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000867] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.001875] rcu: Hierarchical SRCU implementation.
[    0.002705] DTS File Name: /home/hyq/nvidia/l4t-sources/orin_nx/JP5.1.3/Linux_for_Tegra/source/public/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0001-p3768-0000-a0.dts
[    0.002711] DTB Build time: Mar  4 2024 14:21:24
[    0.003993] Tegra Revision: A01 SKU: 0xd4 CPU Process: 0 SoC Process: 0
[    0.004149] Remapping and enabling EFI services.
[    0.004968] smp: Bringing up secondary CPUs ...
[    0.033659] Detected PIPT I-cache on CPU1
[    0.033692] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.033722] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.062357] Detected PIPT I-cache on CPU2
[    0.062367] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.062383] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.090974] Detected PIPT I-cache on CPU3
[    0.090983] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.090997] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.121634] Detected PIPT I-cache on CPU4
[    0.121655] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.121681] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.150336] Detected PIPT I-cache on CPU5
[    0.150346] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.150360] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.150416] smp: Brought up 1 node, 6 CPUs
[    0.150427] SMP: Total of 6 processors activated.
[    0.150430] CPU features: detected: Privileged Access Never
[    0.150431] CPU features: detected: LSE atomic instructions
[    0.150433] CPU features: detected: User Access Override
[    0.150434] CPU features: detected: 32-bit EL0 Support
[    0.150437] CPU features: detected: Common not Private translations
[    0.150438] CPU features: detected: RAS Extension Support
[    0.150439] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.150441] CPU features: detected: CRC32 instructions
[    0.150442] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.167420] spectre-bhb mitigation disabled by command line option
[    0.182670] CPU: All CPU(s) started at EL2
[    0.184370] devtmpfs: initialized
[    0.198912] Registered cp15_barrier emulation handler
[    0.198919] Registered setend emulation handler
[    0.198925] KASLR enabled
[    0.199053] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.199065] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.200496] pinctrl core: initialized pinctrl subsystem
[    0.200788] regulator-dummy: no parameters, enabled
[    0.201172] NET: Registered protocol family 16
[    0.201849] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.201910] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.201961] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.201986] audit: initializing netlink subsys (disabled)
[    0.202050] audit: type=2000 audit(0.200:1): state=initialized audit_enabled=0 res=1
[    0.202266] thermal_sys: Registered thermal governor 'step_wise'
[    0.202269] thermal_sys: Registered thermal governor 'power_allocator'
[    0.202272] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.203091] cpuidle: using governor menu
[    0.203201] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.203260] ASID allocator initialised with 32768 entries
[    0.203340] Serial: AMBA PL011 UART driver
[    0.205039] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.205057] Tegra reboot handler registered.
[    0.222404] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x2c10000
[    0.222415] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x2c20000
[    0.222421] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x2c30000
[    0.222428] mc: mapped MMIO address: 0xffff800010810000 -> 0x2c40000
[    0.222434] mc: mapped MMIO address: 0xffff800010830000 -> 0x2c50000
[    0.222440] mc: mapped MMIO address: 0xffff800010850000 -> 0x2b80000
[    0.222445] mc: mapped MMIO address: 0xffff800010870000 -> 0x2b90000
[    0.222450] mc: mapped MMIO address: 0xffff800010890000 -> 0x2ba0000
[    0.222456] mc: mapped MMIO address: 0xffff8000108b0000 -> 0x2bb0000
[    0.222461] mc: mapped MMIO address: 0xffff8000108d0000 -> 0x1700000
[    0.222466] mc: mapped MMIO address: 0xffff8000108f0000 -> 0x1710000
[    0.222471] mc: mapped MMIO address: 0xffff800010910000 -> 0x1720000
[    0.222476] mc: mapped MMIO address: 0xffff800010930000 -> 0x1730000
[    0.222481] mc: mapped MMIO address: 0xffff800010950000 -> 0x1740000
[    0.222485] mc: mapped MMIO address: 0xffff800010970000 -> 0x1750000
[    0.222490] mc: mapped MMIO address: 0xffff800010990000 -> 0x1760000
[    0.222497] mc: mapped MMIO address: 0xffff8000109b0000 -> 0x1770000
[    0.222506] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.222529] mc-err: mcerr ops are set to t23x
[    0.223198] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[    1.183836] printk: console [ttyAMA0] enabled
[    1.191905] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    1.198614] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    1.205315] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    1.212011] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.220062] ACPI: Interpreter disabled.
[    1.224061] vdd-soc: 1200 mV, enabled
[    1.227800] vdd-cpu-gpu: 1200 mV, enabled
[    1.231872] vdd-5v: 5000 mV, enabled
[    1.235511] sys-vdd-1v8: 1800 mV, enabled
[    1.239584] ddr-vddq: supplied by vdd-5v
[    1.243528] ddr-vddq: 500 mV, enabled
[    1.247312] ddr-vdd2: supplied by vdd-5v
[    1.251250] ddr-vdd2: 1050 mV, enabled
[    1.255083] vdd-AO-1v2: supplied by vdd-5v
[    1.259210] vdd-AO-1v2: 1200 mV, enabled
[    1.263211] vdd-3v3: supplied by vdd-5v
[    1.267059] vdd-3v3: 3300 mV, enabled
[    1.270826] vdd-rtc: supplied by vdd-AO-1v2
[    1.275021] vdd-rtc: 750 mV, enabled
[    1.278684] vdd-0v95-uphy: supplied by vdd-AO-1v2
[    1.283403] vdd-0v95-uphy: 950 mV, enabled
[    1.287579] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[    1.292294] vdd-0v95-hdmi: 950 mV, enabled
[    1.296485] vdd-5v-sys: 5000 mV, enabled
[    1.300460] vdd-3v3-sys: 3300 mV, enabled
[    1.304536] vdd-1v8: supplied by vdd-3v3-sys
[    1.308817] vdd-1v8: 1800 mV, enabled
[    1.312632] vdd-3v3-AO: supplied by vdd-5v-sys
[    1.317089] vdd-3v3-AO: 3300 mV, enabled
[    1.321093] vdd-av10-hub: supplied by vdd-5v-sys
[    1.325733] vdd-av10-hub: 1100 mV, enabled
[    1.329908] vdd-vbus-a: supplied by vdd-5v-sys
[    1.334368] vdd-vbus-a: 5000 mV, enabled
[    1.338367] vdd-vbus-b: supplied by vdd-5v-sys
[    1.342820] vdd-vbus-b: 5000 mV, enabled
[    1.346830] vdd-3v3-dp: supplied by vdd-3v3-sys
[    1.351372] vdd-3v3-dp: 3300 mV, enabled
[    1.355555] iommu: Default domain type: Translated
[    1.360467] eventlib_kernel: keventlib is initialized, test id: 0
[    1.366745] SCSI subsystem initialized
[    1.370569] usbcore: registered new interface driver usbfs
[    1.376063] usbcore: registered new interface driver hub
[    1.381380] usbcore: registered new device driver usb
[    1.386601] mc: Linux media interface: v0.10
[    1.390876] videodev: Linux video capture interface: v2.00
[    1.396494] pps_core: LinuxPPS API ver. 1 registered
[    1.401456] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.410590] PTP clock support registered
[    1.414710] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    1.421864] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    1.429475] Registered efivars operations
[    1.433947] FPGA manager framework
[    1.437367] Advanced Linux Sound Architecture Driver Initialized.
[    1.443716] Bluetooth: Core ver 2.22
[    1.447295] NET: Registered protocol family 31
[    1.451736] Bluetooth: HCI device and connection manager initialized
[    1.458092] Bluetooth: HCI socket layer initialized
[    1.462968] Bluetooth: L2CAP socket layer initialized
[    1.468019] Bluetooth: SCO socket layer initialized
[    1.473356] camchar: rtcpu character device driver loaded
[    1.478956] clocksource: Switched to clocksource arch_sys_counter
[    1.639106] VFS: Disk quotas dquot_6.6.0
[    1.643076] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.650573] pnp: PnP ACPI: disabled
[    1.655942] la/ptsa driver initialized.
[    1.659840] NET: Registered protocol family 2
[    1.664328] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    1.673118] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    1.681662] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.689640] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    1.697538] TCP: Hash tables configured (established 65536 bind 65536)
[    1.704140] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.710947] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.718246] NET: Registered protocol family 1
[    1.722761] RPC: Registered named UNIX socket transport module.
[    1.728690] RPC: Registered udp transport module.
[    1.733391] RPC: Registered tcp transport module.
[    1.738091] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.744534] PCI: CLS 0 bytes, default 64
[    1.748556] Trying to unpack rootfs image as initramfs...
[    1.882224] Freeing initrd memory: 9548K
[    1.888205] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.896179] kvm [1]: IPA Size Limit: 48 bits
[    1.900471] kvm [1]: GICv3: no GICV resource entry
[    1.905262] kvm [1]: disabling GICv2 emulation
[    1.909720] kvm [1]: GIC system register CPU interface enabled
[    1.915614] kvm [1]: vgic interrupt IRQ9
[    1.919634] kvm [1]: VHE mode initialized successfully
[    1.925450] Initialise system trusted keyrings
[    1.930003] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    1.938579] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.944697] NFS: Registering the id_resolver key type
[    1.949762] Key type id_resolver registered
[    1.953941] Key type id_legacy registered
[    1.957982] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.964689] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.972094] ntfs: driver 2.1.32 [Flags: R/W].
[    1.988061] NET: Registered protocol family 38
[    1.992506] Key type asymmetric registered
[    1.996600] Asymmetric key parser 'x509' registered
[    2.001494] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    2.008938] io scheduler mq-deadline registered
[    2.013469] io scheduler kyber registered
[    2.021016] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    2.026616] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    2.032200] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    2.037782] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    2.044100] efifb: probing for efifb
[    2.047708] efifb: framebuffer at 0x279e00000, using 8640k, total 8640k
[    2.054321] efifb: mode is 1920x1080x32, linelength=8192, pages=1
[    2.060411] efifb: scrolling: redraw
[    2.063983] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    2.072513] Console: switching to colour frame buffer device 240x67
[    2.081495] fb0: EFI VGA frame buffer device
[    2.087419] tegra_dc_assign_hw_data: no matching compatible node
[    2.093424] tegradccommon module_init failed
[    2.097690] tegradc module_init failed
[    2.101675] EINJ: ACPI disabled.
[    2.106397] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    2.113276] tegra-pmc: ### PMC reset source: SYS_RESET_N
[    2.118585] tegra-pmc: ### PMC reset level: L0
[    2.123024] tegra-pmc: ### PMC reset status reg: 0x0
[    2.129307] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    3.637018] printk: console [ttyTCU0] enabled
[    3.642023] arm-smmu 12000000.iommu: probing hardware configuration...
[    3.648720] arm-smmu 12000000.iommu: SMMUv2 with:
[    3.653560] arm-smmu 12000000.iommu:         stage 1 translation
[    3.659130] arm-smmu 12000000.iommu:         stage 2 translation
[    3.664679] arm-smmu 12000000.iommu:         nested translation
[    3.670135] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    3.677540] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    3.686385] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    3.693086] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    3.699781] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    3.707269] arm-smmu 10000000.iommu: probing hardware configuration...
[    3.713973] arm-smmu 10000000.iommu: SMMUv2 with:
[    3.718795] arm-smmu 10000000.iommu:         stage 1 translation
[    3.724330] arm-smmu 10000000.iommu:         stage 2 translation
[    3.729875] arm-smmu 10000000.iommu:         nested translation
[    3.735326] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    3.742735] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    3.751590] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    3.758282] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    3.764969] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    3.772080] arm-smmu 8000000.iommu: probing hardware configuration...
[    3.778690] arm-smmu 8000000.iommu: SMMUv2 with:
[    3.783418] arm-smmu 8000000.iommu:  stage 1 translation
[    3.788869] arm-smmu 8000000.iommu:  stage 2 translation
[    3.794309] arm-smmu 8000000.iommu:  nested translation
[    3.799657] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    3.806983] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    3.815699] arm-smmu 8000000.iommu:  Supported page sizes: 0x00001000
[    3.822307] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    3.828910] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    3.836256] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    3.846041] tegra_profiler: version: 1.151, samples/io: 51/30
[    3.852001] tegra_profiler: auth: init
[    3.856154] nvsciipc: loaded module
[    3.861234] tun: Universal TUN/TAP device driver, 1.6
[    3.866836] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    3.874254] hns3: Copyright (c) 2017 Huawei Corporation.
[    3.879738] e1000e: Intel(R) PRO/1000 Network Driver
[    3.884842] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.890920] igb: Intel(R) Gigabit Ethernet Network Driver
[    3.896464] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.902323] PPP generic driver version 2.4.2
[    3.906752] PPP BSD Compression module registered
[    3.911576] PPP Deflate Compression module registered
[    3.916777] PPP MPPE Compression module registered
[    3.921711] usbcore: registered new interface driver r8152
[    3.927345] usbcore: registered new interface driver asix
[    3.932909] usbcore: registered new interface driver ax88179_178a
[    3.939179] usbcore: registered new interface driver cdc_ether
[    3.945168] usbcore: registered new interface driver net1080
[    3.950978] usbcore: registered new interface driver cdc_subset
[    3.957061] usbcore: registered new interface driver zaurus
[    3.962792] usbcore: registered new interface driver cdc_ncm
[    3.968602] usbcore: registered new interface driver aqc111
[    3.974435] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.980780] ohci-pci: OHCI PCI platform driver
[    3.985371] ohci-platform: OHCI generic platform driver
[    3.991019] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    3.997337] usbcore: registered new interface driver uas
[    4.002817] usbcore: registered new interface driver usb-storage
[    4.009125] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    4.015183] mousedev: PS/2 mouse device common for all mice
[    4.020925] usbcore: registered new interface driver xpad
[    4.028342] tegra_rtc c2a0000.rtc: registered as rtc1
[    4.033799] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:28 UTC (28)
[    4.042023] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    4.048434] i2c /dev entries driver
[    4.052131] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    4.057907] tegra-i2c c240000.i2c: Adding to iommu group 2
[    4.063599] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    4.069261] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    4.074934] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    4.080609] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    4.086277] tegra-i2c c250000.i2c: Adding to iommu group 2
[    4.091939] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    4.100233] pps pps0: new PPS source ktimer
[    4.104537] pps pps0: ktimer PPS source registered
[    4.109456] pps_ldisc: PPS line discipline registered
[    4.115450] device-mapper: uevent: version 1.0.3
[    4.120274] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    4.129861] sdhci: Secure Digital Host Controller Interface driver
[    4.136199] sdhci: Copyright(c) Pierre Ossman
[    4.140673] Synopsys Designware Multimedia Card Interface Driver
[    4.146903] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.153353] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    4.161029] tegra-bpmp bpmp: firmware: a5fd653d3815177549cc-fcc6f4f897a
[    4.169862] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    4.175704] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[    4.189766] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    4.195703] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[    5.543782] hid: raw HID events driver (C) Jiri Kosina
[    5.549756] usbcore: registered new interface driver usbhid
[    5.555492] usbhid: USB HID core driver
[    5.559934] tegra-dce d800000.dce: Adding to iommu group 3
[    5.567468] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    5.576372] tegra234-aon c000000.aon: Adding to iommu group 4
[    5.582845] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    5.583779]  c000000.aon:hsp: probed
[    5.591811] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [0]. Ignored...
[    5.604260] tegra234-aon c000000.aon: init done
[    5.604597] tegra23x-psc e860000.psc: Adding to iommu group 5
[    5.608945] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    5.615113] tegra23x-psc e860000.psc: ext_cfg base:0000000066a3d087
[    5.622116] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    5.628196] tegra23x-psc e860000.psc: init done
[    5.628346] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 6
[    5.637150] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    5.637152] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    5.637162] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    5.642616] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    5.648422] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    5.648998] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    5.660418] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    5.665631] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    5.665632] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    5.665641] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    5.674492] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    5.683328] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    5.690433] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    5.762492] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    5.774566] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    5.787143] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    5.799964] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    5.812429] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (112)
[    5.819230] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    5.827599] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=55ecd57df677fd722e795b49ccb283f065b222a1
[    5.841129] t19x_cache tegra-cache: probed
[    5.845549] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    5.856326] optee: probing for conduit method.
[    5.860925] optee: revision 3.22 (e3b12903)
[    5.919620] optee: dynamic shared memory is enabled
[    5.929056] optee: initialized driver
[    5.944961] nvpmodel: initialized successfully
[    5.949654] tegra_hv: get_hvd: not initialized yet
[    5.954593] user_ivc_mempool: hypervisor not present
[    5.960414] usbcore: registered new interface driver snd-usb-audio
[    5.967531] u32 classifier
[    5.970315]     input device check on
[    5.974091]     Actions configured
[    5.977744] Initializing XFRM netlink socket
[    5.982586] NET: Registered protocol family 10
[    5.988456] Segment Routing with IPv6
[    5.992288] NET: Registered protocol family 17
[    5.996891] NET: Registered protocol family 15
[    6.001535] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    6.015727] Bluetooth: RFCOMM socket layer initialized
[    6.021032] Bluetooth: RFCOMM ver 1.11
[    6.024909] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    6.030999] Bluetooth: HIDP socket layer initialized
[    6.037066] 9pnet: Installing 9P2000 support
[    6.041530] Key type dns_resolver registered
[    6.046739] registered taskstats version 1
[    6.050962] Loading compiled-in X.509 certificates
[    6.066975] Loaded X.509 cert 'Build time autogenerated kernel key: 9d3e488709af9cfc10fc5cd35100a1a9bcd52b88'
[    6.077683] tegra194-pcie 14100000.pcie: Adding to iommu group 7
[    6.090423] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    6.097716] tegra194-pcie 14160000.pcie: Adding to iommu group 8
[    6.109984] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    6.116875] tegra194-pcie 141e0000.pcie: Adding to iommu group 9
[    6.128757] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    6.135627] tegra194-pcie 140a0000.pcie: Adding to iommu group 10
[    6.147854] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    6.155287] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[    6.180121] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 11
[    6.198516] simple-framebuffer chosen:framebuffer: framebuffer at 0x279e00000, 0x870000 bytes, mapped to 0x00000000b610f0b3
[    6.209973] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=8192
[    6.219567] checking generic (279e00000 870000) vs hw (279e00000 870000)
[    6.219570] fb0: switching to simple from EFI VGA
[    6.225190] Console: switching to colour dummy device 80x25
[    6.234015] Console: switching to colour frame buffer device 240x67
[    6.243195] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[    6.250744] host1x 13e40000.host1x: Adding to iommu group 12
[    6.288438] host1x 13e40000.host1x: initialized
[    6.293550] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 13
[    6.301637] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    6.313651] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 14
[    6.321625] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    6.333658] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 15
[    6.341636] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    6.353655] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 16
[    6.361672] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    6.373686] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 17
[    6.381671] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    6.393645] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 18
[    6.401608] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    6.413631] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 19
[    6.421633] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    6.433630] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 20
[    6.441620] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    6.453656] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 21
[    6.461650] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    6.473664] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 22
[    6.481607] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    6.493606] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 23
[    6.501617] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    6.513590] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 24
[    6.521524] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    6.533492] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 25
[    6.541479] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    6.553451] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 26
[    6.561448] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    6.573395] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 27
[    6.581373] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    6.593348] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 28
[    6.601339] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    6.613369] falcon 15340000.vic: Adding to iommu group 29
[    6.624005] falcon 15340000.vic: initialized
[    6.628767] falcon 15380000.nvjpg: Adding to iommu group 30
[    6.637068] falcon 15380000.nvjpg: initialized
[    6.641807] falcon 15540000.nvjpg1: Adding to iommu group 31
[    6.651214] falcon 15540000.nvjpg1: initialized
[    6.656061] falcon 154c0000.nvenc: Adding to iommu group 32
[    6.666219] falcon 154c0000.nvenc: initialized
[    6.670969] falcon 15a50000.ofa: Adding to iommu group 33
[    6.679570] falcon 15a50000.ofa: initialized
[    6.684131] nvdec 15480000.nvdec: Adding to iommu group 34
[    6.696102] nvdec 15480000.nvdec: initialized
[    6.700733] tsec 15500000.tsec: Adding to iommu group 35
[    6.711081] tsec 15500000.tsec: initialized
[    6.718703] gic 2a41000.agic-controller: GIC IRQ controller registered
[    6.735464] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    6.752661] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    6.760009] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    6.767040] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    6.773621] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    6.780037] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    6.786346] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    6.795113] tegra194-isp5 14800000.isp: Adding to iommu group 36
[    6.804060] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    6.813454] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    6.819902] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    6.829294] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 37
[    6.837373] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 38
[    6.845307] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    6.855061] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    6.855153] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    6.871398] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    6.878211] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    6.888187] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    6.895053] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 39
[    6.903683] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[    6.915092] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 40
[    6.923690] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[    6.935108] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 41
[    6.943729] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[    6.955114] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 42
[    6.963710] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[    6.975099] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 43
[    6.983695] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[    6.995101] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 44
[    7.003710] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[    7.015077] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 45
[    7.023697] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[    7.035071] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 46
[    7.043692] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[    7.055091] pva 16000000.pva0: Adding to iommu group 47
[    7.065321] pva 16000000.pva0: initialized
[    7.078338] nvdla 15880000.nvdla0: Adding to iommu group 48
[    7.088560] nvdla 15880000.nvdla0: initialized
[    7.094972] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[    7.102119] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    7.109663] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    7.116313] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    7.123076] serial-tegra 3100000.serial: Adding to iommu group 2
[    7.129687] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[    7.139439] serial-tegra 3130000.serial: Adding to iommu group 2
[    7.146012] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[    7.155331] serial-tegra 3140000.serial: Adding to iommu group 2
[    7.161837] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[    7.172489]  usb3: Requested PHY is disabled
[    7.193004] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[    7.202791] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.208365] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    7.217066] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    7.226704] tegra-xusb 3610000.xhci: irq 228, io mem 0x03610000
[    7.233055] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.238622] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    7.246467] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    7.254104] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    7.262640] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.270096] usb usb1: Product: xHCI Host Controller
[    7.275105] usb usb1: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[    7.281387] usb usb1: SerialNumber: 3610000.xhci
[    7.286528] hub 1-0:1.0: USB hub found
[    7.290411] hub 1-0:1.0: 4 ports detected
[    7.294861] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    7.303365] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.310815] usb usb2: Product: xHCI Host Controller
[    7.315835] usb usb2: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[    7.322122] usb usb2: SerialNumber: 3610000.xhci
[    7.327038] hub 2-0:1.0: USB hub found
[    7.330899] hub 2-0:1.0: 4 ports detected
[    7.354823] i2c i2c-1: Added multiplexed i2c bus 9
[    7.359774] i2c-mux-gpio cam_i2cmux: 1 port mux on c240000.i2c adapter
[    7.366812] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    7.388518] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2001000 KHz, changing to: 1984000 KHz
[    7.400932] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2002000 KHz, changing to: 1984000 KHz
[    7.412593] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[    7.419863] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    7.427224] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    7.434409] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    7.443099] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    7.451788] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    7.547120] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    7.567114] tegra194-pcie 14100000.pcie: Link up
[    7.574465] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    7.581282] pci_bus 0001:00: root bus resource [bus 00-ff]
[    7.586919] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    7.596748] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    7.607575] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    7.615501] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    7.621838] pci 0001:00:00.0: PME# supported from D0 D3hot
[    7.631567] pci 0001:01:00.0: [10ec:8168] type 00 class 0x020000
[    7.637889] pci 0001:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    7.645139] pci 0001:01:00.0: reg 0x10: [io  size 0x0100]
[    7.650879] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    7.657991] pci 0001:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    7.666051] pci 0001:01:00.0: supports D1 D2
[    7.670451] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    7.681376] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    7.688809] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    7.695178] pci 0001:01:00.0: BAR 4: assigned [mem 0x20a8000000-0x20a8003fff 64bit]
[    7.703150] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8004000-0x20a8004fff 64bit]
[    7.709843] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[    7.711120] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    7.719437] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.725723] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    7.733032] usb 1-2: Product: USB2.1 Hub
[    7.733034] usb 1-2: Manufacturer: GenesysLogic
[    7.738404] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    7.745137] hub 1-2:1.0: USB hub found
[    7.747086] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    7.754331] hub 1-2:1.0: 4 ports detected
[    7.757224] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    7.777415] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    7.786350] pcieport 0001:00:00.0: Adding to iommu group 7
[    7.792202] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[    7.798263] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[    7.804802] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    7.812297] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    7.819468] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    7.828174] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    7.831323] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[    7.836867] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    7.872303] usb 2-1: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[    7.880731] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.888075] usb 2-1: Product: USB3.1 Hub
[    7.892097] usb 2-1: Manufacturer: GenesysLogic
[    7.900934] hub 2-1:1.0: USB hub found
[    7.906715] hub 2-1:1.0: 4 ports detected
[    7.958963] tegra194-pcie 14160000.pcie: Link up
[    7.966664] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    7.973466] pci_bus 0004:00: root bus resource [bus 00-ff]
[    7.979102] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    7.989216] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    7.995113] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[    8.000044] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.000085] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.021124] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.030609] pci 0004:01:00.0: [2646:5019] type 00 class 0x010802
[    8.036956] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    8.049118] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    8.056547] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    8.064511] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.069893] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    8.077252] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    8.085994] pci 0004:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    8.094912] pcieport 0004:00:00.0: Adding to iommu group 8
[    8.100747] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[    8.107211] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[    8.113251] nvme 0004:01:00.0: Adding to iommu group 8
[    8.118933] nvme nvme0: pci function 0004:01:00.0
[    8.123986] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    8.124460] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    8.137161] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[    8.144336] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    8.153031] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    8.161720] tegra194-pcie 141e0000.pcie:      MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[    8.162068] usb 1-3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[    8.163938] nvme nvme0: allocated 64 MiB host memory buffer.
[    8.184638] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.191984] usb 1-3: Product: USB2.1 Hub
[    8.192178] nvme nvme0: 6/0/0 default/read/poll queues
[    8.196006] usb 1-3: Manufacturer: GenesysLogic
[    8.197918] hub 1-3:1.0: USB hub found
[    8.203676]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    8.206729] hub 1-3:1.0: 4 ports detected
[    8.283342] usb 2-3: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[    8.316026] usb 2-3: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[    8.324442] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.331789] usb 2-3: Product: USB3.1 Hub
[    8.335813] usb 2-3: Manufacturer: GenesysLogic
[    8.344848] hub 2-3:1.0: USB hub found
[    8.350340] hub 2-3:1.0: 4 ports detected
[    8.538959] usb 1-3.1: new full-speed USB device number 4 using tegra-xusb
[    8.676343] usb 1-3.1: New USB device found, idVendor=1a86, idProduct=9354, bcdDevice=15.00
[    8.684941] usb 1-3.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    8.697555] input: HID 1a86:9354 as /devices/platform/3610000.xhci/usb1/1-3/1-3.1/1-3.1:1.0/0003:1A86:9354.0001/input/input0
[    8.768176] hid-generic 0003:1A86:9354.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 1a86:9354] on usb-3610000.xhci-3.1/input0
[    8.783540] input: HID 1a86:9354 as /devices/platform/3610000.xhci/usb1/1-3/1-3.1/1-3.1:1.1/0003:1A86:9354.0002/input/input1
[    8.795946] hid-generic 0003:1A86:9354.0002: input,hidraw1: USB HID v1.10 Mouse [HID 1a86:9354] on usb-3610000.xhci-3.1/input1
[    8.810710] input: HID 1a86:9354 as /devices/platform/3610000.xhci/usb1/1-3/1-3.1/1-3.1:1.2/0003:1A86:9354.0003/input/input2
[    8.822829] hid-generic 0003:1A86:9354.0003: input,hidraw2: USB HID v1.10 Mouse [HID 1a86:9354] on usb-3610000.xhci-3.1/input2
[    8.938957] usb 1-3.3: new high-speed USB device number 5 using tegra-xusb
[    9.075101] usb 1-3.3: New USB device found, idVendor=a69c, idProduct=8d80, bcdDevice= 1.00
[    9.083694] usb 1-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    9.091211] usb 1-3.3: Product: AIC Wlan
[    9.095239] usb 1-3.3: Manufacturer: aicsemi
[    9.099623] usb 1-3.3: SerialNumber: 20220103
[    9.267433] tegra194-pcie 141e0000.pcie: Phy link never came up
[    9.273609] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    9.280410] pci_bus 0007:00: root bus resource [bus 00-ff]
[    9.286045] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[    9.296162] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    9.306992] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[    9.314912] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    9.321228] pci 0007:00:00.0: PME# supported from D0 D3hot
[    9.333745] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    9.339129] pci 0007:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    9.348062] pcieport 0007:00:00.0: Adding to iommu group 9
[    9.353912] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[    9.359968] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[    9.365902] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[    9.372008] pci 0007:00:00.0: Removing from iommu group 9
[    9.377571] pci_bus 0007:00: busn_res: [bus 00-ff] is released
[    9.385115] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    9.391567] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[    9.391667] vdd-3v3-sd: 3300 mV, disabled
[    9.395937] vdd-3v3-sd: supplied by vdd-3v3
[    9.400361] vdd-3v3-pcie-isolate: 3300 mV, disabled
[    9.405678] irq: IRQ299: trimming hierarchy from :pmc@c360000
[    9.413762] tegra194-isp5 14800000.isp: initialized
[    9.423460] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    9.429918] (NULL device *): fops function table already registered
[    9.437737] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    9.444852] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    9.451542] irq: IRQ300: trimming hierarchy from :interrupt-controller@f400000-1
[    9.568026] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[    9.575207] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    9.583892] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    9.592574] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    9.707111] tegra194-pcie 140a0000.pcie: Link up
[    9.714022] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    9.720841] pci_bus 0008:00: root bus resource [bus 00-ff]
[    9.726475] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[    9.736590] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[    9.747418] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    9.755338] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    9.761654] pci 0008:00:00.0: PME# supported from D0 D3hot
[    9.771208] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    9.777524] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    9.783453] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    9.790533] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    9.798532] pci 0008:01:00.0: supports D1 D2
[    9.802928] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    9.813769] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    9.821194] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[    9.827920] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    9.835888] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    9.843860] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[    9.850514] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    9.855889] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[    9.862522] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    9.869883] pci 0008:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    9.878649] pci 0008:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    9.887572] pcieport 0008:00:00.0: Adding to iommu group 10
[    9.893518] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[    9.899719] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[    9.906689] irq: IRQ302: trimming hierarchy from :pmc@c360000
[    9.912670] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[    9.920361] input: gpio-keys as /devices/platform/gpio-keys/input/input3
[    9.928034] tegra-se-nvhost 15810000.se: Adding to iommu group 49
[    9.934611] tegra-se-nvhost 15810000.se: initialized
[    9.949204] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    9.955620] tegra-se-nvhost 15820000.se: Adding to iommu group 50
[    9.962173] tegra-se-nvhost 15820000.se: initialized
[    9.969629] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    9.976017] tegra-se-nvhost 15840000.se: Adding to iommu group 51
[    9.982519] tegra-se-nvhost 15840000.se: initialized
[    9.991492] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    9.998400] tegra_actmon d230000.actmon: in actmon_register()...
[   10.004773] tegra_actmon d230000.actmon: bwmgr_disable = 1
[   10.010925] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[   10.019343] hvc_sysfs: hypervisor is not present
[   10.059243] ALSA device list:
[   10.062301]   No soundcards found.
[   10.066506] Freeing unused kernel memory: 4480K
[   10.071227] Run /init as init process
[   10.074994]   with arguments:
[   10.074996]     /init
[   10.074996]   with environment:
[   10.074997]     HOME=/
[   10.074998]     TERM=linux
[   10.074999]     mminit_loglevel=4
[   10.086611] Root device found: nvme0n1p1
[   10.095213] Found dev node: /dev/nvme0n1p1
[   10.163214] EXT4-fs (nvme0n1p1): 17 orphan inodes deleted
[   10.168773] EXT4-fs (nvme0n1p1): recovery complete
[   10.185666] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[   10.195970] Rootfs mounted over nvme0n1p1
[   10.206062] Switching from initrd to actual rootfs
[   10.254373] systemd[1]: System time before build time, advancing clock.
[   10.315132] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[   10.338717] systemd[1]: Detected architecture arm64.
[   10.387183] systemd[1]: Set hostname to <tegra-ubuntu>.
[   10.504859] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   10.517961] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   10.527541] systemd[1]: Created slice system-modprobe.slice.
[   10.547227] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   10.567199] systemd[1]: Created slice User and Session Slice.
[   10.587050] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.611257] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.635032] systemd[1]: Reached target User and Group Name Lookups.
[   10.654992] systemd[1]: Reached target Slices.
[   10.670982] systemd[1]: Reached target Mounting snaps.
[   10.690977] systemd[1]: Reached target Mounted snaps.
[   10.710982] systemd[1]: Reached target Swap.
[   10.727209] systemd[1]: Listening on RPCbind Server Activation Socket.
[   10.747086] systemd[1]: Listening on Syslog Socket.
[   10.763080] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.787036] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.807180] systemd[1]: Listening on Journal Audit Socket.
[   10.827070] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.847099] systemd[1]: Listening on Journal Socket.
[   10.867095] systemd[1]: Listening on udev Control Socket.
[   10.887046] systemd[1]: Listening on udev Kernel Socket.
[   10.908044] systemd[1]: Mounting Huge Pages File System...
[   10.927944] systemd[1]: Mounting POSIX Message Queue File System...
[   10.947838] systemd[1]: Mounting RPC Pipe File System...
[   10.967882] systemd[1]: Mounting Kernel Debug File System...
[   10.987854] systemd[1]: Mounting Kernel Trace File System...
[   11.008127] systemd[1]: Starting Journal Service...
[   11.028160] systemd[1]: Starting Set the console keyboard layout...
[   11.048269] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   11.076137] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   11.103057] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   11.112516] systemd[1]: Starting Load Kernel Module efi_pstore...
[   11.132053] systemd[1]: Starting Load Kernel Module pstore_blk...
[   11.151958] systemd[1]: Starting Load Kernel Module pstore_zone...
[   11.171945] systemd[1]: Starting Load Kernel Module ramoops...
[   11.191961] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   11.215928] systemd[1]: Started Nameserver information manager.
[   11.235147] systemd[1]: Reached target Network (Pre).
[   11.255416] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   11.264773] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   11.275695] systemd[1]: Starting Load Kernel Modules...
[   11.296177] systemd[1]: Starting Remount Root and Kernel File Systems...
[   11.303919] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[   11.324129] systemd[1]: Starting udev Coldplug all Devices...
[   11.331528] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   11.341686] nvmap_page_pool_init: Total RAM pages: 1907084
[   11.347781] nvmap_page_pool_init: nvmap page pool size: 238385 pages (931 MB)
[   11.355317] nvmap_background_zero_thread: PP zeroing thread starting.
[   11.365124] systemd[1]: Started Journal Service.
[   11.614886] systemd-journald[248]: Received client request to flush runtime journal.
[   12.074266] spi-tegra114 3210000.spi: Adding to iommu group 2
[   12.097137] nvidia: loading out-of-tree module taints kernel.
[   12.149227] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[   12.165052] cpu-throttle-alert cooling device registered.
[   12.173459] spi-tegra114 3230000.spi: Adding to iommu group 2
[   12.174501] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[   12.195356] gpu-throttle-alert cooling device registered.
[   12.211485] lt6911uxc 9-002b: probing lt6911uxc v4l2 sensor at addr 0x2b
[   12.221678] nvadsp 2993000.adsp: Adding to iommu group 52
[   12.223165] lt6911uxc 9-002b: mclk absent,assuming sensor driven externally
[   12.237432] cv0-throttle-alert cooling device registered.
[   12.253717] cv1-throttle-alert cooling device registered.
[   12.270232] tegra-hda 3510000.hda: Adding to iommu group 53
[   12.271357] nvadsp 2993000.adsp: in probe()...
[   12.276200] lt6911uxc 9-002b: tegracam sensor driver:lt6911uxc_v2.0.6
[   12.283051] nv_platform 13800000.display: Adding to iommu group 54
[   12.296461] cv2-throttle-alert cooling device registered.
[   12.316859] r8168 0001:01:00.0: Adding to iommu group 7
[   12.324849] tegra-camrtc-capture-vi tegra-capture-vi: subdev lt6911uxc 9-002b bound
[   12.344874] platform 13800000.display:nvdisplay-niso: Adding to iommu group 55
[   12.351349] r8168 Gigabit Ethernet driver 8.051.02.10m_pll-NAPI loaded
[   12.356587] soc0-throttle-alert cooling device registered.
[   12.371119] r8168 0001:01:00.0: enabling device (0000 -> 0003)
[   12.375119] nvadsp 2993000.adsp: nvadsp_app_module_probe
[   12.383931] lt6911uxc 9-002b: detected lt6911uxc sensor
[   12.400944] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64  35.5.0  Release Build  (buildbrain@mobile-u64-6519-d7000)  Mon Feb 19 20:34:12 PST 2024
[   12.415848] soc1-throttle-alert cooling device registered.
[   12.426456] soc2-throttle-alert cooling device registered.
[   12.434009] r8168 0001:01:00.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[   12.446469] r8168 0001:01:00.0 (unnamed net_device) (uninitialized): Random ether addr f2:84:64:69:77:94
[   12.470541] hot-surface-alert cooling device registered.
[   12.471079] tegra-asoc: sound: Adding to iommu group 52
[   12.477644] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input4
[   12.479810] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   12.481889] r8168  Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[   12.516380] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input5
[   12.536246] r8168 0008:01:00.0: Adding to iommu group 10
[   12.538260] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 52
[   12.538287] tegra210_adsp_audio_probe: platform probe started
[   12.540659] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[   12.540930] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[   12.541181] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[   12.541432] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[   12.541686] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[   12.541929] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[   12.541932] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[   12.541934] tegra210-adsp tegra210-adsp: using adma channel page 0
[   12.541988] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[   12.551283] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input6
[   12.584057] r8168 Gigabit Ethernet driver 8.051.02.10m_pll-NAPI loaded
[   12.646893] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[   12.646924] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input7
[   12.675773] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   12.700759] r8168  Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
[   12.779880] cryptd: max_cpu_qlen set to 1000
[   12.889063] tegra210-adsp tegra210-adsp: Loaded app wire
[   12.894541] tegra210-adsp tegra210-adsp: Loaded app apm
[   12.899923] tegra210-adsp tegra210-adsp: Loaded app adma
[   12.905483] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[   12.911221] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 000000004679ff55
[   12.946468] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[   13.123728] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   14.010244] using random self ethernet address
[   14.017490] using random host ethernet address
[   14.045141] loop: module loaded
[   14.064943] cpufreq: cpu4,cur:1856000,set:1984000,set ndiv:155
[   14.173641] Mass Storage Function, version: 2009/09/11
[   14.173647] LUN: removable file: (no medium)
[   14.175727] using random self ethernet address
[   14.182180] using random host ethernet address
[   14.194484] rndis0: HOST MAC 2e:02:a6:36:e9:94
[   14.194489] rndis0: MAC 2e:02:a6:36:e9:95
[   14.194723] usb0: HOST MAC 2e:02:a6:36:e9:96
[   14.194726] usb0: MAC 2e:02:a6:36:e9:97
[   14.196489] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[   14.199122] l4tbr0: port 1(rndis0) entered blocking state
[   14.199134] l4tbr0: port 1(rndis0) entered disabled state
[   14.199246] device rndis0 entered promiscuous mode
[   14.208113] l4tbr0: port 2(usb0) entered blocking state
[   14.208129] l4tbr0: port 2(usb0) entered disabled state
[   14.208287] device usb0 entered promiscuous mode
[   14.217365] nvvrs_pseq 4-003c: CAUTION: interrupt status reg:0x10 set to 0x8
[   14.217372] nvvrs_pseq 4-003c: Clearing interrupts
[   15.810069] eth0: 0xffff800010927000, a2:64:6d:96:3a:e8, IRQ 305
[   15.879367] eth1: 0xffff800010bc3000, 48:b0:2d:ea:80:a8, IRQ 306
[   16.124850] pstore: Using crash dump compression: deflate
[   16.124887] printk: console [ramoops-1] enabled
[   16.124889] pstore: Registered ramoops as persistent store backend
[   16.124891] ramoops: using 0x200000@0x26eb70000, ecc: 0
[   16.172416] CPU4: shutdown
[   16.175279] psci: CPU4 killed (polled 0 ms)
[   16.212286] CPU5: shutdown
[   16.215123] psci: CPU5 killed (polled 0 ms)
[   16.359964] nvgpu: 17000000.ga10b                  gk20a_scale_init:541  [INFO]  enabled scaling for GPU
[   16.520178] zram: Added device: zram0
[   16.520362] zram: Added device: zram1
[   16.522435] zram: Added device: zram2
[   16.522915] zram: Added device: zram3
[   16.563146] zram0: detected capacity change from 0 to 976429056
[   16.595068] Adding 953540k swap on /dev/zram0.  Priority:5 extents:1 across:953540k SS
[   16.597672] zram1: detected capacity change from 0 to 976429056
[   16.623193] Adding 953540k swap on /dev/zram1.  Priority:5 extents:1 across:953540k SS
[   16.624626] zram2: detected capacity change from 0 to 976429056
[   16.667006] Adding 953540k swap on /dev/zram2.  Priority:5 extents:1 across:953540k SS
[   16.668436] zram3: detected capacity change from 0 to 976429056
[   16.695029] Adding 953540k swap on /dev/zram3.  Priority:5 extents:1 across:953540k SS
[   17.309798] fuse: init (API version 7.32)
[   17.368487] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  35.5.0  Release Build  (buildbrain@mobile-u64-6519-d7000)  Mon Feb 19 20:34:14 PST 2024
[   17.673731] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   20.041739] r8168: eth1: link up
[   20.041870] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   76.484607] bwmgr API not supported
[   79.326699] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[   79.339489] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[   79.349132] (NULL device *): vi_capture_control_message: NULL VI channel received
[   79.356926] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[   79.367811] (NULL device *): vi_capture_control_message: NULL VI channel received
[   79.376219] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[   81.886567] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[   81.895745] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[   81.905362] (NULL device *): vi_capture_control_message: NULL VI channel received
[   81.913135] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[   81.924027] (NULL device *): vi_capture_control_message: NULL VI channel received
root@tegra-ubuntu:/home/hebin# echo 1 > /sys/kernel/debug/tracing/tracing_on
root@tegra-ubuntu:/home/hebin# echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
root@tegra-ubuntu:/home/hebin# echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
root@tegra-ubuntu:/home/hebin# echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
root@tegra-ubuntu:/home/hebin# echo 2 > /sys/kernel/debug/camrtc/log-level
root@tegra-ubuntu:/home/hebin# echo > /sys/kernel/debug/tracing/trace
root@tegra-ubuntu:/home/hebin# cat /sys/kernel/debug/tracing/trace_pipe
     kworker/1:0-20      [001] ....    79.251703: rtcpu_dbg_set_loglevel: tstamp:3192450097 old:0 new:2
     kworker/1:0-20      [001] ....    85.479396: rtcpu_string: tstamp:3387338113 id:0x04010000 str:"VM0 deactivating."
     kworker/1:0-20      [001] ....    91.815180: rtcpu_string: tstamp:3586551515 id:0x04010000 str:"VM0 activating."
     kworker/1:0-20      [001] ....    91.871191: rtcpu_vinotify_error: tstamp:3587050344 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:114785498304 data:0x0000000000000001
     kworker/1:0-20      [001] ....    91.871201: rtcpu_vinotify_event: tstamp:3587210938 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:114774194688 data:0x759d580010000000
     kworker/1:0-20      [001] ....    91.871202: rtcpu_vinotify_event: tstamp:3587211072 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:114774201536 data:0x0000000031000001
     kworker/1:0-20      [001] ....    91.871202: rtcpu_vinotify_event: tstamp:3587211223 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:114774251840 data:0x759d550010000000
     kworker/1:0-20      [001] ....    91.871202: rtcpu_vinotify_event: tstamp:3587211354 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:114774258368 data:0x0000000031000002
     kworker/1:0-20      [001] ....    91.871203: rtcpu_vinotify_event: tstamp:3587211506 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:114785498304 data:0x0000000000000001
     kworker/1:0-20      [001] ....    91.871203: rtcpu_vinotify_event: tstamp:3587211641 cch:0 vi:0 tag:FS channel:0x00 frame:6776 vi_tstamp:114787290720 data:0x00001a7800000010
     kworker/1:0-20      [001] ....    91.871203: rtcpu_vinotify_event: tstamp:3587211793 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:6776 vi_tstamp:114787290848 data:0x0000000800000000
     kworker/1:0-20      [001] ....    91.871203: rtcpu_vinotify_event: tstamp:3587211925 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:6776 vi_tstamp:114787305664 data:0x0000000000000001
     kworker/1:0-20      [001] ....    91.871204: rtcpu_vinotify_event: tstamp:3587212075 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:6776 vi_tstamp:114787332864 data:0x0000000008020001
     kworker/1:0-20      [001] ....    91.871204: rtcpu_vinotify_event: tstamp:3587631479 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:6776 vi_tstamp:114803302112 data:0x0000000004370002
     kworker/1:0-20      [001] ....    91.871204: rtcpu_vinotify_event: tstamp:3587631632 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:6776 vi_tstamp:114803303136 data:0x0000000000000000
     kworker/1:0-20      [001] ....    91.871205: rtcpu_vinotify_event: tstamp:3587631764 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:6776 vi_tstamp:114803326464 data:0x0000000002020001
     kworker/1:0-20      [001] ....    91.871205: rtcpu_vinotify_event: tstamp:3587631917 cch:0 vi:0 tag:FE channel:0x00 frame:6776 vi_tstamp:114803305024 data:0x00001a7800000020
     kworker/1:0-20      [001] ....    91.871205: rtcpu_vinotify_event: tstamp:3587632053 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:6776 vi_tstamp:114803305120 data:0x0000000800000000
     kworker/1:0-20      [001] ....    91.871207: rtcpu_vinotify_event: tstamp:3587632205 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:6776 vi_tstamp:114803371584 data:0x0000000000020001
     kworker/1:0-20      [001] ....    91.871208: rtcpu_vinotify_event: tstamp:3587632339 cch:0 vi:0 tag:FS channel:0x00 frame:6777 vi_tstamp:114803956864 data:0x00001a7900000010
     kworker/1:0-20      [001] ....    91.871208: rtcpu_vinotify_event: tstamp:3588134547 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:6777 vi_tstamp:114803956960 data:0x0000000800000000
     kworker/1:0-20      [001] ....    91.871208: rtcpu_vinotify_event: tstamp:3588134682 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:6777 vi_tstamp:114803971808 data:0x0000000000000001
     kworker/1:0-20      [001] ....    91.871209: rtcpu_vinotify_event: tstamp:3588134836 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:6777 vi_tstamp:114804011424 data:0x0000000008020002
     kworker/1:0-20      [001] ....    91.871209: rtcpu_vinotify_event: tstamp:3588134970 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:114804283904 data:0x759d580010000000
     kworker/1:0-20      [001] ....    91.871209: rtcpu_vinotify_event: tstamp:3588135124 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:114804327232 data:0x0000000031000003
     kworker/1:0-20      [001] ....    91.871210: rtcpu_vinotify_event: tstamp:3588135256 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:6777 vi_tstamp:114819968224 data:0x0000000004370002
     kworker/1:0-20      [001] ....    91.871210: rtcpu_vinotify_event: tstamp:3588135409 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:6777 vi_tstamp:114819969216 data:0x0000000000000000
     kworker/1:0-20      [001] ....    91.871210: rtcpu_vinotify_event: tstamp:3588135540 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:6777 vi_tstamp:114819992608 data:0x0000000002020002
     kworker/1:0-20      [001] ....    91.871210: rtcpu_vinotify_event: tstamp:3588135688 cch:0 vi:0 tag:FE channel:0x00 frame:6777 vi_tstamp:114819971136 data:0x00001a7900000020
     kworker/1:0-20      [001] ....    91.871211: rtcpu_vinotify_event: tstamp:3588135821 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:6777 vi_tstamp:114819971264 data:0x0000000800000000
     kworker/1:0-20      [001] ....    91.871211: rtcpu_vinotify_event: tstamp:3588135972 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:6777 vi_tstamp:114820037664 data:0x0000000000020002
     kworker/1:0-20      [001] ....    91.871211: rtcpu_vinotify_event: tstamp:3588156108 cch:0 vi:0 tag:FS channel:0x00 frame:6778 vi_tstamp:114820622944 data:0x00001a7a00000010
     kworker/1:0-20      [001] ....    91.871211: rtcpu_vinotify_event: tstamp:3588156264 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:6778 vi_tstamp:114820623040 data:0x0000000800000000
     kworker/1:0-20      [001] ....    91.871211: rtcpu_vinotify_event: tstamp:3588156397 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:6778 vi_tstamp:114820637888 data:0x0000000000000001
     kworker/1:0-20      [001] ....    91.871211: rtcpu_vinotify_event: tstamp:3588156546 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:6778 vi_tstamp:114820665056 data:0x0000000008020003
     kworker/1:0-20      [001] ....    91.871212: rtcpu_vinotify_event: tstamp:3588156679 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:114820904416 data:0x759d550010000000
     kworker/1:0-20      [001] ....    91.927183: rtcpu_vinotify_event: tstamp:3588674958 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:114821060672 data:0x0000000031000004
     kworker/1:0-20      [001] ....    94.515136: rtcpu_vinotify_event: tstamp:3669513648 cch:-1 vi:0 tag:FE channel:0x00 frame:6778 vi_tstamp:117417692768 data:0x0000000000000020
     kworker/1:0-20      [001] ....    94.515146: rtcpu_vinotify_event: tstamp:3669513805 cch:-1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:6778 vi_tstamp:117417692800 data:0x0200200001000000
     kworker/1:0-20      [001] ....    94.515147: rtcpu_vinotify_event: tstamp:3669513946 cch:-1 vi:0 tag:ATOMP_FE channel:0x00 frame:6778 vi_tstamp:117417692864 data:0x0000000800000000
     kworker/1:0-20      [001] ....    94.515147: rtcpu_vinotify_event: tstamp:3670056077 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:117436964448 data:0x759d580010000000
     kworker/1:0-20      [001] ....    94.515147: rtcpu_vinotify_event: tstamp:3670056216 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:117437007168 data:0x0000000031000001
     kworker/1:0-20      [001] ....    94.515148: rtcpu_vinotify_event: tstamp:3670599275 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:117446488512 data:0x759d550010000000
     kworker/1:0-20      [001] ....    94.515148: rtcpu_vinotify_event: tstamp:3670599412 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:117446531872 data:0x0000000031000002
There’s CHANSEL_SHORT_FRAME in the trace that tell the sensor output less lines than expected. Try modify the xxx_set_exposure() as fixed exposure to try.
Hi ShaneCCC,
I haven’t used the imx219 to test the module functionality, it hasn’t arrived yet.
Still using the lt6911c, an HDMI to MIPI chip with no exposure configuration.
The CHANSEL_SHORT_FRAME doesn’t matter with the exposure.
It’s relative the output size that driver reported.
So how do I fix it?
In addition, among the two modules I tested, one (serial number: 1423623008531) can capture video stably using JP5.1.2, while the another (serial number: 1424723039800) needs JP5.1.3 to work stably.
Is there any problem in hardware and firmware matching?
Could you try set the pix_clk_hz less than 375000000
pix_clk_hz = “375000000”;
I used 300000000 before . pix_clk_hz = “300000000”;
What’s num_lanes? 4?
Yes.
port-index = <0>;
bus-width = <4>;
tegra234-camera-e2832.txt (39.6 KB)
Do you mean the serial number: 1423623008531 have problem on J5.1.3?
Could you try reboot the device and have below command then start checking the stability.
echo on > /sys/devices/platform/*rtcpu/power/control
This instruction does not work.
But now the serial number: 1423623008531 has been capturing video steadily after boost the clocks.
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
However the serial number: 1424723039800 module can work stably when the clock are not raised, and the video preview will get stuck after the clocks are raised.
1.Do these different behaviors seem to be related to the batch of the module?
2.How to parse the serial number and confirm the production information based on the serial number?
Could you verify both module with reference sensor like imx219 or imx477.
