Workload of mutiple sources into multiple sinks gstreamer
I have 8 stream sources which I want to add into one source_bin using (GstElement *create_source_bin)
Then I want to use this source_bin data to feed to 3 pipelines (three deferent AI models in parralell) to output three sinks. All is done in a single application.
Is this possible and the workload for this case should be [8 + 3] or [(8 + 3) x 3] threads ?
Many thanks,
• DeepStream Version
• TensorRT Version
Do you mean you want to know how many threads will be in the app?
Yeah, and I want to make sure to only use 8 streams sources but not 8x3 ?
If you have 3 different models which want to inference the 8 streams, one pipeline is enough.
I want to separate output frames in 3 different output based on result of 3 models. Since multiple output frames was not supported by DS so that’s why I need to create 3 pipeline.
Understand. If you tee the nvstreammux output to the three models. The number will be 8 + 3 +3
Hmm Why 8 + 3 + 3 ? 8 source threads + 3 pipeline threads and …?
