I am trying to copy an image made out of float through a kernel. This works fine as long as both the target and the source is in CL_RGBA format. But once the target is only CL_R strange values is written to the target.
I have the following kernel code:
__kernel void copy(__read_only image2d_t in,__write_only image2d_t out,sampler_t sampler)
int2 cord = (int2)(get_global_id(0),get_global_id(1));
float4 val = read_imagef(in,sampler,cord);
write_imagef(out,cord,val);
On an input image 5^5 with RGBA channels that look like this:
0;1;2;3 _ 4;5;6;7 _ 8;9;10;11 _ 12;13;14;15 _16;17;18;19
20;21;22;23 _ …
I get the result in an image that only has an R channel
4 4 4 4 16
20 20 20 20 36
48 48 48 48 56
60 60 60 60 76
84 81 81 81 96
Bu if I have a RGBA channel on the result the result is the same as the input.
What can be the cause of this strange behaviour?
