the following code crashes nvfortran here:
module m
implicit none
contains
subroutine s(a, n)
integer, intent(in) :: n
class(*), intent(in) :: a(n)
select type(a)
type is(integer)
print *,'a is integer, a=', a
class default
print *,'a is unsupported type'
stop 1
end select
end
end
program p
use m
implicit none
integer :: b(2,2) = reshape([21, 22, 23, 24], [2,2])
print *,b
call s (b,4) ! OK
print *
print *,b(:,1::2)
call s (b(:,1::2),2) ! bad type
print *
print *,b(1::2,:)
call s (b(1::2,:),2) ! bad type
print *
print *,b(2::2,:)
call s (b(2::2,:),2) ! bad type / ICE
end
I get:
ILM file: can't find intrinsic .dsqrt
NVFORTRAN-F-0000-Internal compiler error. Errors in ILM file 1 (pgi-class-explicit-size.f90)
The ICE goes away when the last 3 code lines are commented. In that case the program does not properly recognize that the passed argument is an integer array when the caller uses a non-unity stride:
21 22 23 24
a is integer, a= 21 22 23 24
21 22
1
Intel compiles the code, but produces wrong output for some of the calls.
