I’m using Xavier AGX with jetpack 4.9 (R32.4)
I have trouble using D-PHY to get image.
There is signal output from sensor and it looks fine.
Here’s the trace, it keep repeating so I just show part of it:
kworker/0:1-17730 [000] … 4366.165905: rtcpu_vinotify_event: tstamp:136728598452 tag:FS channel:0x00 frame:1 vi_tstamp:136728291972 data:0x00000010
kworker/0:1-17730 [000] … 4366.165907: rtcpu_vinotify_event: tstamp:136728598600 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:136728291973 data:0x00000000
kworker/0:1-17730 [000] … 4366.165908: rtcpu_vinotify_event: tstamp:136728598725 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:136728307901 data:0x00000001
kworker/0:1-17730 [000] … 4366.165909: rtcpu_vinotify_event: tstamp:136728598867 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:136173133056 data:0x08020001
kworker/0:1-17730 [000] … 4366.165911: rtos_queue_peek_from_isr_failed: tstamp:136729028612 queue:0x0bcbcf78
kworker/0:1-17730 [000] … 4366.221890: rtcpu_nvcsi_intr: tstamp:136730188068 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:1-17730 [000] … 4366.221893: rtcpu_nvcsi_intr: tstamp:136730188068 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:1-17730 [000] … 4366.221895: rtcpu_nvcsi_intr: tstamp:136730188068 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:1-17730 [000] … 4366.221896: rtcpu_nvcsi_intr: tstamp:136730188068 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:1-17730 [000] … 4366.221898: rtcpu_vinotify_event: tstamp:136730190081 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:136730187821 data:0x177f0002
kworker/0:1-17730 [000] … 4366.221899: rtcpu_vinotify_event: tstamp:136730190226 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:136730187837 data:0x00000000
kworker/0:1-17730 [000] … 4366.221900: rtcpu_vinotify_event: tstamp:136730190352 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:136233291680 data:0x02020001
kworker/0:1-17730 [000] … 4366.221902: rtcpu_vinotify_event: tstamp:136730190493 tag:FE channel:0x00 frame:1 vi_tstamp:136730187843 data:0x00000020
kworker/0:1-17730 [000] … 4366.221903: rtcpu_vinotify_event: tstamp:136730190623 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:136730187843 data:0x00000000
kworker/0:1-17730 [000] … 4366.221904: rtcpu_vinotify_event: tstamp:136730190763 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:136233299776 data:0x00020001
kworker/0:1-17730 [000] … 4366.221905: rtcpu_vinotify_event: tstamp:136730190886 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:136233306784 data:0x07020002
kworker/0:1-17730 [000] … 4366.221912: rtos_queue_send_from_isr_failed: tstamp:136730199975 queue:0x0bcb41f8
kworker/0:1-17730 [000] … 4366.221913: rtos_queue_send_from_isr_failed: tstamp:136730200119 queue:0x0bcb8a60
kworker/0:1-17730 [000] … 4366.221915: rtos_queue_send_from_isr_failed: tstamp:136730200261 queue:0x0bcba5e0
kworker/0:1-17730 [000] … 4366.221940: rtos_queue_send_from_isr_failed: tstamp:136730200396 queue:0x0bcbb3a0
kworker/0:1-17730 [000] … 4366.221942: rtos_queue_send_from_isr_failed: tstamp:136730200528 queue:0x0bcbc160
kworker/0:1-17730 [000] … 4366.221944: rtcpu_vinotify_event: tstamp:136730516777 tag:FS channel:0x00 frame:2 vi_tstamp:136730389472 data:0x00000010
kworker/0:1-17730 [000] … 4366.221945: rtcpu_vinotify_event: tstamp:136730516909 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:136730389473 data:0x00000000
kworker/0:1-17730 [000] … 4366.221946: rtcpu_vinotify_event: tstamp:136730517057 tag:CHANSEL_PXL_SOF channel:0x23 frame:2 vi_tstamp:136730405401 data:0x00000001
kworker/0:1-17730 [000] … 4366.221947: rtcpu_vinotify_event: tstamp:136730517180 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:136240253056 data:0x08020002
kworker/0:1-17730 [000] … 4366.221948: rtcpu_vinotify_event: tstamp:136730517320 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:136240336128 data:0x10000000
kworker/0:1-17730 [000] … 4366.221949: rtcpu_vinotify_event: tstamp:136730517442 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:136240346912 data:0x31000003
kworker/0:1-17730 [000] … 4366.277886: rtcpu_nvcsi_intr: tstamp:136732285571 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:1-17730 [000] … 4366.277889: rtcpu_nvcsi_intr: tstamp:136732285571 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:1-17730 [000] … 4366.277891: rtcpu_nvcsi_intr: tstamp:136732285571 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:1-17730 [000] … 4366.277892: rtcpu_nvcsi_intr: tstamp:136732285571 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:1-17730 [000] … 4366.277926: rtos_queue_send_from_isr_failed: tstamp:136732298935 queue:0x0bcb41f8
kworker/0:1-17730 [000] … 4366.277928: rtos_queue_send_from_isr_failed: tstamp:136732299079 queue:0x0bcb8a60
kworker/0:1-17730 [000] … 4366.277930: rtos_queue_send_from_isr_failed: tstamp:136732299220 queue:0x0bcba5e0
kworker/0:1-17730 [000] … 4366.277931: rtos_queue_send_from_isr_failed: tstamp:136732299357 queue:0x0bcbb3a0
kworker/0:1-17730 [000] … 4366.277932: rtos_queue_send_from_isr_failed: tstamp:136732299491 queue:0x0bcbc160
kworker/0:1-17730 [000] … 4366.277934: rtcpu_vinotify_event: tstamp:136732504440 tag:CHANSEL_PXL_EOF channel:0x23 frame:2 vi_tstamp:136732285321 data:0x177f0002
kworker/0:1-17730 [000] … 4366.277935: rtcpu_vinotify_event: tstamp:136732504570 tag:ATOMP_FRAME_DONE channel:0x23 frame:2 vi_tstamp:136732285337 data:0x00000000
kworker/0:1-17730 [000] … 4366.277936: rtcpu_vinotify_event: tstamp:136732504714 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:136300411680 data:0x02020002
kworker/0:1-17730 [000] … 4366.277938: rtcpu_vinotify_event: tstamp:136732504840 tag:FE channel:0x00 frame:2 vi_tstamp:136732285343 data:0x00000020
kworker/0:1-17730 [000] … 4366.277939: rtcpu_vinotify_event: tstamp:136732504982 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:136732285343 data:0x00000000
kworker/0:1-17730 [000] … 4366.277940: rtcpu_vinotify_event: tstamp:136732505104 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:136300419776 data:0x00020002
kworker/0:1-17730 [000] … 4366.277942: rtcpu_vinotify_event: tstamp:136732505244 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:136300426816 data:0x07020003
The trace showed there were PHY error between FS and FE.
I have checked TRM, but still don’t know what do these description “intr_cil_data_lane_sot_2lsb_err1_a”, “intr_dphy_cil_clk_lane_ulpm_req_a”, “intr_cil_lpdt_int1_a” mean.
Any idea?
