Hellow
I’m trying to compile wrf3.4 with PGI 12.5 on CentOS(64 bit). When I compiled with the configure.wrf I get the following error message:
any idea how can i fix this problem? Thanks!
# configure.wrf
# This file was automatically generated by the configure script in the
# top level directory. You may make changes to the settings in this
# file but be aware they will be overwritten each time you run configure.
# Ordinarily, it is necessary to run configure once, when the code is
# first installed.
# To permanently change options, change the settings for your platform
# in the file arch/configure.defaults then rerun configure.
SHELL = /bin/sh
DEVTOP = `pwd`
LIBINCLUDE = .
.SUFFIXES: .F .i .o .f90 .c
#### Get core settings from environment (set in compile script)
#### Note to add a core, this has to be added to.
COREDEFS = -DEM_CORE=$(WRF_EM_CORE) \
-DNMM_CORE=$(WRF_NMM_CORE) -DNMM_MAX_DIM=2600 \
-DCOAMPS_CORE=$(WRF_COAMPS_CORE) \
-DDA_CORE=$(WRF_DA_CORE) \
-DEXP_CORE=$(WRF_EXP_CORE)
#### Single location for defining total number of domains. You need
#### at least 1 + 2*(number of total nests). For example, 1 coarse
#### grid + three fine grids = 1 + 2(3) = 7, so MAX_DOMAINS=7.
MAX_DOMAINS = 21
#### DM buffer length for the configuration flags.
CONFIG_BUF_LEN = 65536
#### Size of bitmasks (in 4byte integers) of stream masks for WRF I/O
MAX_HISTORY = 25
IWORDSIZE = 4
DWORDSIZE = 8
LWORDSIZE = 4
#### The settings in this section are defaults that may be overridden by the
#### architecture-specific settings in the next section.
#### NOTE: Do not modify these default values here. To override these
#### values, make changes after "Architecture specific settings".
#### Native size (in bytes) of Fortran REAL data type on this architecture ####
#### Note: to change real wordsize (for example, to promote REALs from
#### 4-byte to 8-byte), modify the definition of RWORDSIZE in the
#### section following "Architecture specific settings". Do not
#### change NATIVE_RWORDSIZE as is it architecture-specific.
NATIVE_RWORDSIZE = 4
#### Default sed command and script for Fortran source files ####
#SED_FTN = sed -f $(WRF_SRC_ROOT_DIR)/arch/standard.sed
SED_FTN = $(WRF_SRC_ROOT_DIR)/tools/standard.exe
# Hack to work around $(PWD) not changing during OSF1 build.
# $(IO_GRIB_SHARE_DIR) is reset during the OSF1 build only.
IO_GRIB_SHARE_DIR =
#### ESMF switches ####
#### These are set up by Config.pl ####
# switch to use separately installed ESMF library for coupling: 1==true
ESMF_COUPLING = 0
# select dependences on module_utility.o
ESMF_MOD_DEPENDENCE = $(WRF_SRC_ROOT_DIR)/external/esmf_time_f90/module_utility.o
# select -I options for external/io_esmf vs. external/esmf_time_f90
ESMF_IO_INC = -I$(WRF_SRC_ROOT_DIR)/external/esmf_time_f90
# select -I options for separately installed ESMF library, if present
ESMF_MOD_INC = $(ESMF_IO_INC)
# select cpp token for external/io_esmf vs. external/esmf_time_f90
ESMF_IO_DEFS =
# select build target for external/io_esmf vs. external/esmf_time_f90
ESMF_TARGET = esmf_time
# ESMFINCLUDEGOESHERE
LIBWRFLIB = libwrflib.a
#### Architecture specific settings ####
# Settings for Linux x86_64, PGI compiler with gcc (dmpar)
DMPARALLEL = 1
OMPCPP = # -D_OPENMP
OMP = # -mp -Minfo=mp -Mrecursive
OMPCC = # -mp
SFC = pgf90
SCC = gcc
CCOMP = pgcc
DM_FC = mpif90 -f90=$(SFC)
DM_CC = mpicc -cc=$(SCC) -DMPI2_SUPPORT
FC = $(DM_FC)
CC = $(DM_CC) -DFSEEKO64_OK
LD = $(FC)
RWORDSIZE = $(NATIVE_RWORDSIZE)
PROMOTION = -r$(RWORDSIZE) -i4
ARCH_LOCAL = -DNONSTANDARD_SYSTEM_SUBR
CFLAGS_LOCAL = -w -O3
LDFLAGS_LOCAL =
CPLUSPLUSLIB =
ESMF_LDFLAG = $(CPLUSPLUSLIB)
FCOPTIM = -O3 #-fastsse -Mvect=noaltcode -Msmartalloc -Mprefetch=distance:8 -Mfprelaxed # -Minfo=all =Mneginfo=all
FCREDUCEDOPT = $(FCOPTIM)
FCNOOPT = -O0
FCDEBUG = # -g $(FCNOOPT)
FORMAT_FIXED = -Mfixed
FORMAT_FREE = -Mfree
FCSUFFIX =
BYTESWAPIO = -byteswapio
FCBASEOPTS_NO_G = -w $(FORMAT_FREE) $(BYTESWAPIO) $(OMP)
FCBASEOPTS = $(FCBASEOPTS_NO_G) $(FCDEBUG)
MODULE_SRCH_FLAG = -module $(WRF_SRC_ROOT_DIR)/main
TRADFLAG = -traditional
CPP = /lib/cpp -C -P
AR = ar
ARFLAGS = ru
M4 = m4 -B 14000
RANLIB = ranlib
CC_TOOLS = $(SCC)
None of WRF_EM_CORE, WRF_NMM_CORE,
specified in shell environment…
Compiling: WRF_EM_CORE .
Registry INFO variable counts: 0d 1947 1d 96 2d 754 3d 450
REGISTRY WARNING: Don’t know about ru_tendf_stoch_b in definition of ru_tendf_stoch
REGISTRY WARNING: Don’t know about ru_tendf_stoch_bt in definition of ru_tendf_stoch
REGISTRY WARNING: Don’t know about rv_tendf_stoch_b in definition of rv_tendf_stoch
REGISTRY WARNING: Don’t know about rv_tendf_stoch_bt in definition of rv_tendf_stoch
REGISTRY WARNING: Don’t know about rt_tendf_stoch_b in definition of rt_tendf_stoch
REGISTRY WARNING: Don’t know about rt_tendf_stoch_bt in definition of rt_tendf_stoch
ADVISORY: RSL_LITE version of gen_comms is linked in with registry program.
mpif90 -f90=pgf90 -c -r4 -i4 -O0 -w -Mfree -byteswapio -I…/dyn_em -I…/dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include module_io.f90
PGF90-S-0017-Unable to open include file: mpif.h (module_io.f90: 15781)
0 inform, 0 warnings, 1 severes, 0 fatal for collect_generic_and_call_pkg
PGF90-S-0017-Unable to open include file: mpif.h (module_io.f90: 16417)
0 inform, 0 warnings, 1 severes, 0 fatal for call_pkg_and_dist_generic
make[2]: [module_io.o] Error 2 (ignored)
ar ru …/main/libwrflib.a module_driver_constants.o module_domain_type.o module_streams.o module_domain.o module_integrate.o module_timing.o module_configure.o module_tiles.o module_machine.o module_nesting.o module_wrf_error.o module_state_description.o module_sm.o module_io.o module_comm_dm.o module_comm_dm_0.o module_comm_dm_1.o module_comm_dm_2.o module_comm_dm_3.o module_comm_dm_4.o module_comm_nesting_dm.o module_dm.o module_quilt_outbuf_ops.o module_io_quilt.o wrf_num_bytes_between.o wrf_shutdown.o wrf_debug.o libmassv.o collect_on_comm.o hires_timer.o nl_get_0_routines.o nl_get_1_routines.o nl_get_2_routines.o nl_get_3_routines.o nl_get_4_routines.o nl_get_5_routines.o nl_get_6_routines.o nl_get_7_routines.o nl_set_0_routines.o nl_set_1_routines.o nl_set_2_routines.o nl_set_3_routines.o nl_set_4_routines.o nl_set_5_routines.o nl_set_6_routines.o nl_set_7_routines.o module_alloc_space_0.o module_alloc_space_1.o module_alloc_space_2.o module_alloc_space_3.o module_alloc_space_4.o module_alloc_space_5.o module_alloc_space_6.o module_alloc_space_7.o module_alloc_space_8.o module_alloc_space_9.o
ar: creating …/main/libwrflib.a
ar: module_io.o: No such file or directory
make[2]: [framework] Error 1 (ignored)
ranlib …/main/libwrflib.a
ranlib: ‘…/main/libwrflib.a’: No such file
make[2]: Leaving directory /home/lim/WRF/WRFV3/frame' make[2]: Entering directory /home/lim/WRF/WRFV3/external/io_netcdf’
make[2]: diffwrf' is up to date. make[2]: Leaving directory /home/lim/WRF/WRFV3/external/io_netcdf’
make[2]: Entering directory /home/lim/WRF/WRFV3/external/io_int' if [ -f ../../frame/pack_utils.o ] ; then \ mv diffwrf.F diffwrf.F90 ; \ x=echo "pgf90 -w -Mfree -byteswapio " | awk ‘{print $1}’; export x ; \ if [ $x = "gfortran" ] ; then \ echo removing external declaration of iargc for gfortran ; \ /lib/cpp -C -P -traditional -I../ioapi_share diffwrf.F90 | sed '/integer *, *external.*iargc/d' > diffwrf.f ; \ else \ /lib/cpp -C -P -traditional -I../ioapi_share diffwrf.F90 > diffwrf.f ; \ fi ; \ pgf90 -w -Mfree -byteswapio -c -I../ioapi_share diffwrf.f ; \ mv diffwrf.F90 diffwrf.F ; \ pgf90 -w -Mfree -byteswapio -o diffwrf diffwrf.o io_int.o \ ../../frame/pack_utils.o ../../frame/module_internal_header_util.o \ ../../frame/module_driver_constants.o \ ../../frame/module_machine.o ../../frame/wrf_debug.o ../../frame/module_wrf_error.o \ -L/home/lim/WRF/WRFV3/external/esmf_time_f90 -lesmf_time ; fi ... PGF90-S-0017-Unable to open include file: mpif.h (../frame/module_io.f90: 15781) 0 inform, 0 warnings, 1 severes, 0 fatal for collect_generic_and_call_pkg PGF90-S-0017-Unable to open include file: mpif.h (../frame/module_io.f90: 16417) 0 inform, 0 warnings, 1 severes, 0 fatal for call_pkg_and_dist_generic make[2]: [../frame/module_io.o] Error 2 (ignored) ... ar ru ../main/libwrflib.a module_advect_em.o module_diffusion_em.o module_small_step_em.o module_big_step_utilities_em.o module_em.o module_solvedebug_em.o module_bc_em.o module_init_utilities.o module_wps_io_arw.o module_damping_em.o module_polarfft.o module_force_scm.o module_first_rk_step_part1.o module_first_rk_step_part2.o module_avgflx_em.o module_sfs_nba.o module_convtrans_prep.o module_sfs_driver.o module_stoch.o init_modules_em.o solve_em.o start_em.o shift_domain_em.o couple_or_uncouple_em.o nest_init_utils.o adapt_timestep_em.o interp_domain_em.o ar: module_wps_io_arw.o: No such file or directory make[2]: [dyn_em] Error 1 (ignored) make[2]: Leaving directory/home/lim/WRF/WRFV3/dyn_em’
make[1]: Leaving directory /home/lim/WRF/WRFV3' if [ 0 -eq 1 ] ; then make -i -r MODULE_DIRS="-I../dyn_em -I../dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include " nmm_core ; fi if [ 0 -eq 1 ] ; then make -i -r MODULE_DIRS="-I../dyn_em -I../dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include " exp_core ; fi ( cd main ; make -i -r MODULE_DIRS="-I../dyn_em -I../dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include " SOLVER=em em_wrf ) make[1]: Entering directory /home/lim/WRF/WRFV3/main’
rm -f …/main/module_wrf_top.o
/lib/cpp -C -P -I/home/lim/WRF/WRFV3/inc -DEM_CORE=1 -DNMM_CORE=0 -DNMM_MAX_DIM=2600 -DCOAMPS_CORE=0 -DDA_CORE=0 -DEXP_CORE=0 -DIWORDSIZE=4 -DDWORDSIZE=8 -DRWORDSIZE=4 -DLWORDSIZE=4 -DNONSTANDARD_SYSTEM_SUBR -DDM_PARALLEL -DNETCDF -DUSE_ALLOCATABLES -DGRIB1 -DINTIO -DLIMIT_ARGS -DCONFIG_BUF_LEN=65536 -DMAX_DOMAINS_F=21 -DMAX_HISTORY=25 -DNMM_NEST=0 -I. -traditional …/main/module_wrf_top.F > …/main/module_wrf_top.bb
/home/lim/WRF/WRFV3/tools/standard.exe …/main/module_wrf_top.bb | /lib/cpp -C -P > …/main/module_wrf_top.f90
rm -f …/main/module_wrf_top.b …/main/module_wrf_top.bb
if fgrep -iq ‘!$OMP’ …/main/module_wrf_top.f90 ; then
if [ -n “” ] ; then echo COMPILING …/main/module_wrf_top.F WITH OMP ; fi ;
mpif90 -f90=pgf90 -o …/main/module_wrf_top.o -c -O3 -w -Mfree -byteswapio -I…/dyn_em -I…/dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include -r4 -i4 …/main/module_wrf_top.f90 ;
else
if [ -n “” ] ; then echo COMPILING …/main/module_wrf_top.F WITHOUT OMP ; fi ;
fi
rm -f wrf.o
/lib/cpp -C -P -I/home/lim/WRF/WRFV3/inc -DEM_CORE=1 -DNMM_CORE=0 -DNMM_MAX_DIM=2600 -DCOAMPS_CORE=0 -DDA_CORE=0 -DEXP_CORE=0 -DIWORDSIZE=4 -DDWORDSIZE=8 -DRWORDSIZE=4 -DLWORDSIZE=4 -DNONSTANDARD_SYSTEM_SUBR -DDM_PARALLEL -DNETCDF -DUSE_ALLOCATABLES -DGRIB1 -DINTIO -DLIMIT_ARGS -DCONFIG_BUF_LEN=65536 -DMAX_DOMAINS_F=21 -DMAX_HISTORY=25 -DNMM_NEST=0 -I. -traditional wrf.F > wrf.bb
/home/lim/WRF/WRFV3/tools/standard.exe wrf.bb | /lib/cpp -C -P > wrf.f90
rm -f wrf.b wrf.bb
if fgrep -iq ‘!$OMP’ wrf.f90 ; then
if [ -n “” ] ; then echo COMPILING wrf.F WITH OMP ; fi ;
mpif90 -f90=pgf90 -o wrf.o -c -O3 -w -Mfree -byteswapio -I…/dyn_em -I…/dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include -r4 -i4 wrf.f90 ;
else
if [ -n “” ] ; then echo COMPILING wrf.F WITHOUT OMP ; fi ;
fi
ranlib libwrflib.a
mpif90 -f90=pgf90 -o wrf.exe -O3 -w -Mfree -byteswapio wrf.o …/main/module_wrf_top.o libwrflib.a /home/lim/WRF/WRFV3/external/fftpack/fftpack5/libfftpack.a /home/lim/WRF/WRFV3/external/io_grib1/libio_grib1.a /home/lim/WRF/WRFV3/external/io_grib_share/libio_grib_share.a /home/lim/WRF/WRFV3/external/io_int/libwrfio_int.a -L/home/lim/WRF/WRFV3/external/esmf_time_f90 -lesmf_time /home/lim/WRF/WRFV3/external/RSL_LITE/librsl_lite.a /home/lim/WRF/WRFV3/frame/module_internal_header_util.o /home/lim/WRF/WRFV3/frame/pack_utils.o -L/home/lim/WRF/WRFV3/external/io_netcdf -lwrfio_nf -L/opt/lib.pgi/netcdf4/lib -lnetcdff -lnetcdf
wrf.o: In function .C1_283': wrf.f90:(.data+0xc): undefined reference to module_streams_’
wrf.f90:(.data+0x74): undefined reference to module_driver_constants_' wrf.f90:(.data+0x7c): undefined reference to module_domain_type_’
wrf.f90:(.data+0x84): undefined reference to module_integrate_' wrf.f90:(.data+0x8c): undefined reference to module_wrf_error_’
wrf.f90:(.data+0x94): undefined reference to module_state_description_' wrf.f90:(.data+0x9c): undefined reference to module_configure_’
wrf.f90:(.data+0xac): undefined reference to module_timing_' wrf.f90:(.data+0xb4): undefined reference to module_machine_’
wrf.f90:(.data+0xbc): undefined reference to module_domain_' wrf.f90:(.data+0xc4): undefined reference to module_nesting_’
wrf.f90:(.data+0xcc): undefined reference to module_dm_' ../main/module_wrf_top.o: In function module_wrf_top_wrf_init_‘:
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:69: undefined reference to wrf_dm_on_monitor_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:72: undefined reference to module_configure_initial_config_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:73: undefined reference to module_configure_get_config_as_buffer_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:73: undefined reference to wrf_dm_bcast_bytes_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:73: undefined reference to module_configure_set_config_as_buffer_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:73: undefined reference to module_dm_wrf_dm_initialize_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:73: undefined reference to nl_get_debug_level_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:73: undefined reference to set_wrf_debug_level_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:73: undefined reference to nl_get_max_dom_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:73: undefined reference to wrf_message_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:73: undefined reference to wrf_debug_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:73: undefined reference to module_domain_alloc_and_configure_domain_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:73: undefined reference to wrf_debug_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:73: undefined reference to module_configure_model_to_grid_config_rec_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:73: undefined reference to wrf_debug_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:73: undefined reference to set_scalar_indices_from_config_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:73: undefined reference to wrf_debug_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:73: undefined reference to module_configure_get_config_as_buffer_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:73: undefined reference to wrf_dm_bcast_bytes_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:73: undefined reference to module_configure_set_config_as_buffer_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:106: undefined reference to wrf_debug_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:109: undefined reference to module_domain_domain_get_start_time_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:109: undefined reference to module_domain_domain_get_stop_time_' ../main/module_wrf_top.o: In function module_wrf_top_wrf_run_‘:
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:117: undefined reference to wrf_debug_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:117: undefined reference to module_integrate_integrate_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:117: undefined reference to wrf_debug_' ../main/module_wrf_top.o: In function module_wrf_top_wrf_finalize_‘:
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:123: undefined reference to wrf_debug_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:123: undefined reference to wrf_debug_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:127: undefined reference to wrf_shutdown_' ../main/module_wrf_top.o: In function module_wrf_top_wrf_dfi_‘:
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:136: undefined reference to wrf_message_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:136: undefined reference to wrf_message_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:148: undefined reference to wrf_message_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:148: undefined reference to wrf_message_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:148: undefined reference to wrf_message_' ../main/module_wrf_top.o:/home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:164: more undefined references to wrf_message_’ follow
…/main/module_wrf_top.o: In function module_wrf_top_wrf_dfi_': /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:180: undefined reference to wrf_error_fatal3_’
…/main/module_wrf_top.o: In function module_wrf_top_alloc_doms_for_dfi_': /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:205: undefined reference to module_nesting_nests_to_open_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:205: undefined reference to module_domain_alloc_and_configure_domain_' /home/lim/WRF/WRFV3/main/../main/module_wrf_top.f90:205: undefined reference to module_configure_model_to_grid_config_rec_’
/home/lim/WRF/WRFV3/main/…/main/module_wrf_top.f90:205: undefined reference to module_nesting_nests_to_open_' ../main/module_wrf_top.o: In function .C7_283’:
module_wrf_top.f90:(.data+0x2fc): undefined reference to module_machine_' module_wrf_top.f90:(.data+0x304): undefined reference to module_domain_’
module_wrf_top.f90:(.data+0x30c): undefined reference to module_integrate_' module_wrf_top.f90:(.data+0x314): undefined reference to module_driver_constants_’
module_wrf_top.f90:(.data+0x31c): undefined reference to module_configure_' module_wrf_top.f90:(.data+0x32c): undefined reference to module_timing_’
module_wrf_top.f90:(.data+0x334): undefined reference to module_wrf_error_' module_wrf_top.f90:(.data+0x33c): undefined reference to module_nesting_’
module_wrf_top.f90:(.data+0x344): undefined reference to module_dm_' module_wrf_top.f90:(.data+0x34c): undefined reference to module_state_description_’
module_wrf_top.f90:(.data+0x3b4): undefined reference to module_streams_' module_wrf_top.f90:(.data+0x3bc): undefined reference to module_domain_type_’
/home/lim/WRF/WRFV3/frame/module_internal_header_util.o: In function module_internal_header_util_int_get_write_field_header_': /home/lim/WRF/WRFV3/frame/./module_internal_header_util.f90:285: undefined reference to wrf_error_fatal_’
/home/lim/WRF/WRFV3/frame/module_internal_header_util.o: In function module_internal_header_util_int_get_noop_header_': /home/lim/WRF/WRFV3/frame/./module_internal_header_util.f90:1906: undefined reference to wrf_error_fatal_’
libwrflib.a(module_io_domain.o): In function `module_io_domain_open_r_dataset_':
/home/lim/WRF/WRFV3/external/io_int/libwrfio_int.a(io_int.o): In function ext_int_get_var_td_double_': /home/lim/WRF/WRFV3/external/io_int/./io_int.f:1553: undefined reference to wrf_error_fatal_’
/home/lim/WRF/WRFV3/external/io_int/libwrfio_int.a(io_int.o):/home/lim/WRF/WRFV3/external/io_int/./io_int.f:1567: more undefined references to wrf_error_fatal_' follow /home/lim/WRF/WRFV3/external/io_int/libwrfio_int.a(io_int.o): In function ext_int_read_field_‘:
/home/lim/WRF/WRFV3/external/io_int/./io_int.f:1739: undefined reference to wrf_message_' /home/lim/WRF/WRFV3/external/io_int/./io_int.f:1743: undefined reference to wrf_message_’
/home/lim/WRF/WRFV3/external/io_int/libwrfio_int.a(io_int.o): In function ext_int_write_field_': /home/lim/WRF/WRFV3/external/io_int/./io_int.f:1813: undefined reference to wrf_error_fatal_’
/home/lim/WRF/WRFV3/external/io_int/./io_int.f:1815: undefined reference to wrf_error_fatal_' /home/lim/WRF/WRFV3/external/io_int/./io_int.f:1824: undefined reference to wrf_error_fatal_’
/home/lim/WRF/WRFV3/external/io_int/./io_int.f:1828: undefined reference to wrf_error_fatal_' /home/lim/WRF/WRFV3/external/esmf_time_f90/libesmf_time.a(ESMF_Alarm.o): In function esmf_alarmmod_esmf_alarmsetringinterval_‘:
/home/lim/WRF/WRFV3/external/esmf_time_f90/./ESMF_Alarm.f:337: undefined reference to wrf_error_fatal_' /home/lim/WRF/WRFV3/external/esmf_time_f90/libesmf_time.a(ESMF_Alarm.o):/home/lim/WRF/WRFV3/external/esmf_time_f90/./ESMF_Alarm.f:368: more undefined references to wrf_error_fatal_’ follow
make[1]: [em_real] Error 2 (ignored)
However, when i compiled with setenv J “-j 1” (./compile em_real)
I get the following error messages like “undefined reference mpi_…”
ranlib libwrflib.a
libwrflib.a(module_dm.o): In function module_dm_wrf_dm_initialize_': /home/lim/WRF/WRFV3/frame/./module_dm.f90:139: undefined reference to mpi_comm_size_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:145: undefined reference to mpi_comm_rank_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:149: undefined reference to mpi_comm_dup_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:150: undefined reference to mpi_comm_group_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:155: undefined reference to mpi_group_incl_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:157: undefined reference to mpi_comm_create_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:166: undefined reference to mpi_cart_create_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:171: undefined reference to mpi_cart_create_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:173: undefined reference to mpi_comm_rank_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:174: undefined reference to mpi_cart_coords_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:177: undefined reference to mpi_comm_rank_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:178: undefined reference to mpi_cart_coords_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:188: undefined reference to mpi_comm_dup_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:191: undefined reference to mpi_comm_split_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:194: undefined reference to mpi_comm_split_’
libwrflib.a(module_dm.o): In function module_dm_getrealmpitype_': /home/lim/WRF/WRFV3/frame/./module_dm.f90:958: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:959: undefined reference to mpi_type_size_' libwrflib.a(module_dm.o): In function module_dm_wrf_dm_max_real_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:976: undefined reference to mpi_allreduce_' libwrflib.a(module_dm.o): In function module_dm_wrf_dm_min_real_’:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:985: undefined reference to mpi_allreduce_' libwrflib.a(module_dm.o): In function module_dm_wrf_dm_min_reals_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:996: undefined reference to mpi_allreduce_' libwrflib.a(module_dm.o): In function module_dm_wrf_dm_sum_real_’:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1004: undefined reference to mpi_allreduce_' libwrflib.a(module_dm.o): In function module_dm_wrf_dm_sum_reals_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1014: undefined reference to mpi_allreduce_' libwrflib.a(module_dm.o):/home/lim/WRF/WRFV3/frame/./module_dm.f90:1022: more undefined references to mpi_allreduce_’ follow
libwrflib.a(module_dm.o): In function module_dm_wrf_dm_maxval_real_': /home/lim/WRF/WRFV3/frame/./module_dm.f90:1046: undefined reference to mpi_allgather_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1047: undefined reference to mpi_allgather_' libwrflib.a(module_dm.o): In function module_dm_wrf_dm_maxval_doubleprecision_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1069: undefined reference to mpi_allgather_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1070: undefined reference to mpi_allgather_’
libwrflib.a(module_dm.o): In function module_dm_wrf_dm_maxval_integer_': /home/lim/WRF/WRFV3/frame/./module_dm.f90:1092: undefined reference to mpi_allgather_’
libwrflib.a(module_dm.o):/home/lim/WRF/WRFV3/frame/./module_dm.f90:1093: more undefined references to mpi_allgather_' follow libwrflib.a(module_dm.o): In function module_dm_split_communicator_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1204: undefined reference to mpi_initialized_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1213: undefined reference to mpi_comm_rank_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1214: undefined reference to mpi_comm_size_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1221: undefined reference to mpi_bcast_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1225: undefined reference to mpi_bcast_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1241: undefined reference to mpi_comm_dup_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1242: undefined reference to mpi_comm_split_' libwrflib.a(module_dm.o): In function module_dm_init_module_dm_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1253: undefined reference to mpi_initialized_' libwrflib.a(module_dm.o): In function module_dm_get_full_obs_vector_’:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1319: undefined reference to mpi_comm_size_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1332: undefined reference to mpi_allgather_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1341: undefined reference to mpi_allgatherv_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1345: undefined reference to mpi_allgatherv_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1352: undefined reference to mpi_allgatherv_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1359: undefined reference to mpi_allgatherv_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1376: undefined reference to mpi_allgather_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1385: undefined reference to mpi_allgatherv_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1389: undefined reference to mpi_allgatherv_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1396: undefined reference to mpi_allgatherv_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1415: undefined reference to mpi_allgather_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1422: undefined reference to mpi_allgatherv_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1426: undefined reference to mpi_allgatherv_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1434: undefined reference to mpi_allgatherv_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1441: undefined reference to mpi_allgatherv_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:1448: undefined reference to mpi_allgatherv_’
libwrflib.a(module_dm.o): In function module_dm_wrf_dm_maxtile_real_': /home/lim/WRF/WRFV3/frame/./module_dm.f90:1473: undefined reference to mpi_allgather_’
libwrflib.a(module_dm.o): In function module_dm_wrf_dm_mintile_real_': /home/lim/WRF/WRFV3/frame/./module_dm.f90:1500: undefined reference to mpi_allgather_’
libwrflib.a(module_dm.o): In function module_dm_wrf_dm_mintile_double_': /home/lim/WRF/WRFV3/frame/./module_dm.f90:1527: undefined reference to mpi_allgather_’
libwrflib.a(module_dm.o): In function module_dm_wrf_dm_tile_val_int_': /home/lim/WRF/WRFV3/frame/./module_dm.f90:1553: undefined reference to mpi_allgather_’
libwrflib.a(module_dm.o): In function wrf_termio_dup_': /home/lim/WRF/WRFV3/frame/./module_dm.f90:1640: undefined reference to mpi_comm_size_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1641: undefined reference to mpi_comm_rank_' libwrflib.a(module_dm.o): In function wrf_abort_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1805: undefined reference to mpi_abort_' libwrflib.a(module_dm.o): In function wrf_dm_shutdown_’:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1811: undefined reference to mpi_finalize_' libwrflib.a(module_dm.o): In function wrf_dm_on_monitor_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:1820: undefined reference to mpi_comm_rank_' libwrflib.a(module_dm.o): In function wrf_gatherv_real_’:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:18177: undefined reference to mpi_gatherv_' libwrflib.a(module_dm.o): In function wrf_gatherv_double_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:18210: undefined reference to mpi_gatherv_' libwrflib.a(module_dm.o): In function wrf_gatherv_integer_’:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:18238: undefined reference to mpi_gatherv_' libwrflib.a(module_dm.o): In function wrf_scatterv_real_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:18269: undefined reference to mpi_scatterv_' libwrflib.a(module_dm.o): In function wrf_scatterv_double_’:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:18303: undefined reference to mpi_scatterv_' libwrflib.a(module_dm.o): In function wrf_scatterv_integer_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:18333: undefined reference to mpi_scatterv_' libwrflib.a(module_dm.o): In function wrf_dm_gatherv_double_’:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:18373: undefined reference to mpi_allgather_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:18375: undefined reference to mpi_allgather_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:18379: undefined reference to mpi_allgatherv_' libwrflib.a(module_dm.o): In function wrf_dm_gatherv_single_‘:
/home/lim/WRF/WRFV3/frame/./module_dm.f90:18407: undefined reference to mpi_allgather_' /home/lim/WRF/WRFV3/frame/./module_dm.f90:18409: undefined reference to mpi_allgather_’
/home/lim/WRF/WRFV3/frame/./module_dm.f90:18413: undefined reference to mpi_allgatherv_' libwrflib.a(module_io.o): In function collect_generic_and_call_pkg_‘:
/home/lim/WRF/WRFV3/frame/./module_io.f90:15889: undefined reference to mpi_gather_' /home/lim/WRF/WRFV3/frame/./module_io.f90:15891: undefined reference to mpi_gather_’
/home/lim/WRF/WRFV3/frame/./module_io.f90:15944: undefined reference to mpi_gather_' /home/lim/WRF/WRFV3/frame/./module_io.f90:15946: undefined reference to mpi_gather_’
/home/lim/WRF/WRFV3/frame/./module_io.f90:15999: undefined reference to mpi_gather_' libwrflib.a(module_io.o):/home/lim/WRF/WRFV3/frame/./module_io.f90:16001: more undefined references to mpi_gather_’ follow
libwrflib.a(module_io_quilt.o): In function module_wrf_quilt_setup_quilt_servers_': /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:150: undefined reference to mpi_comm_dup_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:150: undefined reference to mpi_comm_split_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:180: undefined reference to mpi_comm_dup_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:180: undefined reference to mpi_comm_split_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:190: undefined reference to mpi_comm_rank_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:203: undefined reference to mpi_comm_dup_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:203: undefined reference to mpi_comm_split_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:209: undefined reference to mpi_comm_rank_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:215: undefined reference to mpi_comm_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:215: undefined reference to mpi_comm_rank_' libwrflib.a(module_io_quilt.o): In function module_wrf_quilt_quilt_‘:
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:324: undefined reference to mpi_comm_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:324: undefined reference to mpi_comm_rank_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:324: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:350: undefined reference to mpi_reduce_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:354: undefined reference to mpi_finalize_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:379: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:479: undefined reference to mpi_reduce_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:496: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:503: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:520: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:537: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:554: undefined reference to mpi_type_size_’
libwrflib.a(module_io_quilt.o):/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:658: more undefined references to mpi_type_size_' follow libwrflib.a(module_io_quilt.o): In function module_wrf_quilt_quilt_‘:
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:745: undefined reference to mpi_reduce_' libwrflib.a(module_io_quilt.o): In function module_wrf_quilt_quilt_pnc_’:
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:836: undefined reference to mpi_comm_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:836: undefined reference to mpi_comm_rank_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:836: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:856: undefined reference to mpi_reduce_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:860: undefined reference to mpi_finalize_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:882: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:994: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1011: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1028: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1045: undefined reference to mpi_type_size_’
libwrflib.a(module_io_quilt.o):/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1149: more undefined references to mpi_type_size_' follow libwrflib.a(module_io_quilt.o): In function module_wrf_quilt_init_module_wrf_quilt_‘:
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1257: undefined reference to mpi_initialized_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1262: undefined reference to mpi_comm_rank_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1262: undefined reference to mpi_comm_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1289: undefined reference to mpi_bcast_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1289: undefined reference to mpi_bcast_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1289: undefined reference to mpi_bcast_’
libwrflib.a(module_io_quilt.o): In function wrf_quilt_open_for_write_begin_': /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1375: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1389: undefined reference to mpi_comm_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1396: undefined reference to mpi_reduce_’
libwrflib.a(module_io_quilt.o): In function wrf_quilt_open_for_write_commit_': /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1451: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1459: undefined reference to mpi_comm_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1465: undefined reference to mpi_reduce_’
libwrflib.a(module_io_quilt.o): In function wrf_quilt_iosync_': /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1570: undefined reference to mpi_comm_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1576: undefined reference to mpi_reduce_' libwrflib.a(module_io_quilt.o): In function wrf_quilt_ioclose_‘:
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1634: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1641: undefined reference to mpi_comm_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1646: undefined reference to mpi_reduce_' libwrflib.a(module_io_quilt.o): In function wrf_quilt_ioexit_‘:
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1703: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1716: undefined reference to mpi_comm_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1716: undefined reference to mpi_comm_rank_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1722: undefined reference to mpi_reduce_’
libwrflib.a(module_io_quilt.o): In function wrf_quilt_set_time_': /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1791: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1798: undefined reference to mpi_comm_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1804: undefined reference to mpi_reduce_’
libwrflib.a(module_io_quilt.o): In function wrf_quilt_put_dom_ti_real_': /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1878: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1883: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1883: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1890: undefined reference to mpi_comm_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1896: undefined reference to mpi_reduce_’
libwrflib.a(module_io_quilt.o): In function wrf_quilt_put_dom_ti_integer_': /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1993: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:1993: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2001: undefined reference to mpi_comm_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2007: undefined reference to mpi_reduce_' libwrflib.a(module_io_quilt.o): In function wrf_quilt_put_dom_ti_char_‘:
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2103: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2109: undefined reference to mpi_comm_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2116: undefined reference to mpi_reduce_' libwrflib.a(module_io_quilt.o): In function wrf_quilt_put_var_ti_char_‘:
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2377: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2384: undefined reference to mpi_comm_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2390: undefined reference to mpi_reduce_' libwrflib.a(module_io_quilt.o): In function wrf_quilt_write_field_‘:
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2593: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2599: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2601: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2603: undefined reference to mpi_type_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2605: undefined reference to mpi_type_size_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2608: undefined reference to mpi_comm_size_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2620: undefined reference to mpi_reduce_' libwrflib.a(module_io_quilt.o): In function wrf_quilt_find_server_‘:
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2670: undefined reference to mpi_recv_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2674: undefined reference to mpi_bcast_’
libwrflib.a(module_io_quilt.o): In function wrf_quilt_server_ready_': /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2689: undefined reference to mpi_barrier_’
/home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2696: undefined reference to mpi_ssend_' /home/lim/WRF/WRFV3/frame/./module_io_quilt.f90:2701: undefined reference to mpi_barrier_’
make[1]: [em_wrf] Error 2 (ignored)
make[1]: Leaving directory `/home/lim/WRF/WRFV3/main’
Hi Jong-MyoungLim84242,
I appears to me that your MPI installation wasn’t built with Fortran support. Hence, the missing header file and undefined references.
What MPI are you using? How was it built?
Hi Mat
I compiled MVAPICH with PGI-12.5.
Anyway, when I added “-L/opt/mpi/mvapich/pgi/lib -lmpich -lfmpich” on LDFLAGS, I get the following error messages
mpif90 -o wrf.exe -O3 -w -Mfree -byteswapio -L/opt/mpi/mvapich/pgi/lib -lmpich -lfmpich wrf.o …/main/module_wrf_top.o libwrflib.a /home/lim/WRF/WRFV3/external/fftpack/fftpack5/libfftpack.a /home/lim/WRF/WRFV3/external/io_grib1/libio_grib1.a /home/lim/WRF/WRFV3/external/io_grib_share/libio_grib_share.a /home/lim/WRF/WRFV3/external/io_int/libwrfio_int.a -L/home/lim/WRF/WRFV3/external/esmf_time_f90 -lesmf_time /home/lim/WRF/WRFV3/external/RSL_LITE/librsl_lite.a /home/lim/WRF/WRFV3/frame/module_internal_header_util.o /home/lim/WRF/WRFV3/frame/pack_utils.o -L/home/lim/WRF/WRFV3/external/io_netcdf -lwrfio_nf -L/opt/lib.pgi/netcdf4/lib -lnetcdff -lnetcdf
/opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_STATUS_IGNORE' /opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_TRUE’
/opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_MPI_BOTTOM' /opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_FALSE’
/opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_STATUSES_IGNORE' make[1]: [em_wrf] Error 2 (ignored) make[1]: Leaving directory /home/lim/WRF/WRFV3/main’
( cd run ; /bin/rm -f wrf.exe ; ln -s …/main/wrf.exe . )
( cd main ; make -i -r MODULE_DIRS="-I…/dyn_em -I…/dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include " SOLVER=em em_wrf_SST_ESMF ) ;
fi
build started: Sat Aug 11 00:56:39 KST 2012
build completed: Sat Aug 11 01:11:03 KST 2012
( cd main ; make -i -r MODULE_DIRS="-I…/dyn_em -I…/dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include " SOLVER=em IDEAL_CASE=real em_real )
make[1]: Entering directory /home/lim/WRF/WRFV3/main' rm -f ../dyn_em/module_initialize_real.o /lib/cpp -C -P -I/home/lim/WRF/WRFV3/inc -DEM_CORE=1 -DNMM_CORE=0 -DNMM_MAX_DIM=2600 -DCOAMPS_CORE=0 -DDA_CORE=0 -DEXP_CORE=0 -DIWORDSIZE=4 -DDWORDSIZE=8 -DRWORDSIZE=4 -DLWORDSIZE=4 -DNONSTANDARD_SYSTEM_SUBR -DDM_PARALLEL -DNETCDF -DUSE_ALLOCATABLES -DGRIB1 -DINTIO -DLIMIT_ARGS -DCONFIG_BUF_LEN=65536 -DMAX_DOMAINS_F=21 -DMAX_HISTORY=25 -DNMM_NEST=0 -I. -traditional ../dyn_em/module_initialize_real.F > ../dyn_em/module_initialize_real.bb /home/lim/WRF/WRFV3/tools/standard.exe ../dyn_em/module_initialize_real.bb | /lib/cpp -C -P > ../dyn_em/module_initialize_real.f90 rm -f ../dyn_em/module_initialize_real.b ../dyn_em/module_initialize_real.bb if fgrep -iq '!$OMP' ../dyn_em/module_initialize_real.f90 ; then \ if [ -n "" ] ; then echo COMPILING ../dyn_em/module_initialize_real.F WITH OMP ; fi ; \ mpif90 -o ../dyn_em/module_initialize_real.o -c -O3 -w -Mfree -byteswapio -I../dyn_em -I../dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include -r4 -i4 ../dyn_em/module_initialize_real.f90 ; \ else \ if [ -n "" ] ; then echo COMPILING ../dyn_em/module_initialize_real.F WITHOUT OMP ; fi ; \ mpif90 -o ../dyn_em/module_initialize_real.o -c -O3 -w -Mfree -byteswapio -I../dyn_em -I../dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include -r4 -i4 ../dyn_em/module_initialize_real.f90 ; \ fi ( cd ../dyn_em ; make -i -r module_initialize_real.o ) make[2]: Entering directory /home/lim/WRF/WRFV3/dyn_em’
make[2]: module_initialize_real.o' is up to date. make[2]: Leaving directory /home/lim/WRF/WRFV3/dyn_em’
rm -f real_em.o
/lib/cpp -C -P -I/home/lim/WRF/WRFV3/inc -DEM_CORE=1 -DNMM_CORE=0 -DNMM_MAX_DIM=2600 -DCOAMPS_CORE=0 -DDA_CORE=0 -DEXP_CORE=0 -DIWORDSIZE=4 -DDWORDSIZE=8 -DRWORDSIZE=4 -DLWORDSIZE=4 -DNONSTANDARD_SYSTEM_SUBR -DDM_PARALLEL -DNETCDF -DUSE_ALLOCATABLES -DGRIB1 -DINTIO -DLIMIT_ARGS -DCONFIG_BUF_LEN=65536 -DMAX_DOMAINS_F=21 -DMAX_HISTORY=25 -DNMM_NEST=0 -I. -traditional real_em.F > real_em.bb
/home/lim/WRF/WRFV3/tools/standard.exe real_em.bb | /lib/cpp -C -P > real_em.f90
rm -f real_em.b real_em.bb
if fgrep -iq ‘!$OMP’ real_em.f90 ; then
if [ -n “” ] ; then echo COMPILING real_em.F WITH OMP ; fi ;
mpif90 -o real_em.o -c -O3 -w -Mfree -byteswapio -I…/dyn_em -I…/dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include -r4 -i4 real_em.f90 ;
else
if [ -n “” ] ; then echo COMPILING real_em.F WITHOUT OMP ; fi ;
fi
rm -f ndown_em.o
/lib/cpp -C -P -I/home/lim/WRF/WRFV3/inc -DEM_CORE=1 -DNMM_CORE=0 -DNMM_MAX_DIM=2600 -DCOAMPS_CORE=0 -DDA_CORE=0 -DEXP_CORE=0 -DIWORDSIZE=4 -DDWORDSIZE=8 -DRWORDSIZE=4 -DLWORDSIZE=4 -DNONSTANDARD_SYSTEM_SUBR -DDM_PARALLEL -DNETCDF -DUSE_ALLOCATABLES -DGRIB1 -DINTIO -DLIMIT_ARGS -DCONFIG_BUF_LEN=65536 -DMAX_DOMAINS_F=21 -DMAX_HISTORY=25 -DNMM_NEST=0 -I. -traditional ndown_em.F > ndown_em.bb
/home/lim/WRF/WRFV3/tools/standard.exe ndown_em.bb | /lib/cpp -C -P > ndown_em.f90
rm -f ndown_em.b ndown_em.bb
if fgrep -iq ‘!$OMP’ ndown_em.f90 ; then
if [ -n “” ] ; then echo COMPILING ndown_em.F WITH OMP ; fi ;
mpif90 -o ndown_em.o -c -O3 -w -Mfree -byteswapio -I…/dyn_em -I…/dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include -r4 -i4 ndown_em.f90 ;
else
if [ -n “” ] ; then echo COMPILING ndown_em.F WITHOUT OMP ; fi ;
fi
rm -f nup_em.o
/lib/cpp -C -P -I/home/lim/WRF/WRFV3/inc -DEM_CORE=1 -DNMM_CORE=0 -DNMM_MAX_DIM=2600 -DCOAMPS_CORE=0 -DDA_CORE=0 -DEXP_CORE=0 -DIWORDSIZE=4 -DDWORDSIZE=8 -DRWORDSIZE=4 -DLWORDSIZE=4 -DNONSTANDARD_SYSTEM_SUBR -DDM_PARALLEL -DNETCDF -DUSE_ALLOCATABLES -DGRIB1 -DINTIO -DLIMIT_ARGS -DCONFIG_BUF_LEN=65536 -DMAX_DOMAINS_F=21 -DMAX_HISTORY=25 -DNMM_NEST=0 -I. -traditional nup_em.F > nup_em.bb
/home/lim/WRF/WRFV3/tools/standard.exe nup_em.bb | /lib/cpp -C -P > nup_em.f90
rm -f nup_em.b nup_em.bb
if fgrep -iq ‘!$OMP’ nup_em.f90 ; then
if [ -n “” ] ; then echo COMPILING nup_em.F WITH OMP ; fi ;
mpif90 -o nup_em.o -c -O3 -w -Mfree -byteswapio -I…/dyn_em -I…/dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include -r4 -i4 nup_em.f90 ;
else
if [ -n “” ] ; then echo COMPILING nup_em.F WITHOUT OMP ; fi ;
fi
rm -f tc_em.o
/lib/cpp -C -P -I/home/lim/WRF/WRFV3/inc -DEM_CORE=1 -DNMM_CORE=0 -DNMM_MAX_DIM=2600 -DCOAMPS_CORE=0 -DDA_CORE=0 -DEXP_CORE=0 -DIWORDSIZE=4 -DDWORDSIZE=8 -DRWORDSIZE=4 -DLWORDSIZE=4 -DNONSTANDARD_SYSTEM_SUBR -DDM_PARALLEL -DNETCDF -DUSE_ALLOCATABLES -DGRIB1 -DINTIO -DLIMIT_ARGS -DCONFIG_BUF_LEN=65536 -DMAX_DOMAINS_F=21 -DMAX_HISTORY=25 -DNMM_NEST=0 -I. -traditional tc_em.F > tc_em.bb
/home/lim/WRF/WRFV3/tools/standard.exe tc_em.bb | /lib/cpp -C -P > tc_em.f90
rm -f tc_em.b tc_em.bb
if fgrep -iq ‘!$OMP’ tc_em.f90 ; then
if [ -n “” ] ; then echo COMPILING tc_em.F WITH OMP ; fi ;
mpif90 -o tc_em.o -c -O3 -w -Mfree -byteswapio -I…/dyn_em -I…/dyn_nmm -module /home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/esmf_time_f90 -I/home/lim/WRF/WRFV3/main -I/home/lim/WRF/WRFV3/external/io_netcdf -I/home/lim/WRF/WRFV3/external/io_int -I/home/lim/WRF/WRFV3/frame -I/home/lim/WRF/WRFV3/share -I/home/lim/WRF/WRFV3/phys -I/home/lim/WRF/WRFV3/chem -I/home/lim/WRF/WRFV3/inc -I/opt/lib.pgi/netcdf4/include -r4 -i4 tc_em.f90 ;
else
if [ -n “” ] ; then echo COMPILING tc_em.F WITHOUT OMP ; fi ;
fi
ranlib libwrflib.a
mpif90 -o real.exe -O3 -w -Mfree -byteswapio -L/opt/mpi/mvapich/pgi/lib -lmpich -lfmpich real_em.o …/dyn_em/module_initialize_real.o libwrflib.a /home/lim/WRF/WRFV3/external/fftpack/fftpack5/libfftpack.a /home/lim/WRF/WRFV3/external/io_grib1/libio_grib1.a /home/lim/WRF/WRFV3/external/io_grib_share/libio_grib_share.a /home/lim/WRF/WRFV3/external/io_int/libwrfio_int.a -L/home/lim/WRF/WRFV3/external/esmf_time_f90 -lesmf_time /home/lim/WRF/WRFV3/external/RSL_LITE/librsl_lite.a /home/lim/WRF/WRFV3/frame/module_internal_header_util.o /home/lim/WRF/WRFV3/frame/pack_utils.o -L/home/lim/WRF/WRFV3/external/io_netcdf -lwrfio_nf -L/opt/lib.pgi/netcdf4/lib -lnetcdff -lnetcdf
libwrflib.a(module_wps_io_arw.o): In function module_wps_io_arw_read_wps_': /home/lim/WRF/WRFV3/dyn_em/./module_wps_io_arw.f90:271: undefined reference to mpi_file_open_’
/home/lim/WRF/WRFV3/dyn_em/./module_wps_io_arw.f90:284: undefined reference to mpi_file_read_at_' /home/lim/WRF/WRFV3/dyn_em/./module_wps_io_arw.f90:298: undefined reference to mpi_file_read_at_’
/home/lim/WRF/WRFV3/dyn_em/./module_wps_io_arw.f90:306: undefined reference to mpi_file_read_at_' /home/lim/WRF/WRFV3/dyn_em/./module_wps_io_arw.f90:313: undefined reference to mpi_file_read_at_’
/home/lim/WRF/WRFV3/dyn_em/./module_wps_io_arw.f90:320: undefined reference to mpi_file_read_at_' libwrflib.a(module_wps_io_arw.o):/home/lim/WRF/WRFV3/dyn_em/./module_wps_io_arw.f90:328: more undefined references to mpi_file_read_at_’ follow
libwrflib.a(module_wps_io_arw.o): In function module_wps_io_arw_read_wps_': /home/lim/WRF/WRFV3/dyn_em/./module_wps_io_arw.f90:1226: undefined reference to mpi_file_close_’
/opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_STATUSES_IGNORE' make[1]: [em_real] Error 2 (ignored) mpif90 -o ndown.exe -O3 -w -Mfree -byteswapio -L/opt/mpi/mvapich/pgi/lib -lmpich -lfmpich ndown_em.o ../dyn_em/module_initialize_real.o libwrflib.a /home/lim/WRF/WRFV3/external/fftpack/fftpack5/libfftpack.a /home/lim/WRF/WRFV3/external/io_grib1/libio_grib1.a /home/lim/WRF/WRFV3/external/io_grib_share/libio_grib_share.a /home/lim/WRF/WRFV3/external/io_int/libwrfio_int.a -L/home/lim/WRF/WRFV3/external/esmf_time_f90 -lesmf_time /home/lim/WRF/WRFV3/external/RSL_LITE/librsl_lite.a /home/lim/WRF/WRFV3/frame/module_internal_header_util.o /home/lim/WRF/WRFV3/frame/pack_utils.o -L/home/lim/WRF/WRFV3/external/io_netcdf -lwrfio_nf -L/opt/lib.pgi/netcdf4/lib -lnetcdff -lnetcdf /opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_STATUS_IGNORE’
/opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_TRUE' /opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_MPI_BOTTOM’
/opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_FALSE' /opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_STATUSES_IGNORE’
mpif90 -o nup.exe -O3 -w -Mfree -byteswapio -L/opt/mpi/mvapich/pgi/lib -lmpich -lfmpich nup_em.o …/dyn_em/module_initialize_real.o libwrflib.a /home/lim/WRF/WRFV3/external/fftpack/fftpack5/libfftpack.a /home/lim/WRF/WRFV3/external/io_grib1/libio_grib1.a /home/lim/WRF/WRFV3/external/io_grib_share/libio_grib_share.a /home/lim/WRF/WRFV3/external/io_int/libwrfio_int.a -L/home/lim/WRF/WRFV3/external/esmf_time_f90 -lesmf_time /home/lim/WRF/WRFV3/external/RSL_LITE/librsl_lite.a /home/lim/WRF/WRFV3/frame/module_internal_header_util.o /home/lim/WRF/WRFV3/frame/pack_utils.o -L/home/lim/WRF/WRFV3/external/io_netcdf -lwrfio_nf -L/opt/lib.pgi/netcdf4/lib -lnetcdff -lnetcdf
/opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_STATUSES_IGNORE' make[1]: [em_real] Error 2 (ignored) mpif90 -o tc.exe -O3 -w -Mfree -byteswapio -L/opt/mpi/mvapich/pgi/lib -lmpich -lfmpich tc_em.o ../dyn_em/module_initialize_real.o libwrflib.a /home/lim/WRF/WRFV3/external/fftpack/fftpack5/libfftpack.a /home/lim/WRF/WRFV3/external/io_grib1/libio_grib1.a /home/lim/WRF/WRFV3/external/io_grib_share/libio_grib_share.a /home/lim/WRF/WRFV3/external/io_int/libwrfio_int.a -L/home/lim/WRF/WRFV3/external/esmf_time_f90 -lesmf_time /home/lim/WRF/WRFV3/external/RSL_LITE/librsl_lite.a /home/lim/WRF/WRFV3/frame/module_internal_header_util.o /home/lim/WRF/WRFV3/frame/pack_utils.o -L/home/lim/WRF/WRFV3/external/io_netcdf -lwrfio_nf -L/opt/lib.pgi/netcdf4/lib -lnetcdff -lnetcdf /opt/mpi/mvapich/pgi/lib/shared/libfmpich.so: undefined reference to MPIR_F_STATUS_IGNORE’
You should have to do this since the mpif90 script should add these libs. Anyway, try switching the order ( i.e. “-lfmpich -lmpich” ) to get the dependencies right. I doubt it will fix the “mpi_file…” references, but should fix the “MPIR…” references.
