A strange thing is when I shutdown AGX and power on the machine to restart, sometimes Xavier A normally start up,sometimes Xavier B, sometimes both,and sometime both not, each situation I have met.
Dear laizheyuan,
Do you see any errors while booting Tegras when connected to Tegra A/B via minicom.
Dear laizheyuan,
Could you please check the following information?
- Has it been a problem since you first used it?
- What is the environment in which you use the board?
- The unit is in a car or lab?
- Have you updated the board’s SW to Drive Software 9.0?
- Could you please cold reboot the unit not warm boot up?
Hi laizheyuan,
Please help to share the current status then we can help to provide suggestions.
