I’m trying to record rosbag straight to the SD card in my Jetson TX2,
while recording in some stage when the bag gets to about 1.2-1.5GB size
The RAM memory of the process starts accumulating and then it explodes.
Its seems that at some stage its stop writing to the SD card.
I’ve seen these errors in the “dmesg”:
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000991] kmemleak: Kernel memory leak detector disabled
[ 0.802887] Freeing initrd memory: 5432K
[ 3.505575] Freeing unused kernel memory: 8576K
Any idea how to fix it?
