I am using openSUSE Leap 15.3 with a Nvidia P620 card (4 port). It is connected to 4 Dell 32" monitors rotated.
I am using the openSUSE specific RPMs published to Index of /opensuse/leap/15.3/x86_64
This worked fine with version 460.80, but upgrading to 470.94 (and also tested 510.39.01), X server would crash with this error:
X.Org X Server 1.20.3
X Protocol Version 11, Revision 0
[ 505.776] Build Operating System: openSUSE SUSE LINUX
[ 505.776] Current Operating System: Linux mydesktop 5.3.18-59.37-default #1 SMP Mon Nov 22 12:29:04 UTC 2021 (d10168e) x86_64
[ 505.776] Kernel command line: BOOT_IMAGE=/vmlinuz-5.3.18-59.37-default root=UUID=533ba045-46ad-4a95-8fcc-05cb35dd66a7 net.ifnames=0 intel_idle.max_cstate=0 mitigations=auto quiet
[ 505.776] Build Date: 14 December 2021 12:00:00PM
[ 505.776]
[ 505.776] Current version of pixman: 0.34.0
[ 506.398] (II) NVIDIA(3): Setting mode "DP-4:nvidia-auto-select+0+0{AllowGSYNC=Off}"
[ 506.425] (WW) NVIDIA(3): Failed to set the display configuration
[ 506.425] (WW) NVIDIA(3): - Setting a mode on display 0 failed: The extended GPU
[ 506.425] (WW) NVIDIA(3): capabilities check failed
[ 506.425] (EE)
Fatal server error:
[ 506.425] (EE) AddScreen/ScreenInit failed for driver 3
If I removed the rotation setting or disabled the 4th monitor, it is no longer an issue and X server does not crash. Also note that each monitor is assigned to a separate “Screen” (not sure if this is relevant or not, but is notable).
Here is the xorg.conf:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 460.73.01
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" 2160 0
Screen 2 "Screen2" 4320 0
Screen 3 "Screen3" 6480 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from data in "/etc/sysconfig/mouse"
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "yes"
Option "ZAxisMapping" "4 5"
EndSection
# generated from default
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "DELL U3219Q"
HorizSync 10.0 - 137.0
VertRefresh 49.0 - 86.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor2"
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor3"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "Quadro P620"
BusID "PCI:1:0:0"
Screen 0
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 1
EndSection
Section "Device"
Identifier "Device2"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 2
EndSection
Section "Device"
Identifier "Device3"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 3
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-2"
Option "metamodes" "DP-2: nvidia-auto-select +0+0 {rotation=left}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "DP-0: nvidia-auto-select +0+0 {rotation=left}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Screen"
# Removed Option "metamodes" "DP-6: nvidia-auto-select +0+0 {rotation=right}"
# Removed Option "metamodes" "DP-4: nvidia-auto-select +0+0 {rotation=left}"
Identifier "Screen2"
Device "Device2"
Monitor "Monitor2"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-6"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Screen"
# Removed Option "metamodes" "DP-6: nvidia-auto-select +0+0 {AllowGSYNC=Off}"
# Removed Option "metamodes" "DP-6: nvidia-auto-select +0+0 {rotation=right, AllowGSYNC=Off}"
Identifier "Screen3"
Device "Device3"
Monitor "Monitor3"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-4"
Option "metamodes" "DP-4: nvidia-auto-select +0+0 {rotation=right, AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
I have just tested G04 - 390.147 on the same system and this branch of the driver does not have the issue with the 4th monitor rotation. I will use this driver for now until G05 is fixed.
