sample_mnist doesn’t work on WSL2
&&&& RUNNING TensorRT.sample_mnist [TensorRT v8400] # ./sample_mnist
[03/18/2022-18:04:34] [I] Building and running a GPU inference engine for MNIST
[03/18/2022-18:04:34] [I] [TRT] [MemUsageChange] Init CUDA: CPU +313, GPU +0, now: CPU 320, GPU 1181 (MiB)
[03/18/2022-18:04:35] [I] [TRT] [MemUsageSnapshot] Begin constructing builder kernel library: CPU 340 MiB, GPU 1181 MiB
[03/18/2022-18:04:38] [I] [TRT] [MemUsageSnapshot] End constructing builder kernel library: CPU 405 MiB, GPU 1181 MiB
[03/18/2022-18:04:39] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +518, GPU +224, now: CPU 925, GPU 1405 (MiB)
[03/18/2022-18:04:39] [I] [TRT] [MemUsageChange] Init cuDNN: CPU +115, GPU +52, now: CPU 1040, GPU 1457 (MiB)
[03/18/2022-18:04:39] [I] [TRT] Local timing cache in use. Profiling results in this builder pass will not be stored.
[03/18/2022-18:04:44] [I] [TRT] Detected 1 inputs and 1 output network tensors.
[03/18/2022-18:04:44] [I] [TRT] Total Host Persistent Memory: 13600
[03/18/2022-18:04:44] [I] [TRT] Total Device Persistent Memory: 0
[03/18/2022-18:04:44] [I] [TRT] Total Scratch Memory: 0
[03/18/2022-18:04:44] [I] [TRT] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 1 MiB, GPU 884 MiB
[03/18/2022-18:04:44] [I] [TRT] [BlockAssignment] Algorithm ShiftNTopDown took 0.0328ms to assign 3 blocks to 10 nodes requiring 57860 bytes.
[03/18/2022-18:04:44] [I] [TRT] Total Activation Memory: 57860
[03/18/2022-18:04:44] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in building engine: CPU +0, GPU +4, now: CPU 0, GPU 4 (MiB)
[03/18/2022-18:04:44] [I] [TRT] [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 1555, GPU 1655 (MiB)
[03/18/2022-18:04:44] [I] [TRT] Loaded engine size: 2 MiB
[03/18/2022-18:04:44] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +1, now: CPU 0, GPU 1 (MiB)
[03/18/2022-18:04:44] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +0, now: CPU 0, GPU 1 (MiB)
[03/18/2022-18:04:44] [I] Input:
[03/18/2022-18:04:44] [I] Output:
0: *
1: *
2: *
3: *
4: *
5: *
6: *
7: *
8: *
9: *
&&&& FAILED TensorRT.sample_mnist [TensorRT v8400] # ./sample_mnist
TensorRT Version: all 8.x versions affected
GPU Type: RTX 2070
Nvidia Driver Version: 510
CUDA Version: 11.6 (11.4, 11.1)
Operating System + Version: WSL2, Ubuntu 20
