Howdy,
I plugged in a Jetson Nano, which I haven’t used. It turns on alright. However, when I plugged it into a monitor, The desktop icons were half cut off, and the bottom and top bars were missing. I don’t know what the issue is. The HDMI cord works fine. It’s a 2.1 chord. I’m pretty sure it’s picking up the wrong resolution for the monitor, but I’m not sure. Any insight would be helpful.
You may plug in the monitor and boot the system. So that the EDID can be read correctly at booting.
If the Jetson Nano is not used for a while. May consider to re-flash system image through SDKManager. The latest release is Jetpack 4.6.2.
