Having trouble running either the SDK Manager and flash.sh to flash two different AGX evices. I’ve tried on 2 PCs running ubuntu 18.04 (not VMs) and tried various cables to no avail. There seems to be a strange issue with the usb where the connection is lost. I’ve been searching the forums for a while and saw this thread but unclear on the resolution. Before i go searching for a 3rd PC, I wanted to check if there is another option to try. Also next will get the UART logs
/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign kernel_tegra194-p2888-0001-p2822-0000.dtb Welcome to Tegra Flash version 1.0.0 Type ? or help for help and q or quit to exit Use ! to execute system commands [ 0.0006 ] Generating signature [ 0.0016 ] tegrasign_v2 --key --getmode mode.txt [ 0.0026 ] Assuming zero filled SBK key [ 0.0028 ] [ 0.0030 ] header_magic: d00dfeed [ 0.0042 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb [ 0.0053 ] [ 0.0065 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000.dtb zerosbk [ 0.0075 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb [ 0.0188 ] [ 0.0210 ] tegrasign_v2 --key --list 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key [ 0.0219 ] Assuming zero filled SBK key [ 0.0228 ] [ 0.0244 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk [ 0.0309 ] [ 0.0316 ] Signed file: /home/miked/Downloads/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt l4t_sign_image.sh: Generate header for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt l4t_sign_image.sh: chip 0x19: add 0x45209 to offset 0x8 in sig file l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt l4t_sign_image.sh: the signed file is /home/miked/Downloads/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt done. Making system.img... populating rootfs from /home/miked/Downloads/Linux_for_Tegra/rootfs ... done. populating /boot/extlinux/extlinux.conf ... done. Sync'ing system.img ... done. Converting RAW image to Sparse image... done. system.img built successfully. Existing tbcfile(/home/miked/Downloads/Linux_for_Tegra/bootloader/cboot_t194.bin) reused. copying tbcdtbfile(/home/miked/Downloads/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done. copying cfgfile(/home/miked/Downloads/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done. Existing flasher(/home/miked/Downloads/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused. Existing flashapp(/home/miked/Downloads/Linux_for_Tegra/bootloader/tegraflash.py) reused. ./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb" saving flash command in /home/miked/Downloads/Linux_for_Tegra/bootloader/flashcmd.txt saving Windows flash command to /home/miked/Downloads/Linux_for_Tegra/bootloader/flash_win.bat *** Flashing target device started. *** Welcome to Tegra Flash version 1.0.0 Type ? or help for help and q or quit to exit Use ! to execute system commands [ 0.0249 ] tegrasign_v2 --key None --getmode mode.txt [ 0.0272 ] Assuming zero filled SBK key [ 0.0463 ] [ 0.0466 ] Generating RCM messages [ 0.0822 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk [ 0.0851 ] Header already present for mb1_t194_prod.bin [ 0.1070 ] [ 0.1087 ] tegrasign_v2 --key None --getmode mode.txt [ 0.1098 ] Assuming zero filled SBK key [ 0.1101 ] [ 0.1113 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key [ 0.1123 ] Assuming zero filled SBK key [ 0.1131 ] [ 0.1143 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk [ 0.1219 ] [ 0.1546 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin [ 0.1894 ] [ 0.1923 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg [ 0.1948 ] FwIndex: 1, MinRatchetLevel: 0 [ 0.1979 ] FwIndex: 2, MinRatchetLevel: 0 [ 0.1979 ] FwIndex: 3, MinRatchetLevel: 0 [ 0.1979 ] FwIndex: 4, MinRatchetLevel: 0 [ 0.1979 ] FwIndex: 5, MinRatchetLevel: 0 [ 0.1980 ] FwIndex: 6, MinRatchetLevel: 0 [ 0.1980 ] FwIndex: 7, MinRatchetLevel: 0 [ 0.1980 ] FwIndex: 8, MinRatchetLevel: 0 [ 0.1980 ] FwIndex: 11, MinRatchetLevel: 0 [ 0.1981 ] FwIndex: 12, MinRatchetLevel: 0 [ 0.1981 ] FwIndex: 13, MinRatchetLevel: 0 [ 0.1981 ] FwIndex: 14, MinRatchetLevel: 0 [ 0.1981 ] FwIndex: 15, MinRatchetLevel: 0 [ 0.1981 ] FwIndex: 16, MinRatchetLevel: 0 [ 0.1982 ] FwIndex: 17, MinRatchetLevel: 0 [ 0.1982 ] FwIndex: 18, MinRatchetLevel: 0 [ 0.1982 ] FwIndex: 19, MinRatchetLevel: 0 [ 0.1982 ] FwIndex: 30, MinRatchetLevel: 0 [ 0.1982 ] FwIndex: 31, MinRatchetLevel: 0 [ 0.1982 ] [ 0.2214 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0 [ 0.2238 ] RCM 0 is saved as rcm_0.rcm [ 0.2348 ] RCM 1 is saved as rcm_1.rcm [ 0.2350 ] RCM 2 is saved as rcm_2.rcm [ 0.2351 ] List of rcm files are saved in rcm_list.xml [ 0.2351 ] [ 0.2351 ] Signing RCM messages [ 0.2374 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin [ 0.2388 ] Assuming zero filled SBK key [ 0.2399 ] [ 0.2399 ] Copying signature to RCM mesages [ 0.2412 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml [ 0.2430 ] [ 0.2431 ] Parsing partition layout [ 0.2966 ] tegraparser_v2 --pt flash.xml.tmp [ 0.3025 ] [ 0.3026 ] Creating list of images to be signed [ 0.3054 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk [ 0.3069 ] MB1: Nvheader already present is mb1_t194_prod.bin [ 0.3080 ] Header already present for mb1_t194_prod_sigheader.bin [ 0.3089 ] MB1: Nvheader already present is mb1_t194_prod.bin [ 0.3142 ] Header already present for mb1_t194_prod_sigheader.bin [ 0.3151 ] adding BCH for spe_t194.bin [ 0.3514 ] adding BCH for spe_t194.bin [ 0.3622 ] adding BCH for nvtboot_t194.bin [ 0.3689 ] adding BCH for nvtboot_t194.bin [ 0.3754 ] Header already present for preboot_c10_prod_cr.bin [ 0.3892 ] Header already present for preboot_c10_prod_cr.bin [ 0.3897 ] Header already present for mce_c10_prod_cr.bin [ 0.3945 ] Header already present for mce_c10_prod_cr.bin [ 0.3990 ] adding BCH for mts_c10_prod_cr.bin [ 0.4718 ] adding BCH for mts_c10_prod_cr.bin [ 0.6023 ] adding BCH for cboot_t194.bin [ 0.7221 ] adding BCH for cboot_t194.bin [ 0.7391 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb [ 0.7555 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb [ 0.7656 ] adding BCH for tos-trusty_t194.img [ 0.8302 ] adding BCH for tos-trusty_t194.img [ 0.8530 ] adding BCH for eks.img [ 0.8929 ] adding BCH for eks.img [ 0.8935 ] adding BCH for bpmp_t194.bin [ 0.9221 ] adding BCH for bpmp_t194.bin [ 0.9597 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb [ 1.0538 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb [ 1.0884 ] adding BCH for camera-rtcpu-rce.img [ 1.1364 ] adding BCH for camera-rtcpu-rce.img [ 1.1537 ] adding BCH for adsp-fw.bin [ 1.1949 ] adding BCH for adsp-fw.bin [ 1.2013 ] Header already present for warmboot_t194_prod.bin [ 1.2140 ] Header already present for warmboot_t194_prod.bin [ 1.2162 ] adding BCH for recovery.img [ 2.2605 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb.rec [ 4.2017 ] adding BCH for boot.img [ 4.2514 ] adding BCH for boot.img [ 5.6890 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb [ 8.4569 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb [ 8.6860 ] [ 8.6860 ] Filling MB1 storage info [ 8.6861 ] Generating br-bct [ 8.6873 ] Performing cfg overlay [ 8.6873 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg'] [ 8.6878 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61.cfg [ 14.4210 ] [ 14.4212 ] Updating dev and MSS params in BR BCT [ 14.4213 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0 [ 14.5002 ] [ 14.5003 ] Updating bl info [ 14.5017 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin [ 14.5046 ] [ 14.5047 ] Generating signatures [ 14.5062 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key [ 14.5076 ] Assuming zero filled SBK key [ 15.3719 ] [ 15.3720 ] Generating br-bct [ 15.3750 ] Performing cfg overlay [ 15.3751 ] ['/home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61.cfg'] [ 15.3752 ] Updating dev and MSS params in BR BCT [ 15.3754 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0 [ 15.4607 ] [ 15.4608 ] Updating bl info [ 15.4622 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml [ 15.4663 ] [ 15.4664 ] Updating smd info [ 15.4678 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin [ 15.4693 ] [ 15.4693 ] Updating Odmdata [ 15.4707 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000 [ 15.4723 ] [ 15.4724 ] Get Signed section of bct [ 15.4742 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml [ 15.4759 ] [ 15.4772 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin [ 15.4784 ] Assuming zero filled SBK key [ 15.4788 ] [ 15.4788 ] Updating BCT with signature [ 15.4801 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml [ 15.4815 ] [ 15.4816 ] Generating coldboot mb1-bct [ 15.4838 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg [ 15.4850 ] MB1-BCT version: 0x1 [ 15.4854 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg [ 15.4865 ] Added Platform Config 0 data with size :- 3008 [ 15.4887 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg [ 15.4892 ] Added Platform Config 1 data with size :- 19640 [ 15.5604 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg [ 15.5613 ] Added Platform Config 2 data with size :- 24 [ 15.5814 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg [ 15.5831 ] Added Platform Config 4 data with size :- 348 [ 15.5841 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg [ 15.5855 ] Added Platform Config 3 data with size :- 92 [ 15.5933 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg [ 15.5943 ] Added Platform Config 5 data with size :- 56 [ 15.5948 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg [ 15.5956 ] Added Platform Config 7 data with size :- 392 [ 15.5956 ] [ 15.5957 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg [ 15.5957 ] Added Platform Config 8 data with size :- 12 [ 15.5957 ] [ 15.5957 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg [ 15.5957 ] Added Platform Config 9 data with size :- 32 [ 15.5957 ] [ 15.5958 ] Updating mb1-bct with firmware information [ 15.5970 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin [ 15.5982 ] MB1-BCT version: 0x1 [ 15.5987 ] [ 15.5988 ] Updating mb1-bct with storage information [ 15.6002 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin [ 15.6015 ] MB1-BCT version: 0x1 [ 15.6021 ] [ 15.6022 ] Updating mb1-bct with ratchet information [ 15.6033 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg [ 15.6044 ] MB1-BCT version: 0x1 [ 15.6048 ] FwIndex: 1, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 2, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 3, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 4, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 5, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 6, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 7, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 8, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 11, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 12, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 13, MinRatchetLevel: 0 [ 15.6051 ] FwIndex: 14, MinRatchetLevel: 0 [ 15.6052 ] FwIndex: 15, MinRatchetLevel: 0 [ 15.6052 ] FwIndex: 16, MinRatchetLevel: 0 [ 15.6052 ] FwIndex: 17, MinRatchetLevel: 0 [ 15.6052 ] FwIndex: 18, MinRatchetLevel: 0 [ 15.6052 ] FwIndex: 19, MinRatchetLevel: 0 [ 15.6052 ] FwIndex: 30, MinRatchetLevel: 0 [ 15.6052 ] FwIndex: 31, MinRatchetLevel: 0 [ 15.6052 ] [ 15.6064 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct [ 15.6075 ] [ 15.6086 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk [ 15.6096 ] adding BCH for mb1_cold_boot_bct_MB1.bct [ 15.6109 ] [ 15.6124 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key [ 15.6134 ] Assuming zero filled SBK key [ 15.6140 ] [ 15.6154 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk [ 15.6172 ] [ 15.6174 ] Generating recovery mb1-bct [ 15.6194 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg [ 15.6211 ] MB1-BCT version: 0x1 [ 15.6216 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg [ 15.6226 ] Added Platform Config 0 data with size :- 3008 [ 15.6251 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg [ 15.6258 ] Added Platform Config 1 data with size :- 19640 [ 15.6469 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg [ 15.6478 ] Added Platform Config 2 data with size :- 24 [ 15.6483 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg [ 15.6492 ] Added Platform Config 4 data with size :- 348 [ 15.6497 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg [ 15.6503 ] Added Platform Config 3 data with size :- 92 [ 15.6503 ] [ 15.6503 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg [ 15.6503 ] Added Platform Config 5 data with size :- 56 [ 15.6503 ] [ 15.6503 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg [ 15.6503 ] Added Platform Config 7 data with size :- 392 [ 15.6504 ] [ 15.6504 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg [ 15.6504 ] Added Platform Config 8 data with size :- 12 [ 15.6504 ] [ 15.6504 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg [ 15.6504 ] Added Platform Config 9 data with size :- 32 [ 15.6504 ] [ 15.6505 ] Updating mb1-bct with firmware information [ 15.6519 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin [ 15.6533 ] MB1-BCT version: 0x1 [ 15.6539 ] [ 15.6540 ] Updating mb1-bct with storage information [ 15.6552 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin [ 15.6565 ] MB1-BCT version: 0x1 [ 15.6570 ] [ 15.6571 ] Updating mb1-bct with ratchet information [ 15.6582 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg [ 15.6593 ] MB1-BCT version: 0x1 [ 15.6597 ] FwIndex: 1, MinRatchetLevel: 0 [ 15.6599 ] FwIndex: 2, MinRatchetLevel: 0 [ 15.6601 ] FwIndex: 3, MinRatchetLevel: 0 [ 15.6604 ] FwIndex: 4, MinRatchetLevel: 0 [ 15.6606 ] FwIndex: 5, MinRatchetLevel: 0 [ 15.6608 ] FwIndex: 6, MinRatchetLevel: 0 [ 15.6610 ] FwIndex: 7, MinRatchetLevel: 0 [ 15.6610 ] FwIndex: 8, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 11, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 12, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 13, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 14, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 15, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 16, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 17, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 18, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 19, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 30, MinRatchetLevel: 0 [ 15.6611 ] FwIndex: 31, MinRatchetLevel: 0 [ 15.6611 ] [ 15.6623 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct [ 15.6634 ] [ 15.6645 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1.bct zerosbk [ 15.6657 ] adding BCH for mb1_bct_MB1.bct [ 15.6671 ] [ 15.6686 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key [ 15.6696 ] Assuming zero filled SBK key [ 15.6702 ] [ 15.6716 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk [ 15.6735 ] [ 15.6736 ] Generating coldboot mem-bct [ 15.6747 ] tegrabct_v2 --chip 0x19 0 --sdram /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61.cfg --membct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_1.bct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_2.bct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_3.bct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_4.bct [ 15.6757 ] Packing sdram param for instance[0] [ 15.7531 ] Packing sdram param for instance[1] [ 15.7535 ] Packing sdram param for instance[2] [ 15.7540 ] Packing sdram param for instance[3] [ 15.7541 ] Packing sdram param for instance[4] [ 15.7542 ] Packing sdram param for instance[5] [ 15.7542 ] Packing sdram param for instance[6] [ 15.7542 ] Packing sdram param for instance[7] [ 15.7542 ] Packing sdram param for instance[8] [ 15.7542 ] Packing sdram param for instance[9] [ 15.7542 ] Packing sdram param for instance[10] [ 15.7542 ] Packing sdram param for instance[11] [ 15.7542 ] Packing sdram param for instance[12] [ 15.7542 ] Packing sdram param for instance[13] [ 15.7542 ] Packing sdram param for instance[14] [ 15.7542 ] Packing sdram param for instance[15] [ 15.7542 ] [ 15.7543 ] Getting sector size from pt [ 15.7557 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin [ 15.7570 ] [ 15.7571 ] BlockSize read from layout is 200 [ 15.7583 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_1.bct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_2.bct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_3.bct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_4.bct [ 15.7593 ] adding BCH for /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_1.bct [ 15.7632 ] [ 15.7648 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct [ 15.7667 ] [ 15.7679 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot.bct zerosbk [ 15.7692 ] Header already present for mem_coldboot.bct [ 15.7699 ] [ 15.7715 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key [ 15.7725 ] Assuming zero filled SBK key [ 15.7732 ] [ 15.7746 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk [ 15.7762 ] [ 15.7763 ] Generating recovery mem-bct [ 15.7774 ] tegrabct_v2 --chip 0x19 0 --sdram /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61.cfg --membct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_1.bct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_2.bct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_3.bct /home/miked/Downloads/Linux_for_Tegra/bootloader/9551/tmpbpftc7q61_4.bct [ 15.7784 ] Packing sdram param for instance[0] [ 15.8546 ] Packing sdram param for instance[1] [ 15.8551 ] Packing sdram param for instance[2] [ 15.8553 ] Packing sdram param for instance[3] [ 15.8554 ] Packing sdram param for instance[4] [ 15.8554 ] Packing sdram param for instance[5] [ 15.8554 ] Packing sdram param for instance[6] [ 15.8554 ] Packing sdram param for instance[7] [ 15.8554 ] Packing sdram param for instance[8] [ 15.8554 ] Packing sdram param for instance[9] [ 15.8554 ] Packing sdram param for instance[10] [ 15.8555 ] Packing sdram param for instance[11] [ 15.8555 ] Packing sdram param for instance[12] [ 15.8555 ] Packing sdram param for instance[13] [ 15.8555 ] Packing sdram param for instance[14] [ 15.8555 ] Packing sdram param for instance[15] [ 15.8555 ] [ 15.8557 ] Reading ramcode from backup chip_info.bin file [ 15.8672 ] RAMCODE Read from Device: 2 [ 15.8674 ] Disabled BPMP dtb trim, using default dtb [ 15.8674 ] [ 15.8692 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct [ 15.8710 ] [ 15.8728 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm.bct zerosbk [ 15.8744 ] adding BCH for mem_rcm.bct [ 15.8778 ] [ 15.8794 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key [ 15.8805 ] Assuming zero filled SBK key [ 15.8812 ] [ 15.8838 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk [ 15.8865 ] [ 15.8867 ] Copying signatures [ 15.8881 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml [ 20.4596 ] [ 20.4598 ] Boot Rom communication [ 20.4626 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml [ 20.4654 ] BootRom is not running [ 25.8107 ] [ 26.8151 ] tegrarcm_v2 --isapplet
