Hi
I would like to know if I can flash the same BSP binary (e.g. Jetpack 4.4 with 32.4.4) to Xavier AGX 32Gb module or 16Gb module ?
Should they use different device tree ?
hello chester.tseng,
may I know what binary, is it *.so
you would like to push to the target for testing?
the only difference is the emmc configuration since they’re having different root file system size.
thanks
I see, thanks.
I’m trying to flash the same MFI (including rootfs, kernel and device tree) to different configuration of Xavier AGX module. (16G / 32G)
it should works, the flash process will doing board parsing to include corresponding emmc cfg file.
