Jetson AGX Xavier
• DeepStream Version
Deepstream 5.1
4.5
• TensorRT Version
7.3.1
Question
I’m trying to use facenet as a seconday classifier and have converted the network to an onnx model which have successfully been generated to an engine file. But then I get this error message:
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input:0 160x160x3
1 OUTPUT kFLOAT Bottleneck/BatchNorm/batchnorm/add_1:0 128
0:00:05.192311491 16805 0x33baf920 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<face_encodings> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 2]: Use deserialized engine model: /home/bounty/repos/bounty_vidproc/nvidia/face_rec/facenet.onnx_b1_gpu0_fp16.engine
0:00:05.192365766 16805 0x33baf920 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<face_encodings> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::preparePreprocess() <nvdsinfer_context_impl.cpp:874> [UID = 2]: RGB/BGR input format specified but network input channels is not 3
It seems like the configuration file does not match the engine-file somehow. But I have specified the input dimentions and also speficied uff-input-order. as nhwc
what have I missed?
[property]
gpu-id=0
net-scale-factor=1
#uff-file=facenet.uff
onnx-file=facenet.onnx
#model-engine-file=facenet.onnx_b1_gpu0_fp16.engine
uff-input-blob-name=input:0
output-blob-names=Bottleneck/BatchNorm/batchnorm/add_1:0
batch-size=1
infer-dims=160;160;3
uff-input-order=1
model-color-format=0
0=FP32 and 1=INT8 mode 2=INT16
network-mode=2
1=Primary, 2=Secondary
process-mode=2
#input-object-min-width=160
#input-object-min-height=160
gpu-id=0
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0
is-classifier=1
classifier-async-mode=1
#scaling-filter=0
#scaling-compute-hw=0
I downloaded the facenet pb file: github.com/apollo-time/facenet/raw/master/model/resnet/facenet.pb
then converted the model to onnx
python3 -m tf2onnx.convert --input facenet.pb --inputs input:0[1,160,160,3] --inputs-as-nchw input_1:0 --outputs Bottleneck/BatchNorm/batchnorm/add_1:0 --output facenet.onnx
and then used this config file as secondary model:
[property]
gpu-id=0
net-scale-factor=1
batch-size=1
uff-input-order=1
network-mode=2
process-mode=2
gpu-id=0
gie-unique-id=2
operate-on-gie-id=1
is-classifier=1
#scaling-filter=0
