Xavier AGX SOM not booting up
Hi Sir/ Madam,
I have Xavier AGX in which SOM is not getting power on, Carrier Board is working fine as we have checked the same while changing with the other SOM of Xavier AGX.
Can someone help me with this ?
Which jetapck releaese?
Custom board or devkit?
At least provide above information.
Jetpack version was 4.6
It is a development kit.
As per our observation, it is not related to software or OS but it is related to the hardware of Xavier AGX.
Please try to flash 32.7.2 and see if the issue is same.
We were trying that but in Host Machine (SDK Manager), this device is not at all visible.
If you are sure your host and flash other AGX module, then it is hardware problem. We can only ask you to RMA this module.
Thank you for the suggestion.
Can you help me, what would be my next step for RMA?
What if I need an RMA (Return Material Authorization)?(Jetson FAQ | NVIDIA Developer)
If you believe that your Jetson product is defective, please contact the NVIDIA Customer Care team. We will help you troubleshoot your issue and process a replacement if it is found to be defective.
  1. Go to this link.
  2. Select “Live Chat” option to chat online with one of our customer care agents.
  3. Enter your contact information.
  4. Select the “Jetson” from the product drop-down list.
  5. Submit the request.
