Description
I realized that some code pieces in 2.2.4. TF-TRT 2.0 Workflow With A SavedModel are wrong. The code should be fixed as below (relevant lines were written bold).
import tensorflow as tf
from tensorflow.python.compiler.tensorrt import trt_convert as trt
conversion_params = trt.DEFAULT_TRT_CONVERSION_PARAMS
conversion_params = conversion_params._replace(
max_workspace_size_bytes=(1<<32))
conversion_params = conversion_params._replace(precision_mode="FP16")
maximum_cached_engines=100) (engiens → engines)
converter = trt.TrtGraphConverterV2(
input_saved_model_dir=input_saved_model_dir,
conversion_params=conversion_params)
converter.convert()
def my_input_fn():
for _ in range(num_runs):
Inp1 = np.random.normal(size=(8, 16, 16, 3)).astype(np.float32)
inp2 = np.random.normal(size=(8, 16, 16, 3)).astype(np.float32)
yield inp1, inp2
converter.build(input_fn=my_input_fn)
converter.save(output_saved_model_dir) (new line for this part)
saved_model_loaded = tf.saved_model.load(
output_saved_model_dir, tags=[tag_constants.SERVING])
graph_func = saved_model_loaded.signatures[
signature_constants.DEFAULT_SERVING_SIGNATURE_DEF_KEY]
frozen_func = convert_to_constants.convert_variables_to_constants_v2(
graph_func)
output = frozen_func(input_data)[0].numpy()
