Hi, I am using the Xavier AGX 32GB developer kit. I am having booting issues after modifying extlinux.conf in /boot/extLinux after adding another kernel boot option. It goes into a “Halt: spinning forever…” after attempting to load extlinux.conf. See the boot messages below.
What is causing this error? I was able to add other alternate kernels (before this one) with no issues. Is there a limit on the number of alternate kernel boot options? How do I recover the device from here?
¦¦¦¦Shutdown state requested 1
Rebooting system …
[0000.054] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.062] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.067] I> Boot-mode: Coldboot
[0000.070] I> Chip revision : A02P
[0000.073] I> Bootrom patch version : 15 (correctly patched)
[0000.079] I> ATE fuse revision : 0x200
[0000.082] I> Ram repair fuse : 0x1
[0000.085] I> Ram Code : 0x2
[0000.088] I> rst_source : 0xb
[0000.090] I> rst_level : 0x1
[0000.094] I> Boot-device: eMMC
[0000.109] I> sdmmc DDR50 mode
[0000.113] W> No valid slot number is found in scratch register
[0000.118] W> Return default slot: _a
[0000.122] I> Active Boot chain : 0
[0000.125] I> Boot-device: eMMC
[0000.129] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.135] I> Temperature = 42500
[0000.138] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.142] W> Skipping boost for clk: BPMP_APB
[0000.146] W> Skipping boost for clk: AXI_CBB
[0000.150] W> Skipping boost for clk: AON_CPU_NIC
[0000.154] W> Skipping boost for clk: CAN1
[0000.158] W> Skipping boost for clk: CAN2
[0000.163] I> Boot-device: eMMC
[0000.165] I> Boot-device: eMMC
[0000.175] I> Sdmmc: HS400 mode enabled
[0000.179] I> ECC region[0]: Start:0x0, End:0x0
[0000.183] I> ECC region[1]: Start:0x0, End:0x0
[0000.187] I> ECC region[2]: Start:0x0, End:0x0
[0000.192] I> ECC region[3]: Start:0x0, End:0x0
[0000.196] I> ECC region[4]: Start:0x0, End:0x0
[0000.200] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.206] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.210] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.214] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.219] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.224] E> FAILED: Thermal config
[0000.232] E> FAILED: MEMIO rail config
[0000.250] I> Boot-device: eMMC
[0000.260] I> sdmmc bdev is already initialized
[0000.340] I> MB1 done¦¦¦¦main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.349] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-2dfe4beb)
[0000.349] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.350] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.351] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.356] W> device prod register failed
[0000.360] I> Boot-device: eMMC
[0000.363] I> Boot_device: SDMMC_BOOT instance: 3
[0000.369] I> sdmmc-3 params source = boot args
[0000.372] I> sdmmc bdev is already initialized
[0000.376] I> sdmmc-3 params source = boot args
[0000.383] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.390] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.392] W> No valid slot number is found in scratch register
[0000.397] W> Return default slot: _a
[0000.400] I> Active Boot chain : 0
[0000.404] I> parsing oem signed section of bpmp-fw header done
[0000.409] I> bpmp-fw binary init read from storage
[0000.415] I> oem authentication of bpmp-fw header done
[0000.422] I> bpmp-fw binary done read from storage
[0000.424] I> bpmp-fw: Authentication init Done
[0000.428] I> parsing oem signed section of cpubl header done
[0000.434] I> cpubl binary init read from storage
[0000.438] I> bpmp-fw: Authentication Finalize Done
[0000.443] I> oem authentication of cpubl header done
[0000.447] I> cpubl binary done read from storage
[0000.452] I> cpubl: Authentication init Done
[0000.457] I> parsing oem signed section of rce header done
[0000.461] I> rce binary init read from storage
[0000.466] I> Relocating BR-BCT
[0000.469] I> cpubl: Authentication Finalize Done
[0000.473] I> oem authentication of rce header done
[0000.478] I> rce binary done read from storage
[0000.482] I> rce: Authentication init Done
[0000.487] I> parsing oem signed section of ape header done
[0000.491] I> ape binary init read from storage
[0000.496] I> rce: Authentication Finalize Done
[0000.500] I> oem authentication of ape header done
[0000.504] I> ape binary done read from storage
[0000.509] I> ape: Authentication init Done
[0000.515] I> parsing oem signed section of tos header done
[0000.518] I> tos binary init read from storage
[0000.522] I> ape: Authentication Finalize Done
[0000.527] I> oem authentication of tos header done
[0000.531] I> tos binary done read from storage
[0000.535] I> tos: Authentication init Done
[0000.540] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.545] I> bpmp-fw-dtb binary init read from storage
[0000.550] I> tos: Authentication Finalize Done
[0000.556] I> oem authentication of bpmp-fw-dtb header done
[0000.563] I> bpmp-fw-dtb binary done read from storage
[0000.565] I> bpmp-fw-dtb: Authentication init Done
[0000.570] I> parsing oem signed section of cpubl-dtb header done
[0000.576] I> cpubl-dtb binary init read from storage
[0000.580] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.618] I> oem authentication of cpubl-dtb header done
[0000.618] I> cpubl-dtb binary done read from storage
[0000.619] I> cpubl-dtb: Authentication init Done
[0000.621] I> parsing oem signed section of eks header done
[0000.621] I> eks binary init read from storage
[0000.622] I> cpubl-dtb: Authentication Finalize Done
[0000.623] I> oem authentication of eks header done
[0000.626] I> eks binary done read from storage
[0000.631] I> eks: Authentication init Done
[0000.635] I> eks: Authentication Finalize Done
[0000.639] I> EKB detected (length: 0x410) @ VA:0x5270a400
¦¦NOTICE: BL31: v1.3(release):41d46a9cf
NOTICE: BL31: Built : 21:14:52, Jun 25 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing …
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
¦¦welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0001.143] I> Welcome to Cboot
¦¦fmon_post initialized
¦¦[0001.143] I> Cboot Version: t194-18fdfe28
[0001.144] I> CPU-BL Params @ 0xf2820000
[0001.144] I> 0) Base:0x00000000 Size:0x00000000
[0001.147] I> 1) Base:0xf1100000 Size:0x00100000
[0001.152] I> 2) Base:0xf2000000 Size:0x00200000
[0001.156] I> 3) Base:0xf1200000 Size:0x00200000
[0001.161] I> 4) Base:0xf1000000 Size:0x00100000
¦¦clk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
¦¦[0001.165] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.270] I> 6) Base:0xf3800000 Size:0x00400000
[0001.275] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.279] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.284] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.288] I> 10) Base:0xf3000000 Size:0x00800000
[0001.293] I> 11) Base:0x40000000 Size:0x00040000
[0001.297] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.301] I> 13) Base:0x40046000 Size:0x00002000¦¦emc_debugfs initialized
dvs_debugfs initialized
¦¦fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ¦¦[0001.311] I> 14) Base:0x40048000 Size:0x00002000
[0001.361] I> 15) Base:0xac000000 Size:0x00004000
[0001.366] I> 16) Base:0x4004a000 Size:0x00002000
[0001.370] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.374] I> 18) Base:0x4004c000 Size:0x00002000
[0001.379] I> 19) Base:0xf2200000 Size:0x00600000
[0001.383] I> 20) Base:0x4004e000 Size:0x00002000
[0001.388] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.392] I> 22) Base:0x00000000 Size:0x00000000
[0001.397] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.401] I> 24) Base:0xf6000000 Size:0x02000000
[0001.406] I> 25) Base:0x40050000 Size:0x00002000
[0001.410] I> 26) Base:0x40040000 Size:0x00006000
[0001.415] I> 27) Base:0xf1800000 Size:0x00400000
[0001.419] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.424] I> 29) Base:0xf1400000 Size:0x00400000
[0001.428] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.433] I> 31) Base:0x00000000 Size:0x00000000
[0001.437] I> 32) Base:0xf8000000 Size:0x08000000
[0001.441] I> 33) Base:0x00000000 Size:0x00000000
[0001.446] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.450] I> 35) Base:0xab000000 Size:0x01000000
[0001.455] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.459] I> 37) Base:0xf2800000 Size:0x00800000
[0001.464] I> 38) Base:0x80000000 Size:0x20000000
[0001.468] I> 39) Base:0xb0000000 Size:0x08000000
[0001.473] I> 40) Base:0x00000000 Size:0x00000000
[0001.477] I> 41) Base:0x00000000 Size:0x00000000
[0001.482] I> 42) Base:0x00000000 Size:0x00000000
[0001.486] I> 43) Base:0x00000000 Size:0x00000000
[0001.491] I> 44) Base:0x00000000 Size:0x00000000
[0001.495] I> 45) Base:0x00000000 Size:0x00000000
[0001.499] GIC-SPI Target CPU: 0
[0001.502] Interrupts Init done
[0001.505] calling constructors
[0001.508] initializing heap
[0001.511] I> Heap: [0xa06905a8 … 0xab000000]
[0001.515] initializing threads
[0001.518] initializing timers
[0001.521] creating bootstrap completion thread
[0001.525] top of bootstrap2()
[0001.528] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.533] initializing platform
[0001.535] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.541] W> device prod register failed
[0001.545] I> Bl_dtb @0xaaf00000
[0001.551] W> “plugin-manager” doesn’t exist, creating
[0001.553] W> “ids” doesn’t exist, creating
[0001.557] W> “connection” doesn’t exist, creating
[0001.561] W> “configs” doesn’t exist, creating
[0001.573] I> Find /i2c@3160000’s alias i2c0
[0001.573] I> Reading eeprom i2c=0 address=0x50
[0001.599] I> Device at /i2c@3160000:0x50
[0001.599] I> Reading eeprom i2c=0 address=0x56
[0001.624] I> Device at /i2c@3160000:0x56
[0001.625] I> Find /i2c@3180000’s alias i2c2
[0001.625] I> Reading eeprom i2c=2 address=0x54
[0001.627] E> I2C: slave not found in slaves.
[0001.627] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.628] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.629] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.638] E> eeprom: Failed to read I2C slave device
[0001.643] I> Eeprom read failed 0x3526070d
[0001.647] I> Reading eeprom i2c=2 address=0x57
[0001.651] E> I2C: slave not found in slaves.
[0001.655] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.663] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.668] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.678] E> eeprom: Failed to read I2C slave device
[0001.683] I> Eeprom read failed 0x3526070d
[0001.687] I> Reading eeprom i2c=2 address=0x52
[0001.691] E> I2C: slave not found in slaves.
[0001.695] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.703] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.708] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.718] E> eeprom: Failed to read I2C slave device
[0001.723] I> Eeprom read failed 0x3526070d
[0001.728] I> Find /i2c@c240000’s alias i2c1
[0001.731] I> Reading eeprom i2c=1 address=0x52
[0001.736] E> I2C: slave not found in slaves.
[0001.739] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.747] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.753] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.762] E> eeprom: Retry to read I2C slave device.
[0001.767] E> I2C: slave not found in slaves.
[0001.771] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.779] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.784] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.794] E> eeprom: Failed to read I2C slave device
[0001.799] I> Eeprom read failed 0x3526070d
[0001.803] I> Reading eeprom i2c=1 address=0x50
[0001.807] E> I2C: slave not found in slaves.
[0001.811] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.819] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.824] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.834] E> eeprom: Retry to read I2C slave device.
[0001.839] E> I2C: slave not found in slaves.
[0001.843] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.851] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.856] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.866] E> eeprom: Failed to read I2C slave device
[0001.871] I> Eeprom read failed 0x3526070d
[0001.875] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0001.880] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.891] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0001.896] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.907] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.915] W> “i2c@3160000” doesn’t exist, creating
[0001.919] W> “module@0x50” doesn’t exist, creating
[0001.923] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.930] W> “module@0x56” doesn’t exist, creating
[0001.937] I> Adding plugin-manager/cvm
[0001.939] W> “chip-id” doesn’t exist, creating
[0001.943] I> Adding plugin-manager/chip-id/A02P
[0001.947] I> Plugin-manager override starting
[0001.953] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.961] I> node /plugin-manager/fragement-soft-wdt matches
[0001.971] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.975] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.986] I> Disable plugin-manager status in FDT
[0001.986] I> Plugin-manager override finished successfully
[0001.987] I> gpio framework initialized
[0001.989] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0001.996] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.003] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.010] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.019] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.025] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.031] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.038] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.046] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.053] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.060] I> fixed regulator driver initialized
[0002.070] I> register ‘maxim’ power off handle
[0002.071] I> virtual i2c enabled
[0002.072] I> registered ‘maxim,max20024’ pmic
[0002.075] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.081] I> Boot-device: eMMC
[0002.084] I> Boot_device: SDMMC_BOOT instance: 3
[0002.093] I> sdmmc-3 params source = boot args
[0002.093] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.098] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.109] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.114] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.125] I> sdmmc bdev is already initialized
[0002.130] I> sdmmc-3 params source = boot args
[0002.160] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.173] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.182] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.187] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.188] I> hdmi cable connected
[0002.190] W> set volts not configured for ‘vdd-1v0’
[0002.192] W> set volts not configured for ‘vdd-1v8-hs’
[0002.195] E> invalid display type
[0002.199] E> invalid display type
[0002.200] E> cannot find any other nvdisp nodes
[0002.216] I> edid read success
[0002.228] I> edid read success
[0002.228] I> width = 640, height = 480, frequency = 25174825
[0002.229] I> width = 640, height = 480, frequency = 25174825
[0002.230] I> width = 2560, height = 1440, frequency = 296730000
[0002.230] I> width = 1920, height = 1080, frequency = 148500000
[0002.234] I> width = 720, height = 480, frequency = 27000000
[0002.240] I> width = 640, height = 480, frequency = 25174825
[0002.245] I> width = 720, height = 480, frequency = 26973026
[0002.251] I> width = 720, height = 480, frequency = 26973026
[0002.256] I> width = 720, height = 576, frequency = 26973026
[0002.262] I> width = 720, height = 576, frequency = 26973026
[0002.267] I> width = 1280, height = 720, frequency = 74175824
[0002.273] I> width = 1280, height = 720, frequency = 74175824
[0002.278] I> width = 1920, height = 1080, frequency = 148351648
[0002.284] I> width = 1920, height = 1080, frequency = 148351648
[0002.290] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.300] I> hdmi_enable, starting HDMI initialisation
[0002.305] I> hdmi_enable, HDMI initialisation complete
[0002.316] I> Load in CBoot Boot Options partition and parse it
[0002.322] E> Error -9 when finding node with path /boot-configuration
[0002.323] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.325] I> Hit any key to stop autoboot: 4 3 2 1
[0004.333] initializing target
[0004.333] calling apps_init()
[0004.334] starting app kernel_boot_app
[0004.353] I> found decompressor handler: lz4-legacy
[0004.354] I> decompressing BMP blob …
[0004.357] I> Kernel type = Normal
[0004.358] I> Loading kernel-bootctrl from partition
[0004.358] I> Loading partition kernel-bootctrl at 0xa4ac0000 from device(0x1)
[0004.365] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.365] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.366] I> ########## SD boot ##########
[0004.370] I> No sdcard
[0004.372] I> -0 params source =
[0004.375] E> Blockdev open: exit error
[0004.378] E> SD boot failed, err: 724238353
[0004.382] I> ########## USB boot ##########
[0004.391] W> No valid slot number is found in scratch register
[0004.392] W> Return default slot: _a
[0004.409] I> USB Firmware Version: 60.06 release
[0004.464] I> regulator of usb2-0 already enabled
[0004.472] I> regulator of usb2-1 already enabled
[0004.479] I> regulator of usb2-2 already enabled
[0004.488] I> enabling ‘vdd-5v-sata’ regulator
[0005.556] I> USB 2.0 port 4 new low-speed USB device detected
[0005.557] W> Change usb2 root port id to 1
[0005.557] W> Change usb2 root port id to 4
[0005.558] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa0e9f800, cmd_ring.dma = 0xa0e9f840
[0005.559] E> slot id is 1
[0005.560] W> handle_command_completion_event: WARNING: Command was not successfully completed (0x11)
[0006.569] W> xusbh_wait_irq: Timed out! status = 0x00
[0007.573] W> xusbh_wait_irq: Timed out! status = 0x00
[0007.574] W> failed to enumerate usb device
[0007.574] E> failed to start xhci controller
[0007.574] E> Error in init of XUSB host driver, err: 7979000c
[0007.575] E> Failed to initialize device 5-0
[0007.575] E> USB boot failed, err: 2037973004
[0007.575] I> ########## Fixed storage boot ##########
[0007.580] I> Already published: 00010003
[0007.584] I> Look for boot partition
[0007.587] I> Fallback: assuming 0th partition is boot partition
[0007.593] I> Detect filesystem
[0007.620] I> Loading extlinux.conf …
[0007.621] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0007.657]
[0007.658] -----------------------------------------------
[0007.659] Synchronous Exception: DATA ABORT (FAR: 6)
[0007.660] -----------------------------------------------
[0007.662] PAR_ELX: 0x80f
[0007.662]
[0007.663] ESR 0x96000007: ec 0x25, il 0x1, iss 0x7
[0007.664] -----------------------------------------------
[0007.665] [Stack Trace]
[0007.666]
[0007.666] => pc:0xA0644764, sp:0xA0E9F360
[0007.670] => pc:0xA063EE30, sp:0xA0E9F590
[0007.673] => pc:0xA063F160, sp:0xA0E9F620
[0007.677] => pc:0xA060F450, sp:0xA0E9F690
[0007.681] => pc:0xA060F5EC, sp:0xA0E9F730
[0007.685] => pc:0xA060F600, sp:0xA0E9F7A0
[0007.689] => pc:0xA060F284, sp:0xA0E9F7E0
[0007.693] => pc:0xA060E7F8, sp:0xA0E9F7F0
[0007.696] => pc:0xA060E7CC, sp:0xA0E9F800
[0007.700] -----------------------------------------------
[0007.706] iframe 0xa0e9f270:
[0007.708] x0 0x 6 x1 0x a4ab863b x2 0x 7 x3 0x 6b
[0007.717] x4 0x 0 x5 0x 70 x6 0x a x7 0xffffffffffffffff
[0007.727] x8 0x d0 x9 0x 1 x10 0x 2f x11 0x a064d328
[0007.736] x12 0x a0690000 x13 0x a0691808 x14 0x a0692b50 x15 0x 200
[0007.745] x16 0x 1 x17 0x 438 x18 0x 0 x19 0x a0690080
[0007.754] x20 0x 5 x21 0x a0692298 x22 0x a0e9f778 x23 0x a0e9f718
[0007.763] x24 0x a4ab8e94 x25 0x a0655000 x26 0x a4ab863b x27 0x 30
[0007.772] x28 0x 6 x29 0x a0e9f590 lr 0x a0640484 sp 0x a0e9f360
[0007.781] elr 0x a0644764
[0007.784] spsr 0x 80000209
[0007.787] -----------------------------------------------
[0007.793] panic (caller 0xa0601238): die
[0007.796] HALT: spinning forever…
