Pulling the deepstream:6.3-gc-triton-devel tag docker image from nvcr.io/nvidia/deepstream:6.3-gc-triton-devel, and entering that image interactively to check:
gst-inspect-1.0 x265enc
returns No such element or plugin 'x265enc'
same with x264enc.
Same issue with nvcr.io/nvidia/deepstream:6.2-devel, but we were using x264enc and x265enc elements without a problem inside nvcr.io/nvidia/deepstream:6.1.1-devel
Were x264 and x265 encoders intentionally removed or blacklisted in the latest deepstream container?
yingliu
2
Did you execute script “/opt/nvidia/deepstream/deepstream/user_additional_install.sh”?
Please refer to the explanation in the note Docker Containers — DeepStream 6.3 Release documentation (nvidia.com).
As mentioned by yingliu, you can try run user_additional_install.sh
in opt/nvidia/deepstream/deepstream/
x265enc/x264enc is part of gstreamer, you can install it by this script provided by DS.
Thanks both! I didn’t see that documentation - after running that script I can see the plugins are properly installed
