Hi, I want to drive my car with ROS2 using a wizard vehicle, but there is no joint. How can I drive my robot with an articulation controller or something else?
I don’t think you can drive the vehicle with an articulation controller.
If you create a vehicle using the Vehicle Wizard with a “Drive Type” of “None”, then each of the tires have a Vehicle Wheel Controller properties window where you can set the Steering, Wheel Torque and Brake Torque separately for each tire. You can then write a script or use OmniGraph nodes to control the car with a traditional proportional feedback controller.
I hope I am answering your question as I don’t entirely understand the question.
