Workbench-example-hybrid-rag Secret Key Clarity
For clarity which key should I use if I’ve downloaded NIM for the NVCF_RUN_KEY secret key. Should generate and use the key from that NIM or should I generate and use a key from NGC.NVIDIA.COM?
You can generate the key either from build.nvidia.com on a page for any NIM, or you can generate a personal key on ngc.nvidia.com (just make sure you check the api service permissions for your key)
In either case, make sure your key starts with “nvapi-…” and you have credits in your build.nvidia.com for using the api endpoints.
