X displays in a small section of screen: something in my grub setup wrong?
I have some progress with Ubuntu 4.18.0-11-generic. Here’s what I have in the /etc/default/grub file
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=menu
## GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="nosplash"
GRUB_CMDLINE_LINUX="nouveau.blacklist=1 acpi_rev_override=1 acpi_osi=Linux nouveau.modeset=0 pcie_aspm=force drm.vblankoffdelay=1 scsi_mod.use_blk_mq=1 nouveau.runpm=0 mem_sleep_default=deep"
Does this look right?
When I do this on Dell Precision 5510 with hybrid graphics, either with nvidia-390 or nvidia-415, I get a couple of funny video anomalies. THe problems I wish to understand now are the “small X11 display” and the failure of gdm3 entirely.
I’ve disabled the display manager entirely because the problems with gdm3 were baffling. Ubuntu has this program that can specify whether the graphics are only the Intel card, or will use Nvidia PRIME which, so far as I can tell, is close to the Optimus idea. User runs “sudo prime-select nvidia” to specify this. Verify the modules load
$ /sbin/lsmod | grep nvid
nvidia_uvm            786432  0
nvidia_drm             40960  4
nvidia_modeset       1110016  4 nvidia_drm
nvidia              14368768  227 nvidia_uvm,nvidia_modeset
ipmi_msghandler       102400  2 ipmi_devintf,nvidia
drm_kms_helper        172032  2 nvidia_drm,i915
drm                   458752  6 drm_kms_helper,nvidia_drm,i915
Here’s a puzzle. IF there is any xorg.conf file, the X server will not start at all if I run “startx”.
IF I run nvidia-xconfig, it creates an xorg.conf file. After that, the X server will not start at all.
After deleting /etc/X11/xorg.conf, then I can run “startx” however the X11 display is weird. It flashes for a moment “full sized” onto the laptop display, but then only a small square on bottom left is turned on. There is big black nothing top and right. I can interact with the tiny square, but the mouse cursor measurement is way off. The things displayed inside the tiny lighted-up area are “regular sized”, as if they were projected onto the full laptop display, but they are in that tiny box. So I just get a terminal and restart.
I’ve tested the same setup with “systemctl start gdm3” and I end up with black screen of death, even though I have:
$ cat /etc/gdm3/custom.conf
# GDM configuration storage
# See /usr/share/gdm/gdm.schemas for a list of available options.
[daemon]
WaylandEnable=false
After a restart, I can launch “systemctl start lightdm” and the display manager does start, using the whole screen. After that, when I log in, then I am using the full laptop display at 1920x1080. Equally importantly, I DO have access to external monitors via Thunderbolt dock.
Many parts of this are working with the newer Ubuntu kernel.
$ uname -a
Linux delllap-16 4.18.0-11-generic #12-Ubuntu SMP Tue Oct 23 19:22:37 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I have the nvidia bug file, bug no log files in /var/log/gdm3 to share to you.
nvidia-bug-report.log.gz (119 KB)
GDM is probably stumbling because of nvidia kms being turned on.
Run
grep modeset /etc/modprobe.d/*
and
grep modeset /lib/modprobe.d/*
to find the file containing
options nvidia-drm modeset=1
and change it to
options nvidia-drm modeset=0
then run
sudo update-initramfs -u
and reboot, then check if gdm works.
Getting no usable X screen after startx, you might be missing the necessary xrandr commands. E.g. create a file ~/.xinitrc containing
xrandr --setprovideroutputsource modesetting NVIDIA-0
xrandr --auto
exec xterm
should give you a plain X screen with just an xterm if you run startx as that user.
Your advice helped on one of two problems.
The ~/.xinitrc file solved problem that X was only using little corner on display. After startx, the whole display was used. It gave me the happy memory of running Slackware in 1996, when that was how Linux always looked. Thanks.
On the gdm3 problem, I’m still failing. I changed the modeset value in /lib/modprobe.d/nvidia-kms.conf and ran the initramfs. After restart, as root, I run “systemctl start gdm3” and I still get black screen with 1 underscore in white at the top left. This is puzzling because there is no log file created in /var/log/gdm3. Are these permissions correct?
drwx–x--x 2 root gdm 4096 Oct 11 2017 gdm3
Almost everything gets logged to journal now.
Please install/reinstall the package nvidia-prime.
If that doesn’t help, create the file /usr/share/gdm/greeter/autostart/optimus.desktop containing
[Desktop Entry]
Type=Application
Name=Optimus
Exec=sh -c "xrandr --setprovideroutputsource modesetting NVIDIA-0; xrandr --auto"
NoDisplay=true
X-GNOME-Autostart-Phase=DisplayServer
I get a failure, but in different way. Now I can see the screen trying to turn on X, but fails to black. In the gdm settings, I found the DEBUG setting. Thanks to your tip about the journal, I can read that. Please look toward the end of this. Is it possible this whole thing is failing because of write permissions on /var/log/prime-supported.log ???
[code]Dec 01 23:03:41 delllap-16 systemd[2337]: Stopped target Default.
Dec 01 23:03:41 delllap-16 systemd[2337]: Stopped target Basic System.
Dec 01 23:03:41 delllap-16 systemd[2337]: Stopped target Paths.
Dec 01 23:03:41 delllap-16 systemd[2337]: Stopped target Sockets.
Dec 01 23:03:41 delllap-16 systemd[2337]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Dec 01 23:03:41 delllap-16 systemd[2337]: Closed GnuPG cryptographic agent and passphrase cache.
Dec 01 23:03:41 delllap-16 systemd[2337]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec 01 23:03:41 delllap-16 systemd[2337]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Dec 01 23:03:41 delllap-16 systemd[2337]: Closed GnuPG network certificate management daemon.
Dec 01 23:03:41 delllap-16 systemd[2337]: Stopped target Timers.
Dec 01 23:03:41 delllap-16 systemd[2337]: Closed D-Bus User Message Bus Socket.
Dec 01 23:03:41 delllap-16 systemd[2337]: Reached target Shutdown.
Dec 01 23:03:41 delllap-16 systemd[2337]: Starting Exit the Session…
Dec 01 23:03:41 delllap-16 systemd[2352]: pam_unix(systemd-user:session): session closed for user root
Dec 01 23:03:41 delllap-16 systemd[1]: user-runtime-dir@0.service: Unit not needed anymore. Stopping.
Dec 01 23:03:41 delllap-16 systemd[1]: Stopped User Manager for UID 0.
Dec 01 23:03:41 delllap-16 systemd[1]: Removed slice User Slice of UID 0.
Dec 01 23:03:41 delllap-16 systemd[1]: Stopping /run/user/0 mount wrapper…
Dec 01 23:03:41 delllap-16 systemd[1]: Started GNOME Display Manager.
Dec 01 23:03:41 delllap-16 dbus-daemon[1295]: [system] Activating via systemd: service name=‘org.freedesktop.Accounts’ unit='accounts-daemon.se
Dec 01 23:03:41 delllap-16 systemd[1]: Reached target User and Group Name Lookups.
Dec 01 23:03:41 delllap-16 systemd[1]: Starting Accounts Service…
Dec 01 23:03:41 delllap-16 accounts-daemon[2484]: started daemon version 0.6.45
Dec 01 23:03:41 delllap-16 systemd[1]: Stopped /run/user/0 mount wrapper.
Dec 01 23:03:41 delllap-16 dbus-daemon[1295]: [system] Successfully activated service ‘org.freedesktop.Accounts’
Dec 01 23:03:41 delllap-16 systemd[1]: Started Accounts Service.
Dec 01 23:03:41 delllap-16 gdm-launch-environment][2498]: pam_unix(gdm-launch-environment:session): session opened for user gdm by root(uid=0)
Dec 01 23:03:41 delllap-16 gdm-launch-environment][2498]: pam_sss(gdm-launch-environment:session): Request to sssd failed. Connection refused
Dec 01 23:03:41 delllap-16 systemd[1]: Created slice User Slice of UID 1002.
Dec 01 23:03:41 delllap-16 systemd[1]: Started /run/user/1002 mount wrapper.
Dec 01 23:03:41 delllap-16 systemd[1]: Starting User Manager for UID 1002…
Dec 01 23:03:41 delllap-16 systemd-logind[1257]: New session c1 of user gdm.
Dec 01 23:03:41 delllap-16 systemd[1]: Started Session c1 of user gdm.
Dec 01 23:03:41 delllap-16 systemd[2551]: pam_unix(systemd-user:session): session opened for user gdm by (uid=0)
Dec 01 23:03:41 delllap-16 systemd[2551]: Listening on Sound System.
Dec 01 23:03:41 delllap-16 systemd[2551]: Reached target Paths.
Dec 01 23:03:41 delllap-16 systemd[2551]: Starting D-Bus User Message Bus Socket.
Dec 01 23:03:41 delllap-16 systemd[2551]: Listening on GnuPG network certificate management daemon.
Dec 01 23:03:41 delllap-16 systemd[2551]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Dec 01 23:03:41 delllap-16 systemd[2551]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec 01 23:03:41 delllap-16 systemd[2551]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Dec 01 23:03:41 delllap-16 systemd[2551]: Listening on GnuPG cryptographic agent and passphrase cache.
Dec 01 23:03:41 delllap-16 systemd[2551]: Reached target Timers.
Dec 01 23:03:41 delllap-16 systemd[2551]: Listening on D-Bus User Message Bus Socket.
Dec 01 23:03:41 delllap-16 systemd[2551]: Reached target Sockets.
Dec 01 23:03:41 delllap-16 systemd[2551]: Reached target Basic System.
Dec 01 23:03:41 delllap-16 systemd[2551]: Reached target Default.
Dec 01 23:03:41 delllap-16 systemd[2551]: Startup finished in 36ms.
Dec 01 23:03:41 delllap-16 systemd[1]: Started User Manager for UID 1002.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (–) Log file renamed from “/var/log/Xorg.pid-2601.log” to “/var/log/Xorg.0.log”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: X.Org X Server 1.20.1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: X Protocol Version 11, Revision 0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Build Operating System: Linux 4.4.0-138-generic x86_64 Ubuntu
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Current Operating System: Linux delllap-16 4.18.0-11-generic #12-Ubuntu SMP Tue O
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.18.0-11-generic root=UUID=58f6c75
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Build Date: 25 October 2018 02:53:34PM
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: xorg-server 2:1.20.1-3ubuntu2.1 (For technical support please see http://www.ubun
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Current version of pixman: 0.34.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Before reporting problems, check http://wiki.x.org
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: to make sure that you have the latest version.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Markers: (–) probed, () from config file, (==) default setting,
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (++) from command line, (!!) notice, (II) informational,
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Log file: “/var/log/Xorg.0.log”, Time: Sat Dec 1 23:03:41 2018
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) No Layout section. Using the first Screen section.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) No screen section available. Using defaults.
) |–>Screen “Default Screen Section” (0)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () | |–>Monitor “”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) No monitor specified for screen “Default Screen Section”.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Using a default monitor configuration.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Automatically adding devices
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Automatically enabling devices
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Automatically adding GPU devices
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Automatically binding GPU devices
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Max clients allowed: 256, resource mask: 0x1fffff
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Entry deleted from font path.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) FontPath set to:
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: /usr/share/fonts/X11/misc,
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: /usr/share/fonts/X11/Type1,
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: built-ins
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) ModulePath set to “/usr/lib/xorg/modules”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) The server relies on udev to provide the list of input devices.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: If no devices become available, reconfigure udev or disable AutoAddDevice
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loader magic: 0x561ee311c020
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module ABI versions:
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: X.Org ANSI C Emulation: 0.4
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: X.Org Video Driver: 24.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: X.Org XInput driver : 24.1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: X.Org Server Extension : 10.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (++) using VT number 1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) xfree86: Adding drm device (/dev/dri/card1)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) xfree86: Adding drm device (/dev/dri/card0)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
) OutputClass “nvidia” ModulePath extended to "/usr/lib/x86_64-linux-gnu/xorg,
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () OutputClass “Nvidia Prime” ModulePath extended to "/x86_64-linux-gnu/nvidia/
) OutputClass “Nvidia Prime” setting /dev/dri/card1 as PrimaryGPU
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (–) PCI: (0@0:2:0) 8086:191b:1028:06e5 rev 6, Mem @ 0xdb000000/16777216, 0x70000
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (–) PCI:*(1@0:0:0) 10de:13b1:1028:06e5 rev 162, Mem @ 0xdc000000/16777216, 0xb00
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “glx”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module glx: vendor=“X.Org Foundation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: compiled for 1.20.1, module version = 1.0.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: ABI class: X.Org Server Extension, version 10.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Applying OutputClass “nvidia” to /dev/dri/card1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: loading driver: nvidia
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Applying OutputClass “Nvidia Prime” to /dev/dri/card1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Matched nvidia as autoconfigured driver 0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Matched nouveau as autoconfigured driver 1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Matched modesetting as autoconfigured driver 2
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Matched fbdev as autoconfigured driver 3
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Matched vesa as autoconfigured driver 4
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) Assigned the driver to the xf86ConfigLayout
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “nvidia”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/x86_64-linux-gnu/xorg/nvidia_drv.so
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module nvidia: vendor=“NVIDIA Corporation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: compiled for 4.0.2, module version = 1.0.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Module class: X.Org Video Driver
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “nouveau”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module nouveau: vendor=“X.Org Foundation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: compiled for 1.20.0, module version = 1.0.15
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: ABI class: X.Org Video Driver, version 24.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “modesetting”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module modesetting: vendor=“X.Org Foundation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: compiled for 1.20.1, module version = 1.20.1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “fbdev”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module fbdev: vendor=“X.Org Foundation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: compiled for 1.20.1, module version = 0.5.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “vesa”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module vesa: vendor=“X.Org Foundation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: compiled for 1.20.0, module version = 2.4.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA dlloader X Driver 410.78 Sat Nov 10 22:15:52 CST 2018
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NOUVEAU driver Date: Fri Apr 21 14:41:17 2017 -0400
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NOUVEAU driver for NVIDIA chipset families :
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: RIVA TNT (NV04)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: RIVA TNT2 (NV05)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce 256 (NV10)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce 2 (NV11, NV15)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce 4MX (NV17, NV18)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce 3 (NV20)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce 4Ti (NV25, NV28)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce FX (NV3x)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce 6 (NV4x)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce 7 (G7x)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce 8 (G8x)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce GTX 200 (NVA0)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: GeForce GTX 400 (NVC0)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) FBDEV: driver for framebuffer: fbdev
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) VESA: driver for VESA chipsets: vesa
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) systemd-logind: releasing fd for 226:1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading sub module “fb”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “fb”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/xorg/modules/libfb.so
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module fb: vendor=“X.Org Foundation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: ABI class: X.Org ANSI C Emulation, version 0.4
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading sub module “wfb”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “wfb”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/xorg/modules/libwfb.so
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module wfb: vendor=“X.Org Foundation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading sub module “ramdac”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “ramdac”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module “ramdac” already built-in
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (WW) Falling back to old probe method for modesetting
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (WW) Falling back to old probe method for fbdev
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading sub module “fbdevhw”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “fbdevhw”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module fbdevhw: vendor=“X.Org Foundation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: compiled for 1.20.1, module version = 0.0.2
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): using drv /dev/dri/card0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA(0): Creating default Display subsection in Screen section
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: “Default Screen Section” for depth/fbbpp 24/32
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) NVIDIA(0): RGB weight 888
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) NVIDIA(0): Default visual is TrueColor
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Applying OutputClass “nvidia” options to /dev/dri/card1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Applying OutputClass “Nvidia Prime” options to /dev/dri/card1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () NVIDIA(0): Option “AllowEmptyInitialConfiguration”
) NVIDIA(0): Option “IgnoreDisplayDevices” “CRT”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () NVIDIA(0): Enabling 2D acceleration
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading sub module “glxserver_nvidia”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “glxserver_nvidia”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/x86_64-linux-gnu/xorg/libglxserver_nvidia.so
Dec 01 23:03:41 delllap-16 systemd[1]: Starting NVIDIA Persistence Daemon…
Dec 01 23:03:41 delllap-16 nvidia-persistenced[2612]: Verbose syslog connection opened
Dec 01 23:03:41 delllap-16 nvidia-persistenced[2612]: Now running with user ID 103 and group ID 116
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Module class: X.Org Server Extension
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA GLX Module 410.78 Sat Nov 10 22:12:55 CST 2018
Dec 01 23:03:41 delllap-16 nvidia-persistenced[2612]: Started (2612)
Dec 01 23:03:41 delllap-16 nvidia-persistenced[2612]: device 0000:01:00.0 - registered
Dec 01 23:03:41 delllap-16 nvidia-persistenced[2612]: Local RPC services initialized
Dec 01 23:03:41 delllap-16 systemd[1]: Started NVIDIA Persistence Daemon.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA(0): NVIDIA GPU Quadro M1000M (GM107GL-A) at PCI:1:0:0 (GPU-0)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (–) NVIDIA(0): Memory: 2097152 kBytes
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (–) NVIDIA(0): VideoBIOS: 82.07.82.00.29
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA(0): Detected PCI Express Link width: 16X
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA(0): Validated MetaModes:
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA(0): “NULL”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (WW) NVIDIA(0): Unable to get display device for DPI computation.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) modeset(G0): RGB weight 888
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) modeset(G0): Default visual is TrueColor
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading sub module “glamoregl”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “glamoregl”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/xorg/modules/libglamoregl.so
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module glamoregl: vendor=“X.Org Foundation”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: compiled for 1.20.1, module version = 1.0.1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): glamor X acceleration enabled on Mesa DRI Intel® HD Graphics
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): glamor initialized
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Output eDP-1-1 has no monitor section
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Output DP-1-1 has no monitor section
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Output HDMI-1-1 has no monitor section
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Output DP-1-2 has no monitor section
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Output HDMI-1-2 has no monitor section
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): EDID for output eDP-1-1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Manufacturer: SHP Model: 1453 Serial#: 0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Year: 2015 Week: 40
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): EDID Version: 1.4
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Digital Display Input
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): 8 bits per channel
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Digital interface is DisplayPort
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Max Image Size [cm]: horiz.: 35 vert.: 19
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Gamma: 2.20
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): No DPMS capabilities specified
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Default color space is primary color space
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): First detailed timing is preferred mode
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Preferred mode is native pixel format and refresh rate
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): redX: 0.640 redY: 0.329 greenX: 0.300 greenY: 0.600
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): blueX: 0.149 blueY: 0.060 whiteX: 0.312 whiteY: 0.328
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Manufacturer’s mask: 0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Supported detailed timing:
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): clock: 138.5 MHz Image Size: 346 x 194 mm
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1111
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: [32B blob data]
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Unknown vendor-specific block 0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): EDID (in hex):
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): 00ffffffffffff004d10531400000000
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): 28190104a52313780ede50a3544c9926
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): 0f505400000001010101010101010101
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): 0101010101011a3680a070381f403020
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): 35005ac2100000180000000000000000
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): 00000000000000000000000000fe0031
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): 3230334d804c513135364d3100000000
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): 0002410328001200000a010a2020004b
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Printing probed modes for output eDP-1-1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 -hsync -vsync (66.6 k
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 k
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 k
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1600x1024"x60.2 103.12 1600 1600 1656 1664 1024 1024 1029 1030 +hsync +vsync (62.0 k
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 k
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 k
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (9
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (7
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (6
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "800x512"x120.3 51.56 800 800 828 832 512 512 514 515 doublescan +hsync +vsync (62.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "720x450"x119.8 53.25 720 760 836 952 450 451 454 467 doublescan -hsync +vsync (55.9
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "680x384"x119.6 42.38 680 716 784 888 384 385 390 399 doublescan -hsync +vsync (47.7
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "680x384"x119.9 36.00 680 704 720 760 384 385 390 395 doublescan +hsync -vsync (47.4
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "576x432"x120.1 40.81 576 608 668 760 432 432 434 447 doublescan -hsync +vsync (53.7
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): EDID for output DP-1-1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): EDID for output HDMI-1-1
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): EDID for output DP-1-2
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): EDID for output HDMI-1-2
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) modeset(G0): DPI set to (96, 96)
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) UnloadModule: “nouveau”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Unloading nouveau
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) UnloadModule: “fbdev”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Unloading fbdev
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) UnloadSubModule: “fbdevhw”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Unloading fbdevhw
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) UnloadModule: “vesa”
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Unloading vesa
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) modeset(G0): Backing store enabled
Dec 01 23:03:41 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) modeset(G0): Silken mouse enabled
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) modeset(G0): DPMS enabled
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): [DRI2] Setup complete
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): [DRI2] DRI driver: i965
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): [DRI2] VDPAU driver: i965
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA: access.
Dec 01 23:03:42 delllap-16 acpid[1293]: client connected from 2601[0:0]
Dec 01 23:03:42 delllap-16 acpid[1293]: 1 client rule loaded
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA(0): Setting mode “NULL”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) NVIDIA(0): Disabling shared memory pixmaps
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) NVIDIA(0): Backing store enabled
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) NVIDIA(0): Silken mouse enabled
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (==) NVIDIA(0): DPMS enabled
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (WW) NVIDIA(0): Option “PrimaryGPU” is not used
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading sub module “dri2”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “dri2”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module “dri2” already built-in
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA(0): [DRI2] Setup complete
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension Generic Event Extension
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension SHAPE
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension MIT-SHM
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension XInputExtension
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension XTEST
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension BIG-REQUESTS
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension SYNC
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension XKEYBOARD
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension XC-MISC
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension SECURITY
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension XFIXES
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension RENDER
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension RANDR
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension COMPOSITE
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension DAMAGE
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension MIT-SCREEN-SAVER
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension DOUBLE-BUFFER
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension RECORD
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension DPMS
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension Present
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension DRI3
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension X-Resource
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension XVideo
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension XVideo-MotionCompensation
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension SELinux
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) SELinux: Disabled on system
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension GLX
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Indirect GLX disabled.
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) GLX: Another vendor is already registered for screen 0
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension XFree86-VidModeExtension
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension XFree86-DGA
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension XFree86-DRI
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension DRI2
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension NV-GLX
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Initializing extension NV-CONTROL
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) modeset(G0): Damage tracking initialized
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) config/udev: Adding input device Power Button (/dev/input/event3)
) Power Button: Applying InputClass “evdev keyboard catchall”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Power Button: Applying InputClass “libinput keyboard catchall”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) LoadModule: “libinput”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Module libinput: vendor=“X.Org Foundation”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: compiled for 1.20.1, module version = 0.28.1
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: Module class: X.Org XInput Driver
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: ABI class: X.Org XInput driver, version 24.1
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Using input driver ‘libinput’ for ‘Power Button’
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 44 paused 0
) Power Button: always reports core events
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Option “Device” “/dev/input/event3”
) Option “_source” “server/udev”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event3 - Power Button: is tagged by udev as: Keyboard
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event3 - Power Button: device is a keyboard
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event3 - Power Button: device removed
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
) Option “xkb_model” “pc105”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Option “xkb_layout” “us”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) config/udev: Adding input device Video Bus (/dev/input/event5)
) Video Bus: Applying InputClass “evdev keyboard catchall”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Video Bus: Applying InputClass “libinput keyboard catchall”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) Using input driver ‘libinput’ for ‘Video Bus’
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 47 paused 0
) Video Bus: always reports core events
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Option “Device” “/dev/input/event5”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event5 - Video Bus: is tagged by udev as: Keyboard
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event5 - Video Bus: device is a keyboard
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event5 - Video Bus: device removed
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6/event5”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 7)
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) config/udev: Adding input device Video Bus (/dev/input/event6)
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 48 paused 0
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Option “Device” “/dev/input/event6”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event6 - Video Bus: is tagged by udev as: Keyboard
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event6 - Video Bus: device is a keyboard
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event6 - Video Bus: device removed
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Option “config_info” "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0a/LNXVIDEO:01/input/input7/
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 8)
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) config/udev: Adding input device Power Button (/dev/input/event1)
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 49 paused 0
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Option “Device” “/dev/input/event1”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event1 - Power Button: is tagged by udev as: Keyboard
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event1 - Power Button: device is a keyboard
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) event1 - Power Button: device removed
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 9)
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (**) Option “xkb_layout” “us”
Dec 01 23:03:42 delllap-16 /usr/lib/gdm3/gdm-x-session[2590]: (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
It’s truncated, please attach as file.
Sorry.
I restarted system and now attach full output from “journalctl -b” and also attach a new copy of the nvidia-bug-report script. gdm3 does not display. I’m able to stop gdm3 and launch lightdm without trouble. I do have debug details enabled in gdm3 custom config.
jrnl.txt.gz (50.6 KB)
nvidia-bug-report.log.gz (1.03 MB)
That looks rather odd, the home directory of gdm seems to be incorrectly set. Did you already purge gdm, delete the user gdm and then reinstall it?
You got that right. The /home/gdm was owned by gdm.gdm with rwx. I wonder what was wrong with that? If you could explain what you saw, I think we can help more Ubuntu users.
I had some trouble removing the gdm3 package. Package system resisted removing b/c gnome depended on it. I had force remove/purge. It failed to remove gdm user and /home/gdm. I manually removed gdm user and group and home folder. After reboot and 2 gdm3 reinstalls, I have new gdm user. It did not create /home/gdm3 again. After that, gdm3 will start. Only config change I made was to uncomment the EnableWayland=false in gdm3 custom_conf.
How do you like this theory? Perhaps in Ubuntu 16.04 or such, there was a different gdm config. They were moving from lightdm to gdm. Because of the way the Deb system saves config info on removed packages, then new gdm inherited some funny settings. Removing gdm was not enough, settings persisted. Then I got mad at gdm and quit trying for a year or two. Then you solved it.
Why don’t I have/need /home/gdm anymore?
Also interesting to me is that old gdm user had number 1002 in /etc/passwd. New one has number under 500.
Something must have failed during the initial install so gdm was created as normal user (uid>=1000, homedir in /home) instead of a system user (uid<1000, homedir /var/lib/gdm) so it failed to run.
