Writing to pointer struct from threads
I am passing a raw pointer to a kernel, and using some kind of mutexes (some kind :P), each thread adds a value to the same member of the struct.
The pointer, holds an array of structures.
Each block works on a seperate structure of that array. So, block0 works on structure0, block1 on structure1 etc.
For example:
[codebox]
device static unsigned int kernel_mutexes[N];
struct someStruct {
int counter;
glogal void doSomeStuff( struct someStruct* str ) {
const unsigned int structureIdx = blockIdx.x;
// … do some other stuff here …
__syncthreads( );
// Each thread in the current block, will get a chance to
// access and write the member variable as soon as the
// kernel_mutexes[structureIdx] is equal to their id.
// Also, the "static" keyword, guarantees that the thread
// access will start from 0.
while( true ) {
   if( kernel_mutexes[structureIdx] == threadIdx.x ) {
        str[ structureIdx ].counter++;
        atomicAdd( &kernel_mutexes[structureIdx], 1 );
        __threadfence( );
        break;
[/codebox]
Maybe my thought is waaaayyy off?
Any comments and thoughts are welcomed.
edit: fixed using atomicExch and atomicInc, it`s about 2ms faster than before o_O
