We are using the Xavier AGX H.265 and Jetpack 4.3 and have some questions about the nvidia video encoder:
Is the source code of the encoder GStreamer Plugin, omxh265enc available? Is there a Link? If not, is there an HEVC encoding sample?
Can the H.265 video stream’s encoding QP be changed dynamically at runtime while encoding is happening? (eg, via API Call)? If so, is there a list of additional dynamically configurable encoding parameters?
Is there encoding feedback on the complexity of a frame upon completion of encoding it?
Can a frame be encoded in horizontal slice segments by a single encoder?
Is there documentation for enabling and tuning Variable Frame Rate. VFR?
Thank you.
qp-range : Qunatization range for P, I and B frame,
Use string with values of Qunatization Range
in MinQpP-MaxQpP:MinQpI-MaxQpI:MinQpB-MaxQpB order, to set the property.
Or set up fixed QP value:
quant-i-frames : Quantization parameter for I-frames (0xffffffff=component default),
use with ratecontrol-enable = 0
and preset-level = 0
flags: readable, writable, changeable only in NULL or READY state
Unsigned Integer. Range: 0 - 4294967295 Default: 4294967295
quant-p-frames : Quantization parameter for P-frames (0xffffffff=component default),
But we don’t support configuring QP value of each frame.
We have th eproperty in nvv4l2h265enc:
EnableMVBufferMeta : Enable Motion Vector Meta data for encoding
Boolean. Default: false
Not sure it it is the data you need. Please enable it and check.
Now we support fixed framerate. Supporting VFR is under evaluation. Please check
