like ubuntu’s system update
In booted state, Can the entire system be updated using System Update?
If possible
Where should I check out the Jetson Linux Developer Guide?
Thank you.
If possible
Thank you.
Do you mean the GUI button to upgrade the entire system?
It has a similar purpose to the article below.
Thank you.
Then why did that post cannot help your case? Please explain.
I am trying to make a camera using jetson nano.
The camera is remote and there must be a way to update the system including the firmware.
I am trying to proceed by mimicking Ubuntu’s system update method.
In the article mentioned above, I thought it would be helpful because the author was also having similar concerns.
Thank you.
How does a system upgrade using a gui button work as you said?
Thank you.
It cannot. We don’t have such function.
Okay.
I don’t know more about docker, but can I use docker to update my entire system while booted?
Thank you.
