Where did you store your data sets on the docker container? Also how did you manage to migrate them from your personal home computer to the docker container? Is there a command for that?
Lastly, how do we go about setting up the spec.cfg file and editing it? They show us an example one but I am not sure how I can actually go about making one myself.
Data - use the shared folders (one that is common to the host and docker, given as param to the docker run cmd).
Setting cfg - use the notebook they supply, modify their cfg files (i think u need to modify 5 of them).
Note also - this is “half baked” at best - the output of this entire exercise is something (hopefully) digestible by DeepStream, BUT JetPack4.2 is currently not supporting DeepStream properly (see other q I asked in the DS forum).
Hope you are well. I am at the same stage as you now on running it on Xavier. I have loaded 4.1 on the board to see if it will run there since Deepstream doesnt support 4.2
What commands are you using for the following?
1.Locate the tlt-converter inside your inference environment and add its parent
directory to the system path.
2. Run the converter: tlt-converter …
I want to compare them to what I am attempting to do to make sure I have got all the fields right.
