Hello
We used a brand new carrier board, but now there are two problems:
On the AGX development version, there is no problem with flash.sh flashing firmware, but when the new carrier board is operated, there are problems such as the problem in 1.txt1.txt (52.4 KB)
2.txt (7.0 KB) -
We use the development board to successfully flash the firmware, but the problem in 2.txt will occur when the core board is replaced with a new carrier board,and it will be stuck in this position every time it is started.
