@Yolomei ,Hello,Thank you so much,The device tree I modified in Jetson AGX Xavier is as follows, I would like to ask if it is correct?
// SPDX-License-Identifier: GPL-2.0-only
* T194 p2822-0000 audio common DTSI file.
* Copyright (c) 2017-2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
#include <audio/tegra-platforms-audio-dai-links.dtsi>
#include <audio/tegra186-audio-dai-links.dtsi>
#include <audio/tegra186-audio-graph.dtsi>
#include <dt-bindings/gpio/tegra194-gpio.h>
#include <dt-bindings/audio/tegra194-audio.h>
#include <audio/tegra-platforms-audio-dmic3-5-switch.dtsi>
aconnect@2a41000 {
status = "okay";
agic-controller@2a41000 {
status = "okay";
adsp@2993000 {
status = "okay";
//add
clocks {
wm8904_mclk: wm8904_mclk {
compatible = "fixed-clock";
#clock-cells = <0>;
// clock-frequency = <49152000>;
clock-frequency = <12288000>;
clock-output-names = "wm8904-mclk";
status = "okay";
i2c@c250000 {
//add
wm8904_codec: wm8904@1a {
compatible = "wlf,wm8904";
status ="okay";
reg = <0x1a>;
clocks = <&wm8904_mclk>;
// clocks = <&bpmp TEGRA194_CLK_AUD_MCLK>;
// clocks = <&pck0>;
clock-names = "mclk";
port {
wm8904_ep: endpoint {
remote-endpoint = <&i2s1_dap_ep>;
mclk-fs = <256>;
link-name = "wm8904-playback";
/* Default for all I2S is long fsync width(31) */
aconnect@2a41000 {
compatible = "nvidia,tegra210-aconnect";
status = "okay";
ahub {
/* I2S4 in Short frame sync for BT SCO */
i2s@2901300 {
bclk-ratio = <4>;
status = "okay";
tegra_acsl_audio: acsl_audio {
status = "okay";
hda@3510000 {
status = "okay";
nvidia,model = "NVIDIA Jetson AGX Xavier HDA";
tegra_sound: sound {
status = "okay";
compatible = "nvidia,tegra186-ape";
nvidia-audio-card,name = "NVIDIA Jetson AGX Xavier APE";
nvidia,num-codec-link = <1>;
nvidia,num-clk = <6>;
nvidia,clk-rates = < 270950400 /* PLLA_x11025_RATE */
11289600 /* AUD_MCLK_x11025_RATE */
45158400 /* PLLA_OUT0_x11025_RATE */
45158400 /* AHUB_x11025_RATE */
245760000 /* PLLA_x8000_RATE */
12288000 /* AUD_MCLK_x8000_RATE */
49152000 /* PLLA_OUT0_x8000_RATE */
49152000 >;/* AHUB_x8000_RATE */
nvidia,xbar = <&tegra_axbar>;
clocks = <&bpmp_clks TEGRA194_CLK_PLLA>,
<&bpmp_clks TEGRA194_CLK_PLLA_OUT0>,
<&bpmp_clks TEGRA194_CLK_AUD_MCLK>;
clock-names = "pll_a", "pll_a_out0", "extern1";
assigned-clocks = <&bpmp_clks TEGRA194_CLK_AUD_MCLK>;
assigned-clock-parents = <&bpmp_clks TEGRA194_CLK_PLLA_OUT0>;
nvidia-audio-card,widgets =
"Headphone", "WM Headphone Jack",
"Microphone", "WM Mic",
"Line", "WM Line In Jack",
"Microphone", "WM MICBIAS";
//add
nvidia-audio-card,routing =
"WM Headphone Jack", "WM HPOUTL",
"WM Headphone Jack", "WM HPOUTR",
"WM IN2L", "WM Line In Jack",
"WM IN2R", "WM Line In Jack",
"WM Mic", "WM MICBIAS",
"WM IN1L", "WM Mic";
// "x Headphone", "x HPOUTL",
// "x Headphone", "x HPOUTR";
nvidia-audio-card,mclk-fs = <256>;
nvidia,dai-link-1 {
cpu-dai = <&tegra_i2s1>;
codec-dai = <&wm8904_codec>;
cpu-dai-name = "I2S1";
codec-dai-name = "wm8904-hifi";
format = "i2s";
bitclock-slave;
frame-slave;
bitclock-noninversion;
frame-noninversion;
bit-format = "s16_le";
bclk_ratio = <0>;
srate = <48000>;
num-channel = <2>;
ignore_suspend;
name-prefix = "WM";
status = "okay";
tegra_sound_graph: sound_graph {
compatible = "nvidia,tegra186-audio-graph-card";
* Tegra audio graph card is based on uptream generic audio
* graph sound card. In future there is plan to use this
* as default sound card.
status = "disabled";
dais = /* ADMAIF (FE) Ports */
<&admaif1_port>, <&admaif2_port>, <&admaif3_port>,
<&admaif4_port>, <&admaif5_port>, <&admaif6_port>,
<&admaif7_port>, <&admaif8_port>, <&admaif9_port>,
<&admaif10_port>, <&admaif11_port>, <&admaif12_port>,
<&admaif13_port>, <&admaif14_port>, <&admaif15_port>,
<&admaif16_port>, <&admaif17_port>, <&admaif18_port>,
<&admaif19_port>, <&admaif20_port>,
/* ADSP (FE) Ports */
<&adsp_pcm1_port>, <&adsp_pcm2_port>,
<&adsp_compr1_port>, <&adsp_compr2_port>,
/* XBAR I/O ports */
<&xbar_i2s1_port>, <&xbar_i2s2_port>, <&xbar_i2s3_port>,
<&xbar_i2s4_port>, <&xbar_i2s5_port>, <&xbar_i2s6_port>,
<&xbar_dmic1_port>, <&xbar_dmic2_port>,
<&xbar_dmic3_port>, <&xbar_dmic4_port>,
<&xbar_dspk1_port>, <&xbar_dspk2_port>,
/* XBAR HW accelerator ports */
<&xbar_sfc1_in_port>, <&xbar_sfc2_in_port>,
<&xbar_sfc3_in_port>, <&xbar_sfc4_in_port>,
<&xbar_mvc1_in_port>, <&xbar_mvc2_in_port>,
<&xbar_afc1_in_port>, <&xbar_afc2_in_port>,
<&xbar_afc3_in_port>, <&xbar_afc4_in_port>,
<&xbar_afc5_in_port>, <&xbar_afc6_in_port>,
<&xbar_asrc_in1_port>, <&xbar_asrc_in2_port>,
<&xbar_asrc_in3_port>, <&xbar_asrc_in4_port>,
<&xbar_asrc_in5_port>, <&xbar_asrc_in6_port>,
<&xbar_asrc_in7_port>, <&xbar_arad_port>,
<&xbar_mixer_in1_port>, <&xbar_mixer_in2_port>,
<&xbar_mixer_in3_port>, <&xbar_mixer_in4_port>,
<&xbar_mixer_in5_port>, <&xbar_mixer_in6_port>,
<&xbar_mixer_in7_port>, <&xbar_mixer_in8_port>,
<&xbar_mixer_in9_port>, <&xbar_mixer_in10_port>,
<&xbar_ope1_in_port>,
<&xbar_amx1_in1_port>, <&xbar_amx1_in2_port>,
<&xbar_amx1_in3_port>, <&xbar_amx1_in4_port>,
<&xbar_amx2_in1_port>, <&xbar_amx2_in2_port>,
<&xbar_amx2_in3_port>, <&xbar_amx2_in4_port>,
<&xbar_amx3_in1_port>, <&xbar_amx3_in2_port>,
<&xbar_amx3_in3_port>, <&xbar_amx3_in4_port>,
<&xbar_amx4_in1_port>, <&xbar_amx4_in2_port>,
<&xbar_amx4_in3_port>, <&xbar_amx4_in4_port>,
<&xbar_adx1_in_port>, <&xbar_adx2_in_port>,
<&xbar_adx3_in_port>, <&xbar_adx4_in_port>,
/* BE I/O Ports */
<&i2s1_port>, <&i2s2_port>, <&i2s3_port>,
<&i2s4_port>, <&i2s5_port>, <&i2s6_port>,
<&dmic1_port>, <&dmic2_port>, <&dmic3_port>,
<&dmic4_port>,
<&dspk1_port>, <&dspk2_port>,
/* BE HW accelerator ports */
<&sfc1_out_port>, <&sfc2_out_port>,
<&sfc3_out_port>, <&sfc4_out_port>,
<&mvc1_out_port>, <&mvc2_out_port>,
<&afc1_out_port>, <&afc2_out_port>,
<&afc3_out_port>, <&afc4_out_port>,
<&afc5_out_port>, <&afc6_out_port>,
<&asrc_out1_port>, <&asrc_out2_port>,
<&asrc_out3_port>, <&asrc_out4_port>,
<&asrc_out5_port>, <&asrc_out6_port>,
<&mixer_out1_port>, <&mixer_out2_port>,
<&mixer_out3_port>, <&mixer_out4_port>,
<&mixer_out5_port>,
<&ope1_out_port>,
<&amx1_out_port>, <&amx2_out_port>,
<&amx3_out_port>, <&amx4_out_port>,
<&adx1_out1_port>, <&adx1_out2_port>,
<&adx1_out3_port>, <&adx1_out4_port>,
<&adx2_out1_port>, <&adx2_out2_port>,
<&adx2_out3_port>, <&adx2_out4_port>,
<&adx3_out1_port>, <&adx3_out2_port>,
<&adx3_out3_port>, <&adx3_out4_port>,
<&adx4_out1_port>, <&adx4_out2_port>,
<&adx4_out3_port>, <&adx4_out4_port>,
/* ADSP related ports */
<&adsp_admaif1_port>, <&adsp_admaif2_port>,
<&adsp_admaif3_port>, <&adsp_admaif4_port>,
<&adsp_admaif5_port>, <&adsp_admaif6_port>,
<&adsp_admaif7_port>, <&adsp_admaif8_port>,
<&adsp_admaif9_port>, <&adsp_admaif10_port>,
<&adsp_admaif11_port>, <&adsp_admaif12_port>,
<&adsp_admaif13_port>, <&adsp_admaif14_port>,
<&adsp_admaif15_port>, <&adsp_admaif16_port>,
<&adsp_admaif17_port>, <&adsp_admaif18_port>,
<&adsp_admaif19_port>, <&adsp_admaif20_port>,
<&admaif1_codec_port>, <&admaif2_codec_port>,
<&admaif3_codec_port>, <&admaif4_codec_port>,
<&admaif5_codec_port>, <&admaif6_codec_port>,
<&admaif7_codec_port>, <&admaif8_codec_port>,
<&admaif9_codec_port>, <&admaif10_codec_port>,
<&admaif11_codec_port>, <&admaif12_codec_port>,
<&admaif13_codec_port>, <&admaif14_codec_port>,
<&admaif15_codec_port>, <&admaif16_codec_port>,
<&admaif17_codec_port>, <&admaif18_codec_port>,
<&admaif19_codec_port>, <&admaif20_codec_port>;
label = "NVIDIA Jetson AGX Xavier APE";
clock-names = "pll_a", "plla_out0";
widgets = "Headphone", "WM Headphone Jack",
routing = "WM Headphone Jack", "WM HPOUTL",
* For codec2codec based DAI link design this is required.
* For DPCM based design, this is optional and instead
* it will be picked from codec port node.
mclk-fs = <256>;
* Default config for all I2S dai links are
* format = "i2s", bitclock-slave, frame-slave,
* bitclock-noninversion, frame-noninversion,
* Any change from default needs override on
* platform specific files.
/* Override with Codec entries */
&i2s1_to_codec {
// link-name = "rt5658-playback";
bitclock-master;
frame-master;
codec {
sound-dai = <&wm8904_codec 0>;
prefix = "WM";
hdr40_snd_link_i2s: &i2s2_to_codec { };
/* Override with BT SCO entries */
&i2s4_to_codec {
format = "dsp_a";
bitclock-inversion;
/* Audio graph related bindings */
&i2s1_dap_ep {
remote-endpoint = <&wm8904_ep>;
&i2s4_dap_ep {
dai-format = "dsp_a";
bitclock-inversion;
hdr40_snd_i2s_dap_ep: &i2s2_dap_ep { };
