When I boot my QNX hypervisor ubuntu guest, nVidia GPU driver can’t display due to errors below:
NVRM: GPU 0000:00:03.0: RmInitAdapter failed! (0x26:0x65:1155)
NVRM: GPU 0000:00:03.0: rm_init_adapter failed, device minor number 0
ubuntu 18.04 with nvidia device driver has been installed in a hard disk, I can boot ubuntu with this hard disk as “Native” linux and got all display fine.
However if I boot the same hard disk’s ubuntu by a virtual machine loading from QNX hypervisor, I got the issue. If there are some special tips to use nvidia GPU driver from virtual machine?
After login to linux, I use SSH and run “nvidia-bug-report.sh” per link
https://devtalk.nvidia.com/default/topic/522835/linux/if-you-have-a-problem-please-read-this-first
and got result file “nvidia-bug-report.log.gz” . How to attached this result file with this report here?
