Wrong Readings using 8 Bit PNG for Clara CXR Classification Model
Our team is currently exploring the model that is provided in NGC here:
https://ngc.nvidia.com/catalog/models/nvidia:med:clara_xray_classification_chest_no_amp/files
We have tried to inference some images into this model. The images itself comes from a number of sources online, that is: the NIH dataset and the Chexpert dataset.
But we have found that using the images from above dataset results in very biased readings to some classes. We used 19 different images from different classes of radiological readings, yet all tends to output the same results, as shown in the image below.
And so my questions are:
(1) Our hypothesis of why this happens, is because the model itself is trained on 16 Bit PNG images, yet the images we used are that of 8 Bit PNGs. Is this hypothesis true?
Some questions more related to the model itself than Clara Train:
(2) Do you think using this model as a pretrained model, which is used to train a new model using 8 Bit images is a good idea?
(3) Aside from the PLCO dataset, are there notable sources of 16 Bit PNG images online that the Nvidia team is aware of?
1.1 Yes, the trained model is trained with 16-bit PNG images from PLCO, and therefore the data augmentation method was set up for the 16-bit images, e.g., normalization.
1.2 It is still feasible to perform the inference with 8-bit png images as long as data augmentation modules are properly adjusted. However, accuracy is unknown.
2. No, finetuning from an Imagenet pre-trained model will be better.
3. MIMIC CXR dataset has the original DICOM available to the public.
