With Multiple Sparks: do they all need the same amount of NVMe storage?
I have a single Spark (HP ZGX Nano) and considering adding a second one. My question is about local storage on each Spark. I haven’t seen this question asked anywhere yet.
Is it necessary to have the same amount of local storage (e.g. 1, 2, or 4TB) on both nodes? Or can I get away with 4TB on the main node, and then load the models from that node directly in the the RAM of the second node (using the 100GbE link)?
Thanks,
John
Ideally, you’d want to keep the available local storage the same size on all the nodes, but it’s probably not absolutely required; you’ll just have a little more management overhead.
If you export the location where your models are stored (like your huggingface cache directory) via NFS and mount it on all the nodes, then you can probably get by with less storage on the other nodes.
You’ll need to set variables like HF_HOME accordingly as well.
A few months ago, my suggestion would have been to get a 1TB unit then upgrade it to 4TB using the Corsair MP700 Micro, but with the never-ending flash price increases, check to see if the price difference between a 1TB vs a 4TB ZGX Nano is more than the cost of the Corsair NVMe to see if it’s worth doing it.
Have one node with 4TB of storage, export /home as NFS and mount that via the Mellanox interfaces on your other nodes, this will save you multiple times through your future multi nodes experience.
You can have different storage configs between your sparks, as long as the model files you are running is available to both sparks its all good.
Thanks! BTW, that’s exactly what I did with the first one: purchased back in January with 1TB, purchased the MP700 micro 4TB. (But now I have an extra 1TB drive…)
Thanks everyone!!
