I think there is a easier way to understand when to press the power button.
If you board just plug out and in the power supply cable, your board is now still not powered on.
In such case,
- press the recovery button
- press the power button (power LED should be ON now)
- release the power button
- release the recovery button
If your board is already in powered-on state, then it is pointless to press a power key again because it will not trigger anything. In such case, do the above 4 steps again but replace the power button to reset button in step 2,3.
So the timing to use either power key or reset key depends on your power status of your board.
