my configuration is a GTX 285 under Vista x64, 258.96 drivers. I’m using the official OpenCL C++ wrapper to dynamically (re-)create a program for a given context if the kernel source code has changed. The source code basically is:
// Put the whole source code into a single line.
cl::Program::Sources lines(1,std::make_pair(m_source_code.c_str(),m_source_code.length()));
// (Re-)create and build the program.
delete m_program;
m_program=new cl::Program(*m_context,lines,&result);
if (result==CL_SUCCESS) {
// Get all devices in the context.
DeviceList devices=m_context->getInfo<CL_CONTEXT_DEVICES>();
result=m_program->build(devices);
VECTOR_CLASS<cl::Kernel> kernels;
result=m_program->createKernels(&kernels);
assert(result==CL_SUCCESS);
The code works fine if executed for the first time, but afterwards the assert fails with result==CL_INVALID_VALUE. When debugging into createKernels(), it turns out that the first call to clCreateKernelsInProgram() succeeds and results in numKernels==0 (which already is wrong, I checked that the source code is not empty and compiles fine), but the second call to clCreateKernelsInProgram() returns CL_INVALID_VALUE. According to the documentation, CL_INVALID_VALUE is only returned “if kernels is not NULL and num_kernels is less than the number of kernels in program”. So if the number of kernels really was 0 as returned by the first call, the second call should not fail, which leads me to believe there is a bug in the frist call to clCreateKernelsInProgram().
Any hints for a work-around?
