WSL2 Ubuntu 22.04 apt update fails
WSL2 Ubuntu 22.04 apt update failed with errors:
Ign:1 Index of /compute/cuda/repos/wsl-ubuntu/x86_64 InRelease
Ign:2 https://nvidia.github.io/libnvidia-container/experimental/deb/amd64 InRelease
Get:3 Index of /ubuntu jammy-security InRelease [110 kB]
Hit:4 Index of linux/ubuntu/ jammy InRelease
Hit:5 Index of /ubuntu jammy InRelease
Get:6 Index of /ubuntu jammy-updates InRelease [119 kB]
Hit:7 Index of /ubuntu jammy-backports InRelease
Err:1 Index of /compute/cuda/repos/wsl-ubuntu/x86_64 InRelease
Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 152.195.19.142 443]
Err:2 https://nvidia.github.io/libnvidia-container/experimental/deb/amd64 InRelease
Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 185.199.110.153 443]
Did not have this kind of problem before. That is, I successfully installed all required GPU driver, CUDA toolkit, container toolkit, Docker, etc., and then pulled and ran up Morpheus and Triton server images using the SID NPL example.
Have already followed the instructions in this webpage:
$ wget https://developer.download.nvidia.com/compute/cuda/repos/$distro/$arch/cuda-keyring_1.0-1_all.deb
$ sudo dpkg -i cuda-keyring_1.0-1_all.deb
I don’t understand what have been missed or mistake made.
How can I fix this problem?
CJ Liu
