• Hardware Platform Jetson
• DeepStream Version 6.0
• JetPack Version 4.6
• Issue Type question
I’m trying to wrap the SmartRecord API in a Gstreamer (Bin) element. It seems to be working alright with video only like:
gst-launch-1.0 v4l2src io-mode=2 do-timestamp=TRUE device=/dev/video1 ! video/x-raw ! queue ! nvvidconv ! "video/x-raw(memory:NVMM),format=I420" ! nvv4l2h264enc maxperf-enable=1 disable-cabac=true idrinterval=60 ! h264parse ! mtdsmartrecord name=smartrec
but when i’m adding an audio ghostpad ( see the #ifdef ADD_AUDIO parts) to the Element it fails completely when trying to finalise (=call NvDsSRStart) the file like (using the same pipeline as above):
0:01:41.608964063 376 0x7f94545c50 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
0:01:41.610548750 376 0x7f94545c50 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:<source> pad not activated yet
0:01:41.631333233 376 0x7f48064e30 WARN qtdemux qtdemux_types.c:233:qtdemux_type_get: unknown QuickTime node type pasp
0:01:41.631486728 376 0x7f48064e30 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
0:01:41.631621472 376 0x7f48064e30 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 2
0:01:41.631658973 376 0x7f48064e30 WARN qtdemux qtdemux.c:11710:qtdemux_parse_trak:<qtdemux0> error: This file is corrupt and cannot be played.
0:01:41.633203607 376 0x7f94545c50 WARN discoverer gstdiscoverer.c:1473:handle_message:<qtdemux0> Got an error [debug:qtdemux.c(11710): qtdemux_parse_trak (): /GstPipeline:Discoverer/GstURIDecodeBin:discoverer-uri/GstDecodeBin:decodebin1/GstQTDemux:qtdemux0], [message:This file is corrupt and cannot be played.]
** ERROR: <RunUserCallback:207>: No video stream found
** ERROR: <RunUserCallback:212>: No audio stream found
it does create a file, however it seems to be corrupted because when i look at it :
/data/videos$ ffmpeg -i smartrecord_00000_20220404-021611_376.mp4
ffmpeg version 3.4.8-0ubuntu0.2 Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 7 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)
configuration: --prefix=/usr --extra-version=0ubuntu0.2 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
libavutil 55. 78.100 / 55. 78.100
libavcodec 57.107.100 / 57.107.100
libavformat 57. 83.100 / 57. 83.100
libavdevice 57. 10.100 / 57. 10.100
libavfilter 6.107.100 / 6.107.100
libavresample 3. 7. 0 / 3. 7. 0
libswscale 4. 8.100 / 4. 8.100
libswresample 2. 9.100 / 2. 9.100
libpostproc 54. 7.100 / 54. 7.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5584d7b640] Invalid mdhd time scale 0, defaulting to 1
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5584d7b640] invalid STSD entries 0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5584d7b640] error reading header
smartrecord_00000_20220404-021611_376.mp4: Invalid data found when processing input
Can anyone see what I am doing wrong with adding the ghostpad for the audio ?
I’m wondering because if I don’t #define ADD_AUDIO this plugin seems to work alright for the video.
Kind regards,
Tom
gstmtdsmartrecord.cpp (14.0 KB)
gstmtdsmartrecord.h (1.4 KB)
