X server 1.21.1.4 crashes after a while when using remote desktop in ubuntu 22.04.1
After successfully using a remote desktop session, the Xserver suddenly crashes. Time of crash seems to be random. dmsg reports GPU fallen from off the bus. PC is accessible by ssh.
To reproduce the problem: start ubuntu, enable remote desktop, connect from other ubuntu system. Randomly wait until the eror happens.
Thanks in advance.
-Attached, nvidia-bug-report.log.gz
nvidia-bug-report.log.gz (222.2 KB)
System details:
uname -a
Linux 4090Desktop 6.8.0-52-generic #53~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Wed Jan 15 19:18:46 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
sudo X -version
X.Org X Server 1.21.1.4
X Protocol Version 11, Revision 0
Current Operating System: Linux 4090Desktop 6.8.0-52-generic #53~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Wed Jan 15 19:18:46 UTC 2 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.8.0-52-generic root=UUID=756cd848-b158-4527-ad4d-56723ec0be92 ro quiet splash vt.handoff=7
xorg-server 2:21.1.4-2ubuntu1.7~22.04.12
sudo lshw
4090desktop
description: Desktop Computer
product: System Product Name (SKU)
vendor: ASUS
version: System Version
serial: System Serial Number
width: 64 bits
capabilities: smbios-3.5.0 dmi-3.5.0 smp vsyscall32
configuration: boot=normal chassis=desktop family=To be filled by O.E.M. sku=SKU uuid=3fecf86b-f949-2bab-375c-c87f5459d18b
*-core
description: Motherboard
product: PRIME Z790-P WIFI
vendor: ASUSTeK COMPUTER INC.
physical id: 0
version: Rev 1.xx
serial: 221113232402060
slot: Default string
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: 0806
date: 11/22/2022
capacity: 16MiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int14serial int17printer int10video acpi usb biosbootspecification uefi
*-memory
description: System Memory
physical id: c
slot: System board or motherboard
*-bank:0
description: [empty]
physical id: 0
slot: Controller0-DIMM0
*-bank:1
description: DIMM Synchronous 4800 MHz (0.2 ns)
product: F5-6000J3636F16G
vendor: G Skill Intl
physical id: 1
serial: 00000000
slot: Controller0-DIMM1
width: 64 bits
clock: 505MHz (2.0ns)
*-bank:2
physical id: 2
slot: Controller1-DIMM0
*-bank:3
physical id: 3
serial: 00000000
slot: Controller1-DIMM1
width: 64 bits
*-cache:0
description: L1 cache
physical id: 1b
slot: L1 Cache
capacity: 384KiB
capabilities: synchronous internal write-back data
configuration: level=1
*-cache:1
physical id: 1c
slot: L1 Cache
capacity: 256KiB
capabilities: synchronous internal write-back instruction
*-cache:2
description: L2 cache
physical id: 1d
slot: L2 Cache
capacity: 16MiB
capabilities: synchronous internal write-back unified
configuration: level=2
*-cache:3
description: L3 cache
physical id: 1e
slot: L3 Cache
capacity: 30MiB
configuration: level=3
*-cache:4
physical id: 1f
slot: L1 Cache
capacity: 256KiB
*-cache:5
physical id: 20
slot: L1 Cache
capacity: 512KiB
*-cache:6
physical id: 21
slot: L2 Cache
capacity: 8MiB
*-cache:7
physical id: 22
slot: L3 Cache
capacity: 30MiB
*-cpu
description: CPU
product: 13th Gen Intel(R) Core™ i7-13700K
vendor: Intel Corp.
physical id: 23
bus info: cpu@0
version: 6.183.1
serial: To Be Filled By O.E.M.
slot: LGA1700
capacity: 5300MHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect user_shstk avx_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req hfi vnmi umip pku ospke waitpkg gfni vaes vpclmulqdq tme rdpid movdiri movdir64b fsrm md_clear serialize pconfig arch_lbr ibt flush_l1d arch_capabilities cpufreq
configuration: cores=16 enabledcores=16 microcode=299 threads=24
*-pci
description: Host bridge
product: Intel Corporation
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 01
width: 32 bits
clock: 33MHz
*-pci:0
description: PCI bridge
physical id: 1
bus info: pci@0000:00:01.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:121 ioport:7000(size=4096) memory:84000000-850fffff ioport:4000000000(size=34393292800)
*-generic:0
description: Unassigned class
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/fb0
version: ff
width: 32 bits
clock: 66MHz
capabilities: bus_master vga_palette cap_list rom fb
configuration: depth=32 driver=nvidia latency=255 maxlatency=255 mingnt=255 resolution=1920,1080
resources: irq:218 memory:84000000-84ffffff memory:4000000000-47ffffffff memory:4800000000-4801ffffff ioport:7000(size=128) memory:85000000-8507ffff
*-generic:1
physical id: 0.1
bus info: pci@0000:01:00.1
logical name: card1
logical name: /dev/snd/controlC1
logical name: /dev/snd/hwC1D0
logical name: /dev/snd/pcmC1D3p
logical name: /dev/snd/pcmC1D7p
logical name: /dev/snd/pcmC1D8p
logical name: /dev/snd/pcmC1D9p
version: ff
width: 32 bits
clock: 66MHz
configuration: driver=snd_hda_intel latency=255 maxlatency=255 mingnt=255
resources: irq:17 memory:85080000-85083fff
*-input:0
product: HDA NVidia HDMI/DP,pcm=3
physical id: 0
logical name: input21
logical name: /dev/input/event8
*-input:1
product: HDA NVidia HDMI/DP,pcm=7
physical id: 1
logical name: input22
logical name: /dev/input/event10
*-input:2
product: HDA NVidia HDMI/DP,pcm=8
physical id: 2
logical name: input23
logical name: /dev/input/event12
*-input:3
product: HDA NVidia HDMI/DP,pcm=9
physical id: 3
logical name: input24
logical name: /dev/input/event13
*-pci:1
physical id: 6
bus info: pci@0000:00:06.0
version: 01
width: 32 bits
clock: 33MHz
resources: irq:122 memory:87100000-871fffff
*-nvme
description: NVMe device
product: KINGSTON SFYRS1000G
vendor: Kingston Technology Company, Inc.
physical id: 0
bus info: pci@0000:02:00.0
logical name: /dev/nvme0
version: EIFK31.6
serial: 50026B76861670A2
width: 64 bits
clock: 33MHz
capabilities: nvme pciexpress msix msi pm nvm_express bus_master cap_list
configuration: driver=nvme latency=0 nqn=nqn.2020-04.com.kingston:nvme:nvm-subsystem-sn-50026B76861670A2 state=live
resources: irq:16 memory:87100000-87103fff
*-namespace:0
description: NVMe disk
physical id: 0
logical name: hwmon1
*-namespace:1
physical id: 2
logical name: /dev/ng0n1
*-namespace:2
physical id: 1
bus info: nvme@0:1
logical name: /dev/nvme0n1
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: guid=83a551f6-80a0-4af1-aadd-34a4a8c6ad9a logicalsectorsize=512 sectorsize=512 wwid=eui.00000000000000000026b76861670a25
*-volume:0
description: Windows FAT volume
vendor: MSDOS5.0
physical id: 1
bus info: nvme@0:1,1
logical name: /dev/nvme0n1p1
logical name: /boot/efi
version: FAT32
serial: 664a-3971
capacity: 99MiB
capabilities: boot nomount fat initialized
configuration: FATs=2 filesystem=fat mount.fstype=vfat mount.options=rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro name=EFI system partition state=mounted
*-volume:1
description: reserved partition
vendor: Windows
physical id: 2
bus info: nvme@0:1,2
logical name: /dev/nvme0n1p2
serial: 495b0eff-693b-4a88-816d-00a817fde742
capacity: 15MiB
capabilities: nofs nomount
configuration: name=Microsoft reserved partition
*-volume:2
description: Windows NTFS volume
vendor: Windows
physical id: 3
bus info: nvme@0:1,3
logical name: /dev/nvme0n1p3
version: 3.1
serial: 6c0be95f-8687-a34a-9250-ee590b5c74dd
capacity: 930GiB
capabilities: ntfs initialized
configuration: clustersize=4096 created=2023-01-27 01:25:27 filesystem=ntfs name=Basic data partition state=dirty
*-volume:3
vendor: Windows
physical id: 4
bus info: nvme@0:1,4
logical name: /dev/nvme0n1p4
version: 3.1
serial: 0caa-ad63
capacity: 712MiB
capabilities: boot precious nomount ntfs initialized
configuration: clustersize=4096 created=2024-10-08 15:23:14 filesystem=ntfs state=clean
*-generic
description: Signal processing controller
physical id: a
bus info: pci@0000:00:0a.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pciexpress pm cap_list fb
configuration: depth=32 driver=intel_vsec latency=0 mode=1920x1080 visual=truecolor xres=1920 yres=1080
resources: iomemory:480-47f irq:0 memory:4804210000-4804217fff
*-raid
description: RAID bus controller
physical id: e
bus info: pci@0000:00:0e.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: raid msix pciexpress pm bus_master cap_list
configuration: driver=vmd latency=0
resources: iomemory:480-47f iomemory:480-47f irq:0 memory:4802000000-4803ffffff memory:82000000-83ffffff memory:4804100000-48041fffff
*-usb
description: USB controller
physical id: 14
bus info: pci@0000:00:14.0
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: iomemory:480-47f irq:149 memory:4804200000-480420ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 6.8.0-52-generic xhci-hcd
physical id: 0
bus info: usb@1
logical name: usb1
version: 6.08
capabilities: usb-2.00
configuration: driver=hub slots=16 speed=480Mbit/s
*-usb:0
description: Human interface device
product: AURA LED Controller
vendor: AsusTek Computer Inc.
physical id: 2
bus info: usb@1:2
version: 1.00
serial: 9876543210
configuration: driver=usbhid maxpower=16mA speed=12Mbit/s
*-usb:1
description: USB hub
product: USB2.0 Hub
vendor: VIA Labs, Inc.
physical id: 6
bus info: usb@1:6
version: 3.f4
capabilities: usb-2.10
configuration: driver=hub slots=4 speed=480Mbit/s
*-usb
description: Keyboard
product: USB Receiver
vendor: Logitech
physical id: 3
bus info: usb@1:6.3
version: 12.10
configuration: driver=usbhid maxpower=98mA speed=12Mbit/s
*-input:0
product: Logitech Wireless Mouse
physical id: 0
logical name: input17
logical name: /dev/input/event3
logical name: /dev/input/mouse0
capabilities: usb
*-input:1
product: Logitech K520
physical id: 1
logical name: input18
logical name: /dev/input/event4
logical name: input18::capslock
logical name: input18::compose
logical name: input18::kana
logical name: input18::numlock
logical name: input18::scrolllock
capabilities: usb
*-usb:2
product: USB2.0 Hub
vendor: Genesys Logic, Inc.
physical id: b
bus info: usb@1:b
version: 60.90
configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
*-usb
product: HP Basic USB Keyboard
vendor: CHICONY
physical id: 2
bus info: usb@1:b.2
version: 3.00
capabilities: usb-1.10
configuration: driver=usbhid maxpower=100mA speed=2Mbit/s
*-usb:3
product: USB2.0 Hub
physical id: d
bus info: usb@1:d
version: 60.90
*-usb
product: H100iELITE
vendor: Corsair Inc.
physical id: 3
bus info: usb@1:d.3
version: 1.00
configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
*-usb:4
description: Bluetooth wireless interface
product: AX201 Bluetooth
vendor: Intel Corp.
physical id: e
bus info: usb@1:e
version: 0.02
capabilities: bluetooth usb-2.01
configuration: driver=btusb maxpower=100mA speed=12Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 6.08
capabilities: usb-3.10
configuration: driver=hub slots=9 speed=10000Mbit/s
*-usb
product: USB3.0 Hub
physical id: 5
bus info: usb@2:5
version: 3.f4
configuration: driver=hub slots=4 speed=5000Mbit/s
*-memory UNCLAIMED
description: RAM memory
physical id: 14.2
bus info: pci@0000:00:14.2
version: 11
width: 64 bits
clock: 33MHz (30.3ns)
capabilities: pm cap_list
configuration: latency=0
resources: iomemory:480-47f iomemory:480-47f memory:4804228000-480422bfff memory:4804231000-4804231fff
*-network DISABLED
description: Wireless interface
physical id: 14.3
bus info: pci@0000:00:14.3
logical name: wlp0s20f3
version: 11
serial: 84:14:4d:0c:50:e4
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=6.8.0-52-generic firmware=86.fb5c9aeb.0 so-a0-hr-b0-86.uc latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: iomemory:480-47f irq:18 memory:4804224000-4804227fff
*-serial:0
description: Serial bus controller
physical id: 15
bus info: pci@0000:00:15.0
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=intel-lpss latency=0
resources: irq:27 memory:4804218000-4804218fff
*-serial:1
physical id: 15.1
bus info: pci@0000:00:15.1
version: 11
width: 64 bits
clock: 33MHz
resources: irq:40 memory:4804219000-4804219fff
*-serial:2
physical id: 15.2
bus info: pci@0000:00:15.2
version: 11
width: 64 bits
clock: 33MHz
resources: irq:29 memory:480421a000-480421afff
*-communication
description: Communication controller
physical id: 16
bus info: pci@0000:00:16.0
version: 11
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_me latency=0
resources: iomemory:480-47f irq:200 memory:480422d000-480422dfff
*-sata
description: SATA controller
physical id: 17
bus info: pci@0000:00:17.0
version: 11
width: 32 bits
clock: 66MHz
capabilities: sata msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:148 memory:87200000-87201fff memory:87203000-872030ff ioport:8050(size=8) ioport:8040(size=4) ioport:8020(size=32) memory:87202000-872027ff
*-pci:2
physical id: 1a
bus info: pci@0000:00:1a.0
version: 11
width: 32 bits
clock: 33MHz
resources: irq:123 ioport:6000(size=4096) memory:86500000-86efffff ioport:4804300000(size=2097152)
*-pci:3
physical id: 1b
bus info: pci@0000:00:1b.0
version: 11
width: 32 bits
clock: 33MHz
resources: irq:124
*-pci:4
physical id: 1c
bus info: pci@0000:00:1c.0
version: 11
width: 32 bits
clock: 33MHz
resources: irq:125 ioport:5000(size=4096) memory:85b00000-864fffff ioport:4804500000(size=2097152)
*-pci:5
physical id: 1c.2
bus info: pci@0000:00:1c.2
version: 11
width: 32 bits
clock: 33MHz
resources: irq:126 ioport:4000(size=4096) memory:87000000-870fffff
*-network
description: Ethernet interface
product: RTL8125 2.5GbE Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:06:00.0
logical name: eno1
version: 05
serial: c8:7f:54:59:d1:8b
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.8.0-52-generic duplex=full firmware=rtl8125b-2_0.0.2 07/13/20 ip=192.168.1.41 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:18 ioport:4000(size=256) memory:87000000-8700ffff memory:87010000-87013fff
*-pci:6
physical id: 1d
bus info: pci@0000:00:1d.0
version: 11
width: 32 bits
clock: 33MHz
resources: irq:127 ioport:3000(size=4096) memory:85100000-85afffff ioport:4804700000(size=2097152)
*-pci:7
physical id: 1d.4
bus info: pci@0000:00:1d.4
version: 11
width: 32 bits
clock: 33MHz
resources: irq:128 memory:86f00000-86ffffff
*-nvme
product: Samsung SSD 990 EVO 1TB
vendor: Samsung Electronics Co Ltd
physical id: 0
bus info: pci@0000:08:00.0
logical name: /dev/nvme1
version: 0B2QKXJ7
serial: S7M3NL0X831269H
width: 64 bits
clock: 33MHz
capabilities: nvme pm msi pciexpress msix nvm_express bus_master cap_list
configuration: driver=nvme latency=0 nqn=nqn.1994-11.com.samsung:nvme:990EVO:M.2:S7M3NL0X831269H state=live
resources: irq:16 memory:86f00000-86f03fff
*-namespace:0
physical id: 0
logical name: hwmon2
*-namespace:1
physical id: 2
logical name: /dev/ng1n1
*-namespace:2
physical id: 1
bus info: nvme@1:1
logical name: /dev/nvme1n1
configuration: guid=890f09ab-3dab-4e0c-b3f5-1bd6b2a2cac0 logicalsectorsize=512 sectorsize=512 wwid=eui.0025382841a0dbad
*-volume:0
vendor: mkfs.fat
physical id: 1
bus info: nvme@1:1,1
logical name: /dev/nvme1n1p1
version: FAT32
serial: 741d-abcf
capacity: 1074MiB
capabilities: boot fat initialized
*-volume:1
description: EXT4 volume
vendor: Linux
physical id: 2
bus info: nvme@1:1,2
logical name: /dev/nvme1n1p2
logical name: /
logical name: /var/snap/firefox/common/host-hunspell
version: 1.0
serial: 756cd848-b158-4527-ad4d-56723ec0be92
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2025-01-19 06:57:25 filesystem=ext4 lastmountpoint=/ modified=2025-02-14 06:23:48 mount.fstype=ext4 mount.options=ro,noexec,noatime,errors=remount-ro mounted=2025-02-14 06:23:49 state=mounted
*-isa
description: ISA bridge
physical id: 1f
bus info: pci@0000:00:1f.0
version: 11
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
*-pnp00:00
product: PnP device PNP0c02
physical id: 0
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: PnP device PNP0501
physical id: 1
capabilities: pnp
configuration: driver=serial
*-pnp00:02
physical id: 2
capabilities: pnp
*-pnp00:03
physical id: 3
capabilities: pnp
*-pnp00:04
physical id: 4
capabilities: pnp
*-pnp00:05
physical id: 5
capabilities: pnp
*-pnp00:06
physical id: 6
capabilities: pnp
*-multimedia
description: Audio device
physical id: 1f.3
bus info: pci@0000:00:1f.3
logical name: card0
logical name: /dev/snd/controlC0
logical name: /dev/snd/hwC0D0
logical name: /dev/snd/pcmC0D0c
logical name: /dev/snd/pcmC0D0p
logical name: /dev/snd/pcmC0D1p
logical name: /dev/snd/pcmC0D2c
version: 11
width: 64 bits
clock: 33MHz
configuration: driver=snd_hda_intel latency=32
resources: iomemory:480-47f iomemory:480-47f irq:217 memory:4804220000-4804223fff memory:4804000000-48040fffff
*-input:0
product: HDA Intel PCH Front Mic
physical id: 0
logical name: input25
logical name: /dev/input/event9
*-input:1
product: HDA Intel PCH Rear Mic
physical id: 1
logical name: input26
logical name: /dev/input/event11
*-input:2
product: HDA Intel PCH Line
physical id: 2
logical name: input27
logical name: /dev/input/event14
*-input:3
product: HDA Intel PCH Line Out
physical id: 3
logical name: input28
logical name: /dev/input/event15
*-input:4
product: HDA Intel PCH Front Headphone
physical id: 4
logical name: input29
logical name: /dev/input/event16
*-serial:3
description: SMBus
physical id: 1f.4
bus info: pci@0000:00:1f.4
version: 11
width: 64 bits
clock: 33MHz
configuration: driver=i801_smbus latency=0
resources: iomemory:480-47f irq:18 memory:480422c000-480422c0ff ioport:efa0(size=32)
*-serial:4
physical id: 1f.5
bus info: pci@0000:00:1f.5
version: 11
width: 32 bits
clock: 33MHz
configuration: driver=intel-spi latency=0
resources: irq:0 memory:80800000-80800fff
*-input:0
product: Sleep Button
physical id: 1
logical name: input0
logical name: /dev/input/event0
capabilities: platform
*-input:1
product: Power Button
physical id: 2
*-input:2
product: Eee PC WMI hotkeys
physical id: 3
logical name: input19
logical name: /dev/input/event5
*-input:3
physical id: 4
logical name: /dev/input/event2
*-input:4
product: Asus WMI hotkeys
physical id: 5
logical name: input20
logical name: /dev/input/event6
*-input:5
product: CHICONY HP Basic USB Keyboard
physical id: 6
logical name: input8
logical name: /dev/input/event7
logical name: input8::capslock
logical name: input8::numlock
logical name: input8::scrolllock
capabilities: usb
