With usb3.0 connected cameras fail to be recognized
I am using a Jetson Orin Nano with a carrier board, connecting two USB 3.0 cameras via the USB 3.0 interface. In practice, we have observed that when power‑cycling the Jetson Orin Nano, there is approximately a 3% probability that the cameras fail to be recognized. At the same time, the console log from the Jetson Orin Nano indicates that the USB hub is also not functioning.
To investigate this, we have carried out the following tests:
  1. We kept the Jetson Orin Nano powered continuously while power‑cycling the cameras (which are externally powered). Under this condition, the cameras never failed to be detected.
  2. We introduced a delay of more than 10 seconds after power‑up of the Jetson Orin Nano before enabling the 5V supply on the USB 3.0 interface. With this delay, the failure rate dropped by about half.
Could you please provide suggestions on how to further reduce the camera detection failure rate? I have attached the kernel log outputs for both the successful and failed detection scenarios for reference.
-------------------------------good case---------------------------------------------------------
| Bus 002 Device 004: ID 2bdf:0001 U3V MV-CS016-10UC
Bus 002 Device 003: ID 2bdf:0001 U3V MV-CS016-10UC
Bus 002 Device 002: ID 0bda:0489 Realtek Semiconductor Corp. 4-Port USB 3.0 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0bda:5489 Realtek Semiconductor Corp. 4-Port USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 10000M
|__ Port 1: Dev 3, If 1, Class=Miscellaneous Device, Driver=, 5000M
|__ Port 1: Dev 3, If 2, Class=Miscellaneous Device, Driver=usbfs, 5000M
|__ Port 1: Dev 3, If 0, Class=Miscellaneous Device, Driver=usbfs, 5000M
|__ Port 2: Dev 4, If 0, Class=Miscellaneous Device, Driver=usbfs, 5000M
|__ Port 2: Dev 4, If 1, Class=Miscellaneous Device, Driver=, 5000M
|__ Port 2: Dev 4, If 2, Class=Miscellaneous Device, Driver=usbfs, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
-------------------------------bad case--------------------------------------------------------- |
Would suggest test it on Orin Nano developer kit and see if the issue also appears. To clarify this is not specific to the cuctom carrier board.
Also suggest use latest Jetpack 6.2.2 r36.5 or Jetpack 7.2 r39.2.
“Are you suggesting we test on the official developer kit? The core module is NVIDIA’s official one, while the carrier board is from an NVIDIA third-party partner.”
A slightly more concise and direct version:
We’re on Jetpack 6.2.2 r34.6 right now. Just wondering – do the two versions you suggested have any USB driver updates?
Jetpack 6.2.2 is r36.5. There is no r34.6. Please clarify this. We would suggest
  1. Do compliance test to the custom carrier board. Please check the tuning guide:
    Jetson Download Center | NVIDIA Developer
  2. Please try to replicate the issue on Orin Nano developer kit. To clarify if it is specific to the custom carrier board or not.
