I tried to run my holoscan application remotely over SSH. I did configure X11 forwarding on the server (clara holoscan devkit).
The sshd_config file on the server looks like this:
AllowAgentForwarding yes
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding yes
X11DisplayOffset 10
X11UseLocalhost no
On the client (local computer) I run the following command:
ssh user@address -v -AX
The debug information returns that forwarding is activated. I can open any graphical application (e.g. xterm
) on the server without any issue. From inside a container on the server, however, I get the following error when running an application which uses holoviz:
Glfw Error 65544: X11: Failed to open display localhost:12.0
terminate called after throwing an instance of 'std::runtime_error'
what(): Failed to initialize glfw
Aborted (core dumped)
I ran the container following your guide with --net host
, -v /tmp/.X11-unix:/tmp/.X11-unix
and -e DISPLAY=$DISPLAY
Do you know how to set the display inside the container such that holoviz window is forwarded?
Any help would be much appreciated.
